Thread: Archive through May 23, 2005 |
Bronze Member Username: Steve_m
Ivyland,
PA
Post Number: 21 Registered: Feb-05
| Posted on Sunday, May 08, 2005 - 09:42 am: |
Dawny, Could you please give me the phone number and extention of the person who helped you in Wayne. If you are not comfortable posting his|her number maybe you could email it to me at sbjmedlar@comcast.net. Thanks a million. |
Relevant Product Info
jvc_explorer Unregistered guest |
| Posted on Sunday, May 08, 2005 - 10:04 am: |
I purchased a HD52Z585 and loved the picture, but returned it due to 1) LOUD fan, 2) not enough connections, 3) gray side bars in 4:3 mode, and 4) the HDMI connection would stop working (required a power cycle on the Dish 942DVR). I exchanged it for a Samsung hlp4663w which resolved all 4 issues, but the picture just isn't as good (in my opinion). On the HD52Z585, I'm wondering if all units have a noisy fan (any quiet ones out there?) or if there's some kind of fix. I also heard there may have been an HDMI issue that can be resolved by a service call? On the next generation units (are they out yet?), has the fan noise issue been resolved? Are black side bars in 4:3 mode available? I'm wondering if I should just go with the next generation of sets. |
To jvc-explorer Unregistered guest |
| Posted on Sunday, May 08, 2005 - 11:31 am: |
You don't have your 4663 set up correctly. I suggest you calibrate your display using the Avia CD or Home Theater Basics CD or some DVD with THX calibration such as Ladder 49. Remember to write down the settings because each input must be adjusted. For now: Contrast...90 Brightness.45 Sharpness..20 Color......44 Tint.......50...mine is disabled. Color Tone...Normal In Setup and Color Weakness set the green to 2 or 3. These settings +- 2 are close. |
| Posted on Monday, May 09, 2005 - 06:01 pm: |
In my opinion the 4663 just doesn't have the same PQ as the JVC. It uses the HD3 chip which produces a softer image. The 4674 is much better in my opinion, maybe even superior to the JVC (if you can live with the rainbows). The fan on my JVC is quite noisy. The fix is to turn up the volume and watch a lot of action movies ;) Many HD receivers have the capaibility to up-convert SD signals to HD and insert black bars. My SA 8300HD does this, so I never have to deal with the gray bar issue. Your receiver might do the same. If not, your options would be to (1) get used to it; (2) use one of the stretch modes to fill the screen. |
New member Username: 1red1
WA
Post Number: 1 Registered: May-05
| Posted on Tuesday, May 10, 2005 - 12:20 am: |
I just bought a 585 model tv about 2 weeks ago. I think I got a good deal, I paid $2500 for the tv the stand and a 5 year service warranty. The only problem I have with the set is the "loud fan noise" It is really noticeable when I watch tv at night and have the volume down. I was thinking of maybe returning the unit and getting the sony 55"lcd but it will probably be another $500 for a comparable package. Does anybody have any comments on the sony sets and fan noise? |
HD Fanatic Unregistered guest |
| Posted on Tuesday, May 10, 2005 - 01:02 am: |
I have had 3 Sony's and I can honestly tell you that the fan noise was very minimal. The loudness varied slightly on each of them, the quietest was my 55" KDF-55WF655 February build. It's a bit louder right at start-up, but 30 seconds or so after the TV is on, I had to get about 2ft. from the set before I could hear it. Things to watch out for on the Sony's, the first set I had,(KDF-55WF655) the screen would black out for a split second while watching anything connected to component video. Would only happen 3-5 times through-out a movie, but enough to take the enjoyment out. The second set (another KDF-55WF655), the display info would pop up by itself. Not very often, maybe once every 8 hrs of viewing. Enough to be a nuisance. The third set (a KDF-60XS955) had a stuck blue pixel smack dab in the middle of the screen. Plus, the screen-door-effect and SSE were very bothersome with this set. All these problems are well documented among a vast number of owners of Sonys. I know that these problems may seem minor to some, and maybe I'm being too picky, but I'm really not expecting perfection. It's just that when spending over 3 grand for a TV, one should expect things to work correctly. I'm currently waiting to view the new JVC 61". Sony is also coming out with some new models, and I would like to see them also. My advice to you, is if you are unhappy with your 52" JVC. take it back. The issues I had with my Sony's may not bother you. I'm holding out for the new models... |
