Home > Message Board > Home Video > Rear Projection TVs > Archive through July 12, 2005 > Wiring of Samsung HLR5067 and HD850/9...
Author Thread: Wiring of Samsung HLR5067 and HD850/950 with Comcast HD box
Username: Hppygllmr
WA
The HLR only has one HDMI input. My HD cable box has a DVI or Component output and, depending on which DVD player I get, will have either a HDMI or DVI output. What's the best way to wire these to maximize my picture quality?
Username: Kdog044
Post Number: 134
Use component for the cable box and HDMI for the upconverting DVD player. I assume this will be an upconverting player as those are the only ones with DVI or HDMI output.
The DVI is overrated in my opinion, I had my upconverting DVD player hooked up with it to my sammy DLP and it gives you a grainy picture, I think the Component cables are much better, even cheap ones. Try it out with both and see, and please let us know your opinion.
Username: Helpful_smurf
Post Number: 10
I also stepped down from DVI/HDMI on my cable box to Component in favor of the HDMI to HDMI connection for my upconvert DVD player. I noticed no difference in the quality of my HD from my comcast HD/DVR (Motorola DCT6400) on the Samsung HLR 5067.
And before the bunghole that keeps hijacking threads responds to this one, I immediately saw rainbows, heard fan noise and decided to return my set and bought a Sony Projection LCD. What a dork.
Home > Message Board > Home Video > Rear Projection TVs > Archive through July 12, 2005 > Wiring of Samsung HLR5067 and HD850/9... [ « Previous ] [ Next » ]
