Thread: Archive through April 09, 2005 |
| Posted on Sunday, February 27, 2005 - 01:48 pm: |
CAN I USE BOTH SATELLITE 110 AND 119 AT THE SAME TIME ON DISH 3; AND WHAT CAN DO? |
rafael martinez Unregistered guest |
| Posted on Tuesday, March 01, 2005 - 10:55 am: |
can someone said anything? |
| Posted on Tuesday, March 01, 2005 - 05:31 pm: |
3 days ago, my pansat 2500a went out along with 3 of my buddies units.Everyone else in my area is still up.This is a werid problem.Im getting a wait for picture message.The keys in my unit are the same as the ones that are still up.Can anyone please help me.thank u. |
| Posted on Tuesday, March 01, 2005 - 05:35 pm: |
reset it..FTA's are all still working fine...something odd about U and 3 buds.. |
| Posted on Tuesday, March 01, 2005 - 05:55 pm: |
i have an oval dish 3 but i am only getting 110, i moved the dish L & R to get the 119, do not work. is it a problem with my dish? |
| Posted on Tuesday, March 01, 2005 - 06:49 pm: |
http://forum.ecoustics.com/bbs/messages/2/125186.html |
New member Username: Frankqd
Waxahachie,
Tx
Usa
Post Number: 2 Registered: Feb-05
| Posted on Wednesday, March 02, 2005 - 09:53 am: |
how long is this stuff going to last |
a guy xbbbb Unregistered guest |
| Posted on Friday, March 04, 2005 - 02:16 am: |
how do you make the pansat 2500a to work? i tried everything and couldnt get it to to work. |
| Posted on Friday, March 04, 2005 - 08:57 pm: |
can anybody tell the input key? |
| Posted on Friday, March 04, 2005 - 09:22 pm: |
input key?...where are U reading that?..U mean the flash/bin?...here's the parity keys for Dish and Bev,but ...U talking about FTA?...pansat? Current BEV Keys AUX0 is active, changed Tue Nov 18 20:00:00 2003 AUX0: 82 D7 51 E4 5B 97 9D 81 AUX1: 65 57 46 14 36 02 D8 DA Current Dish Keys KEY1 is active, changed Thu Dec 2 12:52:34 2004 KEY0: 06 07 F0 E2 61 6F E1 45 KEY1: 01 C5 FB 21 37 B6 C0 5E
| Posted on Friday, March 04, 2005 - 09:30 pm: |
Here....copied and pasted from above in this thread...do some reading.. ................................................ Anonymous Posted on Monday, December 06, 2004 - 06:42 pm: -------------------------------------------------------------------------------- For those who has "input data" it means you have to change your Key data in 01 which have been changed. bryon holt New member Username: Bh4478 Post Number: 4 Registered: Dec-04 Posted on Monday, December 06, 2004 - 07:00 pm: -------------------------------------------------------------------------------- what model do i enter james millard Silver Member Username: Jmill1948 chester , va usa Post Number: 404 Registered: Apr-04 Posted on Monday, December 06, 2004 - 07:31 pm: -------------------------------------------------------------------------------- try key:global
| Posted on Friday, March 04, 2005 - 09:46 pm: |
lk. can u please explain that to me? |
New member Username: Ltk2000
Post Number: 1 Registered: Mar-05
| Posted on Friday, March 04, 2005 - 09:51 pm: |
Hi, I have a pansat 2500a. I have it install and have signal but no picture...Can anyone please help....... |
| Posted on Friday, March 04, 2005 - 10:17 pm: |
what do mean by key global i need more inf. |
| Posted on Friday, March 04, 2005 - 10:40 pm: |
LK. can u please help me. my receiver's saiying (please imput keys.) please explain that to me |
| Posted on Saturday, March 05, 2005 - 12:30 am: |
type in ...key:global....at STB model box |
| Posted on Saturday, March 05, 2005 - 12:50 am: |
download and watch the video here.. http://www.dss-jmvip3mfiles.com/Download%20Files.htm
| Posted on Saturday, March 05, 2005 - 10:02 am: |
-------------------------------------------------------------------------------- Instructions: If you have never flashed before, make sure you have a STRAIGHT THROUGH serial cable. A standard crossover cable WILL NOT WORK. Also note that some computers and laptops have misconfigured or sub-standard serial ports and may not work properly. Also, many USB to serial adaptors have been known to cause issues. 1. Connect your receiver to your PC with the serial cable female to female. 2. Load up the "GTRom STB Updater" software. 3. Select the correct Serial Port for your system and leave Baud at 115200. For STB Model enter "Pansat 2500A" exactly, without the quotes. If this doesn't work, some users have also had success with "key:global". Under Bin File select your recently downloaded fix. 4. Hit "Download" and wait for your STB to be updated. Note that you must wait for the message "Download Complete", at which point your receiver will reboot. DO NOT STOP UPDATING OR DISCONNECT YOUR CABLE WHEN IT REACHES "100%" - WAIT FOR THE "DOWNLOAD COMPLETE" MESSAGE! 