New member Username: Spoto
Post Number: 2 Registered: Mar-05
| Posted on Tuesday, May 10, 2005 - 09:23 am: |
RaveD -- I've got the SA 8000HD STB and am wondering if you had to do anything special to the 8300 to get black side bars? Mine is set for 1080i output, but on SD programs the sidebars are grey. To be honest, I don't notice it anymore and it's not a disturbance but it might be nice to get black side bars. Not sure if it matters but my cable service is Time Warner. |
| Posted on Tuesday, May 10, 2005 - 10:32 am: |
I had a JVC and took it back for fan noise and picture tilt. I bought a Sony and have been very happy. While the JVC picture is slightly better (black levels, smooth) the Sony is a much better overall package. |
New member Username: Quazl
AR
| Posted on Tuesday, May 10, 2005 - 01:17 pm: |
Great Thread. Actaully amazing thread. I can say that I have almost read every single post on this thread (almost). I hope that this question has not been asked or answered. On the JVC site these are the 7 models of D-ILA's. HD-52Z575 (52 inch Silver) HD-61Z575 (61 inch Sliver) HD-52Z585 (52 inch Black) HD-61Z585 (61 inch Black) HD-61Z886 (61 inch Black, newer model) HD-61Z786 (61 inch Sliver, newer model) HD-70G886 (70 inch Black, newer model) I have compared the details of the features between the older models with the newer models. It seems that the only thing that is different is the Dual IEEE 1394 (i.Link) Connectivity. Is this a correct assumption? I have read alot about light engine repairs or replacements and light bulb replacements. Do the newer models have the correct or better light engine? I realize that getting a warranty with the light bulb replacement is a must, but my only reserve now is the light engine. The Television that i have now suffers from simailiar problems that the light engine that Mr. Lynch and other say cause bas color in the corners. It is a normal CRT, so it isn't anything like the the D-ILA, but i can say that I hate color problems. The bad image and color problems that I have on my existing set is the reason that I am buying a new TV. Basically, my question is this: If I buy a newer model are the chances of getting the dreaded green corners lower? This really is my only concern before I choose Between the HD-61Z575 (61 inch Silver) and the HD-61Z786 (61 inch Sliver, newer model). Quazl 'Cuba has gun control and universal health care, so why do they clamor to come here?' |
Onmitsu Unregistered guest |
| Posted on Tuesday, May 10, 2005 - 02:56 pm: |
Quazl, The new sets have a cable-card slot and a high definition over-the-air tuner. They have a new 32 bit image processor, and the color management has gone from 4-point to 5-point (adding "flesh tone"). I do not think the light engine has changed. JVC has not said that it has, and the picture geometry looks the same as the old sets. I have had a 585 and a 786. I have not seen problems with color uniformity across the screen. Onmitsu. p.s. The HD-61Z786 is black. |
AR
Post Number: 2 Registered: May-05
| Posted on Tuesday, May 10, 2005 - 06:14 pm: |
Onmitsu, Thanks for the reponse. That is wanted to know. I didn't do enough research. You have knocked me off the fence into the greener grass. What kind of set do you own now? Quazl
New member Username: Jefff629
Post Number: 1 Registered: Mar-05
| Posted on Wednesday, May 11, 2005 - 02:55 am: |
