Thread: Dishnetwrk ppv schedule on web |
| Posted on Tuesday, June 07, 2005 - 08:49 pm: |
this is the sites for the ppv movie and event pages. http://www.ppvorder3.com/events/event_menu.htm (on this site you most likely will have to click on the bottom of the page for movies for that day, the links are confusing, and its hard to find these pages! movies: http://www.ppvorder3.com/movies/Tuesday_Jun_7.html
use the dishnetwork page Unregistered guest |
| Posted on Tuesday, June 07, 2005 - 09:18 pm: |
Better yet use go to the dishnetwork home page and follow the links to order. |
| Posted on Tuesday, June 07, 2005 - 09:19 pm: |
| Posted on Monday, June 13, 2005 - 02:21 pm: |
How do I enter codes on Multistar max.2500 system,do I need to change provider to acctivate codes. I mean they work but only one channel or two then sytem needs re-boot to see 1 or two others. Help.. |
New member Username: Phoenix68
Queen creek ,
Arizona
Usa
Post Number: 3 Registered: Jun-05
| Posted on Tuesday, June 14, 2005 - 04:55 pm: |
I recently installed a pansat 2500a and it's connected to a dishnet antenna with a dual lnb .I am able to received channels from sat 119. Here is my ? .If i connect sat 110 with a diplexer to 119 will i be able to get more channels or will damaged the my receiver.Any help greatly appreciated .New to all this satellie stuff,please be patient.
