Thread: Samsung 42 inch projection tv picture problem |
New member Username: Donald44
Post Number: 1 Registered: Jun-05
| Posted on Thursday, June 16, 2005 - 03:39 pm: |
tv picture looks 3d and the auto picture perfect focus only goes to 4% now. anyone having this problem |
nicole fahey Unregistered guest |
| Posted on Tuesday, June 28, 2005 - 02:42 am: |
hi don We are having exactly the same problem with our Samsung TV. Any ideas how to fix it? nicole. |
| Posted on Monday, July 11, 2005 - 10:38 pm: |
We are having the same problem too. Just woke up one day and all colors are off line and red looks warped. |
| Posted on Thursday, July 14, 2005 - 10:14 am: |
I've recently purchased this TV, 42" Samsung HLR ,and it's been about 3 weeks now. I recently noticed that when I switch on the TV, the screen is very reddish, seems like it couldn't produce blue and green, even though I switch the channel, the picture just shows the color red, in different levels, the whole picture is very reddish. I have to switch off the tv, wait a bit and switch back on again then it'll be back to normal. This doesn't happen everytime, but happened just enough to worries me a lot. This could be an indication of larger problem in the future right? |
Silver Member Username: Fyi
Dallas,
Texas
Post Number: 103 Registered: May-05
| Posted on Thursday, July 14, 2005 - 10:28 am: |
Answered on another thread. Possible cable or connection problem. |
| Posted on Thursday, July 14, 2005 - 10:33 am: |
Thank you for quick response... but how would there be connection problem when I'm only viewing local TV stations? There's only the cable directly connected to the TV. |
Dallas,
Texas
Post Number: 105 Registered: May-05
| Posted on Thursday, July 14, 2005 - 10:41 am: |
Good question! That's the worst of all the connection methods. I'm not sure if you have a set top box or straight cable, but a digital or component Pr, Pb, Y connection is the best. A sure way to rule out the set as having a problem is to hook up a DVD player through one of the above connection methods. If a DVD plays fine every time it's cable related. |
| Posted on Thursday, July 14, 2005 - 10:45 am: |
Thanks FYI, I'll give it a try. Hope it's not the TV itself...cause I was worried about mechanical problems or the spinning wheel got stuck and couldn't produce other color than red...or something like that.... |
| Posted on Friday, July 29, 2005 - 04:01 pm: |
I am having the same problem mentioned above, but it appears that there is a bow in the picture both at the top and bottom. I tried some of the cable connections but this did not resolve the problem. Any ideas or suggestions about what else to try? |