RE: Fan noise I have the HD61Z575 and was bothered by the fan noise (which increases in volume as the set heats up) and the ensuing whiny tone that emanates from the front of the set. I had the front fan replaced (the exhaust fan, there are two other cooling fans), but it made no difference. I had the set sitting on top of a glass table with components on the two lower shelves. Using a sound level meter, I recorded 50dbs at 4' coming from the front of the set just from the sound of the fan. Because I like the picture so much on this JVC, I was determined to work out the fan noise issue. First: the bulk of the egregious noise is transmitted by reverbs off the surface on which the set sits. If the set is resting on a hard surface, the noise will be amplified. I lay a 1/4" sheet of acoustic vinyl on top of the glass table and reduced the noise by about 30%. 50dbs were read inside 3'. Then, I discovered that most of the sound came from the 1/4" space between the surface of the table and the lower front edge of the JVC. The set itself rests on several small "feet" that elevate the television. I cut a 2" wide by 30" long strip of 1/4" spongy poster board (available at any art store) and placed it under the front of the television, flush with the front edge. I trimmed the front edge of the board with black electrical tape so it's virtually invisible. 50dbs can now only be read at 6". When I sit 12' from the set now, I can barely hear the fan noise and the whiny tone is completely gone. If you read the JVC site carefully, they make a point of stating the the surface on which the set rests determines the volume of the fan noise (e.g. harder surface = more noise). My advice is to simply buy the $5 piece of poster board, tape the edge with a dark color, and slide it under the front edge of the set to block the space between the table surface and the bottom of the television. The sound eminating from the front surface of the television is minimal and won't bother the viewer from 12'. The quality of the picture on these sets - the closest to film on any rear-projection HD - is worth keeping |
| Posted on Wednesday, May 11, 2005 - 10:56 am: |
Jeff -- great post on reducing fan noise. Questions: - Where can you get acoustic vinyl? - By placing the poster board under the front of the TV doesn't it change the viewing angle? Or are you suggesting that it fits in the space already there due to the feet? - Do you think either of these measures might reduce airflow around the TV and cause more heat buildup within the set? |
| Posted on Wednesday, May 11, 2005 - 11:03 am: |
Sam -- On the 8300HD, have you run the HD setup wizard and restricted the output to 1080i only? If so then the 8300HD should be generating the bars on SD material. The 8300HD is capable of generating gray or black bars. There is another setting in there (I can't recall the exact name) which you can set to "Dark", "Medium", or "Light". Setting it to dark will produce black sidebars. |
New member Username: Bigguylow
Alameda,
CA
Post Number: 3 Registered: Apr-05
| Posted on Wednesday, May 11, 2005 - 12:20 pm: |
Jeff, if possible, could you post a pic of your setup with the soundproofing. Thanks. |
| Posted on Wednesday, May 11, 2005 - 01:32 pm: |
Quazl, I had the 585 for four weeks, and then I swapped it for the 786. I have had the 786 for about four weeks. My local store did a no charge swap, so I got my 786 for what I paid for the 585 :-) I have been very happy with both sets, and have no plans on changing any time soon. Onmitsu. |
| Posted on Wednesday, May 11, 2005 - 04:02 pm: |
Hi Everyone, Great forum. I recently purchased a 52" 575 Dec. build. When I turn off the TV 3 senarios occur: 1. TV shuts off and cooling fan stays on for 90 seconds and the blue power light goes off. I assume this is the norm. 2. TV shuts off, cooling fan goes off and light goes off. This is probably bad, but it hasn't happened often. 3. TV shuts off, cooling fan stays on for 90 seconds and the blue power light stays on. This has happened several times. Can anyone in this brillant forum enlighten me? Thanks in advance! |
| Posted on Wednesday, May 11, 2005 - 05:02 pm: |
The norm is #3. Mine does it every time. Are you sure the AC power is not interrupted? |
| Posted on Wednesday, May 11, 2005 - 05:12 pm: |
RaveD - You mean your blue power light is on all the time even when your TV is powered off? In my senario #3 everything on the TV is off except the blue power light and the orange lamp light above the power button. In my senario #1 the lights are on only as long as the cooling fan is on. I am positive the AC power is not interrupted. Thanks for your quick response. |
