Home > Message Board > Home Video > Satellite TV > Archive through June 18, 2005 > Samsung SIR-TS160 receives no signal ...
Author Thread: Samsung SIR-TS160 receives no signal from Satellite 110
Hey Guys,
I'm not sure is this belongs here but here it goes. I recently upgraded Direct Tv to an HD dish and HD receiver. Everything works great so far except that I am not receiving any signal from satellite 110 which means no HBO HB or Showtime HD and a few others. in setting it up I put my zip in and got the right elevation & tilt numbers. But I'm still not receiving any signal. On the other 2 satellites 101 & 119 reception is near 100%. Can someone help me out here? Whats the problem? Here are some test results.
490 Test 1 SAT A (101) Odd Txp 13V
491 Test 2 SAT A (101) Even Txp 18V
492 Test 3 SAT B (119) Odd Txp 13V
403 Test 4 SAT B (119) Even Txp 18V
494 Searching for satellite signal. Please stand by.
Has this problem happened to anynone else? Can someone please recommend some things to try? Could it be a defective C LNB?
hello .... can someone giwe the new key code numbers ; its ben a week i lost all my channels ;please help me ; i use fortec reciwer
Home > Message Board > Home Video > Satellite TV > Archive through June 18, 2005 > Samsung SIR-TS160 receives no signal ... [ « Previous ] [ Next » ]