5. Now, load up GTools. You must use version 1.85, not version 1.81 or earlier. Due to menu corruption, Windows 98 users should download the special Win98 version which allows the STB type to be customized via a mouse right-click menu. 6. Open your channel list and make sure that only the satellites you are receiving are selected. This is not a guide on how to use GTools, so I'm going to A$$ume that you know what you're doing here - otherwise check other threads for instructions. 7. Go to OPTION -> STB SETTING (or, for the Win98 version, right click and go to TOOLS -> STB TYPE) and set it to Type2. (Yes, Pansat STBs used to use Type1, but this update needs Type2.) Unless you have a 2300 model then you use Type 1 and also for model 1500 you need to use Type 2 on your channel list. 8. Go to TOOLS -> STB CONNECT (Win98 users will find this via a right-click menu). 9 Select your COM port like you did earlier, then click the Download button. 10. Wait for the download to complete, like earlier, and your STB to reboot. 11. Connect receiver and make sure to get right signal quality by going to menu, follow the on screen instructions then go to Parental Control. 12. Scroll down to the very bottom line and enter "0" four times. This will lead to a new menu. 13. Scroll down to the "Set Default Key" line and press OK. 14. You'll see a message about waiting for settings to save, after which you can leave the Setup Menu. 15. Start watching TV! These steps worked perfectly for me. So if they didn't work for you... 1. Are your satellites set up correctly in the setup menu? Also check your DiSeqC settings. 2. Is your channel list good/recent enough? 3. Have you tried manually scanning for channels? 4. Do you have a DishPRO LNB/dish? Download a channel list designed specifically for it. 5. Has the setup worked before? If not, double and triple check your satellite dish's alignment. Are your LNBs leading into the DiSeqC port you thought they were? Is your dish aimed at the satellite you thought it was? Remember that the STB has no idea what satellite you're aimed at and will give you readings even if you're aimed at the wrong one. If you can't get any channels or are having odd transponder problems, it could very well be your dish's alignment. Is the signal strength strong enough? 6. If you can't edit the channel list or access parental controls, you likely downloaded a channel list as STB Type1. Download it again as Type2. 7. Something else could be wrong, like your switch, dish, LNB, cabling, and so on. 8. Note that you do NOT have to flash back to the factory image before applying this fix (but if you end up having problems with Knight Rider lights please see below) and you do NOT have to edit any keys before pressing "Set Default Keys". 9. It is completely normal to have a "Bad or scrambled channel" message pop up briefly now and again while watching television. Getting "Knight Rider" flashing lights after flashing? 1. Go to www.pansatusa.com and download the factory firmware image, then flash it to your STB via the instructions above. Afterwards, try loading the fix again. 2. Try powering your STB off and on before flashing. 3. Always, always wait for the "Download Complete" message when flashing. 4. If it just won't work, try flashing from a different computer - especially if you're using a USB to Serial adaptor or a laptop |
| Posted on Monday, March 07, 2005 - 12:30 am: |
I'm able to wach ECHO119 channels, but how can I configure my Pansat2500a to recieve ECHO110 cannels? PLZ HELP!!! |
| Posted on Tuesday, March 08, 2005 - 05:43 pm: |
I have a Panset 2500 A I need the new key code numbers other than 01 C5 FB 21 37 B6 Co 5E |
| Posted on Tuesday, March 08, 2005 - 05:57 pm: |
there are none other that those...if U mean "input key"...key:global |
| Posted on Tuesday, March 08, 2005 - 05:59 pm: |
Does anyone have the current dish keys for key 01 pansat? Please help |
| Posted on Tuesday, March 08, 2005 - 06:04 pm: |
Yes "input key".... key:global if there are no new input keys I am getting go signal strength but no pictures. saying bad or scrambled on all 110, 119 & 91 |
flygrl50 Unregistered guest |
| Posted on Tuesday, March 08, 2005 - 06:14 pm: |
im new to this, on the pansat 2500a where would you put the code. i have a code for the fortec |
| Posted on Tuesday, March 08, 2005 - 06:17 pm: |
Tuesday, March 8 2005 KEY00 CHANGE How to fix: press menu go down to parental controlls, and press ok press down arrow and enter 0000 thats 4 zeros now go down to nagravision and press ok now press the right side arrow next to the ok button 11 times untill it sais dish network now press the down arrow 1 time key number should read 00 now now press the down arrow 1 time using the buttons on the remote (number buttons, To type the letters into the new keydata, press the appropriate button on your remote: Audio = A, Info = B, Signal = C, Pause = D, Sat = E, EPG = F) set the key to 8A C4 96 93 EC 79 9D 57 now press the ok button! then press exit to exit the menu This is how to change your public keys when needed, these instructions should work for both 2300 and 2500 pansats.
