Thread: VCR, TV, Satellite recording problem |
Unregistered guest |
| Posted on Saturday, June 11, 2005 - 12:43 pm: |
Anyone, I have a mitsubishi TV, JVC VCR and a dish satellite. I have been trying to connect all 3 together so that I can record onto the VCR but no luck. Can anyone help. |
Gold Member Username: Samijubal
Post Number: 1150 Registered: Jul-04
| Posted on Saturday, June 11, 2005 - 12:49 pm: |
Use RCA cables from the satellite to the in on the VCR and set the VCR to line, look for an input button on the remote or go through the channels till you get to line. Connect the VCR to the TV with RCA cables too. |
| Posted on Sunday, July 03, 2005 - 08:18 pm: |
please help, i have dvd/vcr and i want to record from regular tv and i cant seem to get it. |
New member Username: Robyn
Post Number: 1 Registered: Jul-05
| Posted on Saturday, July 09, 2005 - 06:20 am: |
I am trying to connect my video. I have cable tv so not sure where I connect the video to cable box or tv. |
New member Username: Raverys12
| Posted on Saturday, July 09, 2005 - 11:30 am: |
I have a Toshiba vhs/dvd recorder that I have installed and I have it all setup with a switch box. I can view my dish network video with no problem and my input from the vcr works fine, but when I go to record I cant seem to get a video or audio signal to record. I have tryed composit video to the input of the vcr and also switched from TV to cable on the vcr .... no soap ... I'm sure it is something simple that I am just over looking .... any suggestions ... Help will be appreciated. |