| Posted on Wednesday, May 11, 2005 - 05:18 pm: |
I guess I misunderstood. Then scenario #1 is normal; the power light and LED stay on while the TV cools off, then everything shuts off. Also, I have the power light set to LOW, and when the TV is turned off, it goes to HIGH during the cooldown period. |
| Posted on Wednesday, May 11, 2005 - 07:21 pm: |
Yes, that's the normal shut-off sequence. |
Derfinot Unregistered guest |
| Posted on Wednesday, May 11, 2005 - 07:50 pm: |
I recently ordered a HD-61Z575 from Costco about 3 weeks ago. I checked last week and Costco no longer carries the 61" model anymore. I received my set yesterday and to my suprise it was the HD-61Z886 with a April 2005 build date. I wonder if Costco oversold the older model and had to replace the orders with the newer model. In any event I am very happy, out of the box the picture looks amazing. Thanks to everyone on this board for the recomendations |
| Posted on Wednesday, May 11, 2005 - 10:04 pm: |
Derfinot, DAMMIT! You lucky dog! If somehow I could have known, I would have placed my order. You got one heck of a deal. |
| Posted on Thursday, May 12, 2005 - 03:41 am: |
To RaveD and Bob Low - RE: fan noise I live in Southern California where material like acoustic vinyl is easier to get than most places (due to the number of recording and post-production studios). The truth is, almost any thin sheet of soft vinyl or even 1/8" foam rubber would do. I purchased mine (and it's pretty expensive) from Steve Klein (available on the internet most likely) in N. Hollywood (http://www.soundcontrolroom.com/facts.htm). The sheet is about 6" wider (on all sides) than the footprint of the television. I cut the sheet of 1/4" insulated poster board to 30". The set is actually about 34" wide at its base. The 2" on either side allows for the feet to sit on the table, not the poster board. I lifted each side of the set to insert the poster board under the set's front edge. The set rests perfectly level and is not elevated by the 1/4" board. All the board does is seal the front space under the television so no sound resonates from below the set and out toward the viewing area. I failed to mention (although I believe this has little effect) that I mounted a 2'X4' acoustic sound board (also from Steven Klein) on the wall behind the set. I wanted to ensure that no sound emanating from the rear fans would bounce off the wall. The JVC discharges no heat from beneath the television. All out ports are at the rear of the set. As long as you leave about 3" between the rear of the set and the wall, it should vent perfectly. I will post a photo of the set up soon. It's actually easier to describe than to display in a photo, because the poster board, as I've placed it, is almost invisible. I am considering, because I've become obsessive about eliminating all noise from the fans, building a panel lined with acoustic foam and cut to the contour of the front of the television to allow for the curved power panel (the blue power light and red LED). I don't use the JVC's speakers and know that if I put a facing in the front of the set, I can totally kill the noise - slight as it is now - coming from the fan. If I finish it in black lacquer, it'll look really nice. But, until it rains for about three days straight, I think I'll wait. There are better things to do. Like actually WATCHING the JVC. Hope this helps. |
| Posted on Thursday, May 12, 2005 - 11:53 am: |
I just bought the 575 from best buy and it will get delivered next week. One reason I bought this type of TV was to avoid burn in. I was just looking at the product manual on JVC's website, and it has a warning about burn in. Is that just kind of a legal CYA thing, or is it actually a problem with these TVs. Everything I read and the guys at best buy (who were very helpful) said these TVs don't have burn in problems. Thanks! |
Silver Member Username: Mr_lynch
Seattle,
WA
Post Number: 730 Registered: Sep-04
| Posted on Thursday, May 12, 2005 - 12:06 pm: |