| Posted on Tuesday, March 08, 2005 - 06:28 pm: |
Got it, Thanks LK |
| Posted on Tuesday, March 08, 2005 - 06:29 pm: |
Got it, Thanks LK |
| Posted on Tuesday, March 08, 2005 - 06:31 pm: |
Got it, Thanks LK |
| Posted on Tuesday, March 08, 2005 - 07:00 pm: |
It worked, Thanks A Whole Bunch LK!!!!!!!!!!!!!!!!!! |
mysticat Unregistered guest |
| Posted on Tuesday, March 08, 2005 - 07:26 pm: |
Thank you,thank you,thank you.If there are more people like you the World would be a better place :-)) |
| Posted on Tuesday, March 08, 2005 - 07:46 pm: |
had my pansat2500 working for about aweek now saids need input keys |
| Posted on Tuesday, March 08, 2005 - 08:21 pm: |
-------------------------------------------------------------------------------- Tuesday, March 8 2005 KEY00 CHANGE How to fix: press menu go down to parental controls, and press OK press down arrow and enter 0000 thats 4 zeros now go down to nagravision and press ok now press the right side arrow next to the ok button 11 times until it says dish network now press the down arrow 1 time key number should read 00 now now press the down arrow 1 time using the buttons on the remote (number buttons, To type the letters into the new keydata, press the appropriate button on your remote: Audio = A, Info = B, Signal = C, Pause = D, Sat = E, EPG = F) set the key to 8A C4 96 93 EC 79 9D 57 now press the ok button! then press exit to exit the menu This is how to change your public keys when needed, these instructions should work for both 2300 and 2500 pansats. |
| Posted on Tuesday, March 08, 2005 - 11:21 pm: |
i did da do you see but my 2500 doesn't work i need you help lk |
| Posted on Tuesday, March 08, 2005 - 11:29 pm: |
it works for the rest of the world... |
| Posted on Tuesday, March 08, 2005 - 11:33 pm: |
rafael podrias explicarlo pues mi pansat tiene la misma señal y hice lo que dice lk y no funciono por (FAVOR) |
| Posted on Tuesday, March 08, 2005 - 11:38 pm: |
| Posted on Wednesday, March 09, 2005 - 10:22 am: |
LK need help ..the set key above is not working for me neither |
| Posted on Wednesday, March 09, 2005 - 10:56 am: |
If I added a second fta stb. to my existing dish500 would it work just by putting on a splitter at the end of rg6 cable or would there be a conflict between the 2. I would assume if one stb.is running at a time there would be no conflict but I beleive I read somewhere that it will work without conflict. Any thoughts? Thanks |
| Posted on Wednesday, March 09, 2005 - 11:07 am: |
the new keys correctly installed DO work..unless U have other issues and your pansat didn't work prior to 2 days ago.. |
| Posted on Wednesday, March 09, 2005 - 04:39 pm: |
i did againg and noww is working thank youuu lk |
| Posted on Wednesday, March 09, 2005 - 05:14 pm: |
I have a pansat 2500a .I am not able to get pass the password to be able to set parental controls. How do you reset to basic factory controls. Can anyone help? |
Chantal Unregistered guest |
| Posted on Wednesday, March 09, 2005 - 08:59 pm: |
the new keys correctly installed , it's working in the kitchen. but in my room still don't work. The message, no signal. I think I have another problem. What could it be? |
| Posted on Wednesday, March 09, 2005 - 09:02 pm: |
| Posted on Saturday, March 12, 2005 - 03:23 pm: |
Forum" means a chat area, message board, bulletin board (bbs), or e-mail function offered as part of any eCoustics.com Site. If you participate in any Forum within an eCoustics.com site, you MUST NOT: defame, abuse, harass or threaten others; make any bigoted, hateful or racially offensive statements; advocate illegal activity or discuss illegal activities with the intent to commit them; post or distribute any material that infringes and/or violates any right of a third party or any law; post or distribute any vulgar, obscene, discourteous or indecent language or images; advertise or sell to, or solicit others; use the Forum for commercial purposes of any kind; post or distribute any software or other materials which contain a virus or other harmful component; or post material or make statements that do not generally pertain to the designated topic or theme of any chat room or bulletin board.
