Thread: Mitsubishi HD 1080 |
| Posted on Wednesday, June 08, 2005 - 01:27 pm: |
How do you contact tech support for Mitsubishi? My tv has a bowed picture for the first 5 minutes before it warms up and the picture normalizes. Thanks |
| Posted on Friday, June 10, 2005 - 04:33 pm: |
This forum might be useful: www.electronicsrepair.org or write to: MITSUBISHI DIGITAL ELECTRONICS AMERICA,INC.(MDEA) 9351 Jeronimo Rd. Irvine, CA 92618 info@mitsubishi-tv.com or call 1-800-553-7278 or 1-800-332-2119 or Fax 1-800-825-6655 Or else just post on this forum and ask! xvxvxvx |
Unregistered guest |
| Posted on Tuesday, June 21, 2005 - 10:05 pm: |
hi, we have the same problems with the mistubishi HD 1080 did you have it fixed? the pictures curves and the colors are weird. how much was it o fix it? thanks for your help |
| Posted on Tuesday, June 28, 2005 - 09:07 pm: |
what is the sqv button on the 60' 1080 mit. projection. i hit this button and now my "cable guide" will not work, when i push guide, the picture stutters and does nothing i can not get my cable guide back???thank you!! |