Buddha- Back when I bought my set last August, we had a big discussion on it. I contacted JVC and they said the Dila sets do NOT suffer from burn-in. The manual is an edited version of the rear-projection CRT one and they accidentally left the burn-in warning. You can ignore it. I've played hours of Halo/Halo 2 with no signs of burn-in, and I watch SD in 4:3 with black bars with out any issues either. I've probably had my JVC set longer than most forum users, put thousands of hours on my set, and I can tell you from experience that the TV will not burn-in. |
Bronze Member Username: Douga
Post Number: 45 Registered: Dec-04
| Posted on Thursday, May 12, 2005 - 12:09 pm: |
buddha, JVC has confirmed that there is no burn in with this set*. It is either a misprint or a CYA as you stated. *JVC does mention the possibility of a temporary burn-in situation where the image may appear to be burned-in for a very small amount of time. If the tv is shut off or the static image on the set is changed (i.e. change channels), the temporary burn in is gone. In other words, there is no permanent burn-in problem. |
| Posted on Thursday, May 12, 2005 - 03:47 pm: |
Mr. Lynch and Mr. Ardy, Thanks for the info! I am really looking foward to getting this TV. Like you Mr. Lynch, I am looking forward to playing Halo2 in widescreen HD. Any other advice you guys have to a new owner of this TV? I went ahead and bought the bestbuy service plan. I'm going to be hooking my xbox, ps2 (new one with progessive scan DVD player), and SD satelitte receiver with s-video up to it. Waiting to get HD until DirectTV gets the MPEG-4 stuff ready. And I got a yamaha home theater in a box setup to hook up to it as well. Thanks! |
Seattle,
WA
Post Number: 733 Registered: Sep-04
| Posted on Thursday, May 12, 2005 - 04:30 pm: |
buddha- The s-video connection is probably going to look like crap, so don't expect too much. I'd recommend picking a disc like DVE or AVIA and to correct any brightness and color issues the set may have. The JVCs default settings are overly bright and vivid. It looks great in a really bright showroom, but when you get it home it will most lilely need to be toned down a bit. After a week or two of viewing your new set, you will might start to noticing minor issues with your TV. Wait to make adjustment then. You might really enjoy the default settings so why mess with it. Also go into the user menu and turn off all the "enhancements" like "Dynamic gamma", "color management", "digital noise reduction". They seem hurt the picture more than they help. For the Xbox you should pick up the HD pack. It comes with Component cables (they work great) and only cost $20. That way you can enjoy your Xbox in true widescreen 480p/720p. Amped 2 is a personal favorate of mine to show off the TV. The 720p graphics are amazingly crisp and clear. |
| Posted on Thursday, May 12, 2005 - 09:34 pm: |
Mr. Lynch, Thanks for the tips! I already picked up the HD cables - really looking forward to trying it out. Can you get those kind of disks at a place like best buy, or do you need to order them from somewhere special? I would imagine those would most likely eliminate the need for professional calibration? Thanks again! |
Bronze Member Username: Ruffwood
Post Number: 13 Registered: Feb-05
| Posted on Thursday, May 12, 2005 - 10:21 pm: |
I have enjoyed my JVC 61Z575 since February and have tweaked the color settings for a few weeks using DVE and Mr.Lynch's settings. Thanks Mr. Lynch Then I was tweaking my Surround Sound system for a couple of weeks, and now its on to fan noise reduction. Will it ever end? Thanks for the tips, Jeff F Also, Walmart has Black 1/4" poster board. They also have green, yellow Etc. If anyone wants to get creative. |
Post Number: 14 Registered: Feb-05
| Posted on Friday, May 13, 2005 - 09:50 am: |
Anyone have any HomeDepot/Lowes light fixture suggestions for backlighting a 61Z575? |
Bronze Member Username: Mr_sparks
Ca
Usa
Post Number: 75 Registered: Jan-05
| Posted on Friday, May 13, 2005 - 01:10 pm: |
"Bud - Can you get those kind of disks (DVE) at a place like best buy, or do you need to order them from somewhere special?" Here's the web site for Digital Video Essentials DVD: http://www.videoessentials.com/ You'll most likely need to buy it online. It's a very helpful disk for basic's like brightness, color, detail and such. |
| Posted on Friday, May 13, 2005 - 01:24 pm: |
Buddha: Before plunking down the dough for the DVE or AVia disks, look to see if you have any with the THX optimizer program on them. These will be Star Wars Episode 2, etc. You may find that setting up with this device is totally acceptable. I have also found that if your set has multiple picture modes (dynamic, standard, cinema) which are independently adjustable it works well to use them as optimized modes for Standard definition TV, DVD, and High Def programming. Using Dynamic I have SD quality that is very good, better than CRTrp sets, Standard is set up for optimized HD content, and Cinema is optimized for dvd. The set is a Samsung DLP but most sets have a similar setup. |
Seattle,
WA
Post Number: 735 Registered: Sep-04
| Posted on Friday, May 13, 2005 - 01:33 pm: |
I've seen DVE and AVIA at several stores around the Seattle area. Best Buy, Fry's and Suncoast all carry it. Avia is $50, DVE can be found for $20-$25. The THX optimiser works really good, but having a blue filter will increase the acurracy of your adjustments. DVE comes with a blue, red and green filter. On my JVC I setup each of the color modes for different types of viewing. "Standard" was fine tuned to Standard def signals "Dynamic" was adjusted for HD content "Theater" for DVDs "game" for my Xbox. |
| Posted on Friday, May 13, 2005 - 03:30 pm: |
Actually, I do have Episode II on DVD. I'll have to give that one a try first. Of course, I'm sure anything will be better than what I'm used to. I have a 10 year old magnavox 32". Although I do have to say it has held up very nicely and has a good picture, especially with directv SD. Thanks for the advice! I'm so glad I stumbled on this website while doing a google search! |
New member Username: Ccorcoran
Post Number: 3 Registered: May-05
| Posted on Saturday, May 14, 2005 - 05:45 pm: |
Any tips... trying to avoid vertical sidebars when watching with HD channels (thru Comcast and Motorola STB). Some HD channels default to widescreen "full" while others post black sidebars and thereafter require aspect changes (HD Panarama or Cinema Zoom) to get widescreen. When possible, would like "full" by default. Is there a way to setup the Motorola STB or change setting on my JVC 52 ? |
Post Number: 4 Registered: May-05
| Posted on Saturday, May 14, 2005 - 05:52 pm: |
Also, Mr Sparks... I purchased my JVC 52 via Costco. Could you reply to the specifics of the "value added" gained from a JVC purchase thru Costco as compared to typical internet options. Is it possible to upgrade my JVC when newer JVC options become available. |
New member Username: Motliek
IN
Post Number: 9 Registered: Jan-05
| Posted on Saturday, May 14, 2005 - 09:15 pm: |
Good Eve, Well 4 months to the day and my stinkin lamp blew. JVC is of course going to overnight one to me on Monday , due Tue or Wed. Now I get to watch the Survivor Finale on a lovely 19". Sweeeeet. Should have put 2+2 together as I adjusted the brightness most of the week. Aside from this still love the set!!! |
Bronze Member Username: Dan_furlong
Texas
Post Number: 40 Registered: Jan-05
| Posted on Sunday, May 15, 2005 - 08:29 am: |
I have an extra brand new bulb from JVC just incase of a blow out. I have recently returned my JVC for another brand. If anyone would like to buy it, make a reasonable offer. danfurlong@netzero.com |
New member Username: Dapercy
Post Number: 4 Registered: Mar-05
| Posted on Sunday, May 15, 2005 - 12:46 pm: |
Just called an Ultimate Electronics that is going out of business and asked if they had any D-ILAs and the salesman told me that they have been recalled for catching on fire? I think he may have been trying to direct me to his remaining Samsung inventory. Can anyone confirm this. It didn't sound too far fetched with the overheating problems discussed on this thread. |
Bronze Member Username: Sailbyte
Post Number: 46 Registered: Dec-04
| Posted on Sunday, May 15, 2005 - 04:24 pm: |
David: Some D-ILAs have been recalled due to a potential fire problem. This has been handled very nicely by JVC with a very quick in-home repair that involves a quick part swap. I have no idea what the issue with that particular vendor may be -- but I love my JVC.
Bronze Member Username: Mrtomasulo
Post Number: 41 Registered: Mar-05
| Posted on Monday, May 16, 2005 - 09:53 am: |
Mr. Lynch-- I just picked up a Toshiba 5980 dvd player and was just curious what setting you play most of your movies at (480p, 720p, or 1040i)? Also to anyone, what's the qualitative difference between 720p and 1040i? Is 1040i supposed to be better? |
| Posted on Monday, May 16, 2005 - 10:29 am: |
Mister T. The difference between 720 P and 1040i will be in most cases less afactor than the "actual" resolution of the program material. If you check out the different HD sources you will see a great variation in quality . Even going back to the old 480i analog system, most picture resolution was considerably less than 480 lines, as low as 200 on some vcrs. 720 P should theoretically yield a smoother picture since each pass paints an entire frame. The 1080i would theoretically yield a slightly more detailed picture due to the extra lines, however they are painted 520 lines per pass. Real world signal differences will create much greater differences than the native resolution |
Ca
Usa
Post Number: 76 Registered: Jan-05
| Posted on Monday, May 16, 2005 - 02:32 pm: |
CRAIG - "Also, Mr Sparks... I purchased my JVC 52 via Costco. Could you reply to the specifics of the "value added" gained from a JVC purchase thru Costco as compared to typical internet options." I like to buy from costco because, if the item breaks or fails to satisfy me, I can simply return it for a full refund, for as long as I am a member. I, personally would not buy a big ticket item from most of the internet companies, because once you take delivery, they will not give you service. Just how I like to buy ... |
Seattle,
WA
Post Number: 737 Registered: Sep-04
| Posted on Monday, May 16, 2005 - 02:51 pm: |
Mr. T- The Toshiba scaler is about equal to the one built into the JVC so setting the DVD player at 480p or 720p will result in about the same PQ. 1080i adds a few artifacts and I would not recommend using that setting with the JVC. The biggest gain you get with using the Toshiba DVD player is from the HDMI output. It definitely provides a much cleaner signal than component cables. small lines and text are rock solid, and some DVDs that show a little bit of color banding with component look smoother and sharper with the HDMI. Months ago I posted some pictures of "Finding Nemo" that showed the difference. I'll see if I can dig them up again. David- The recall was more of an "upgrade" according to JVC. It was a small board that was swapped out. It only affected pre-Nov models and the fix was done in about 15 minutes on my set. |
Post Number: 42 Registered: Mar-05
| Posted on Monday, May 16, 2005 - 03:45 pm: |
Thanks Klaus and Mr. L. Mr. L-- I was glad to find that I did notice the difference with the HDMI cable, too. My girlfriend, who thinks I'm goofy when I talk about the different connections and their quality, even admitted she saw the difference. Glad I bought it. And now I don't have to unhook the Gamecube back and forth when I want to watch a movie. Also, we had both agreed that it didn't look quite as good at 1040i and I'm glad to hear it wasn't just us. |
Texas
Post Number: 41 Registered: Jan-05
| Posted on Monday, May 16, 2005 - 05:49 pm: |
Mr. Lynch Can you recommend a place where I can get a high quality HDMIm to HDMIm cable? |
Seattle,
WA
Post Number: 741 Registered: Sep-04
| Posted on Monday, May 16, 2005 - 06:30 pm: |
Dan- My Toshiba DVD player came with a HDMI cable. When moving things around a few weeks ago I damaged my HDMI cable and I replaced it with this one: http://www.buy.com/retail/product.asp?sku=10399698&loc=101&hdwt=22225&sp=1 It is made by Belkin and sold under the name PureAV. Compusa and a few other stores sell it for $99-$120. If you shop online around you can find it around $50-$60. I've had excellent results with it and the quality is right up there with Monster cable, but at 1/2 the price. for HDMI to HDMI 8ft length: Part number av52300-08 4ft length: Part number av52300-04 For DVI to HDMI 8ft length: Part number av52400-08 4ft length: Part number av52400-04
Bronze Member Userna |