LocoVato Unregistered guest |
| Posted on Tuesday, March 15, 2005 - 09:29 pm: |
Key: FO C9 59 D8 7F 8D 34 13 |
New member Username: Papastratos
| Posted on Tuesday, March 15, 2005 - 10:18 pm: |
if i want to get 119 west and Intelsat Americas 5 at 97.0°W the same time from montreal what kind dish and LNBF i should get for the pansat 2500A. HELP !!! thank you |
loopthis Unregistered guest |
| Posted on Tuesday, March 15, 2005 - 10:56 pm: |
We were dealing with 2 keys LocoVato - 00 and 01 which key did you post ? and does the other key remain the same ? Thanks |
| Posted on Tuesday, March 15, 2005 - 11:40 pm: |
Please Help, I am not able to store the new key data for the March 15 crack. When I entered the new key data, and then pressed ok for several times to save the new entered key data, and then exit, but nothing was saved. The old key data still there. Thank you in advance |
| Posted on Wednesday, March 16, 2005 - 02:56 pm: |
Help, under installation and selected satellite is comes up with like a full slate of 'new' satellites and since it is full it won't let me add my echo's.....any hints? I've tried new files and I get the same thing...should I reset to factory default? |
New member Username: Zeemak
Post Number: 5 Registered: Jan-05
| Posted on Thursday, March 17, 2005 - 05:41 pm: |
Need New Key for March 17th, Please help |
Post Number: 2 Registered: Mar-05
| Posted on Thursday, March 17, 2005 - 10:58 pm: |
Anybody knows how to revive a dead Pansat? No image, no lights on, strange noise. I tried to switch on/off , nothing. Thanks. |
WinnipegAtHome.com Unregistered guest |
| Posted on Friday, March 18, 2005 - 12:07 am: |
Here are the Keys for March 17th. KEY1 0B 51 9E B7 EB 20 E7 4D (active) Enjoy  |
| Posted on Friday, March 18, 2005 - 05:07 pm: |
IS THERE A PROGRAM THAT U CAN PUT IN A PANSAT 2500A THAT WILL PUT IN THE NEW KEY NUMBERS WITH OUT YOU HAVING TO UP DATE IT EVERY TIME. |
| Posted on Friday, March 18, 2005 - 05:46 pm: |
@papastratos Have you plugged it in to an outlet? |
| Posted on Friday, March 18, 2005 - 06:51 pm: |
Are the keys for March 17th valid 'till today? |
New member Username: Winnipeg
Winnipeg,
Manitoba
| Posted on Friday, March 18, 2005 - 07:33 pm: |
The keys posted March 17th are good till the next time Dish Network goes down. |
don't know Unregistered guest |
| Posted on Friday, March 18, 2005 - 09:31 pm: |
Can anyone help me I am NOT able to go to parental control and channel edit on the main menu it doesn't light up. I am able to get to installation then it skip parental control and channel edit. It goes to user setup, factory setting and system information. How can I get parental control and channel edit back to the main menu. The front panel of receiver shows 0o. Thanks in advance |
New member Username: Caly
Post Number: 8 Registered: Mar-05
| Posted on Saturday, March 19, 2005 - 01:11 pm: |
hello i would wanna know some info about how the pansat 2500A works - for example when u buy it does it have auto roll ? does it have the software installed ? anyone wanna help me tnx if u wanna chat contact me on messenger at calin_olariu2001@yahoo.com or calin_olariu2001@hotmail.com ok i am gonna wait for somebody to answer me |
| Posted on Saturday, March 19, 2005 - 02:19 pm: |
WAS THE KEY CHANGED TODAY AGAIN? i IMPUTED LATEST KEY THIS MORNING (03/19/2005, WHATCHED 4 A WILE, TURNED IT OFF, CAME BACK 20 MIN. LATER....NOTHING SAYS SCRAMBLE OR BAD CHANNEL- ANYONE CAN HELP? |
| Posted on Saturday, March 19, 2005 - 02:24 pm: |
READ the REPUTABLE DSS SITES thread/topic in these forums...then CONTACT the sponsors/advertisers there and ask them..some Dss sites sell pre programmed/some don't..VERY SIMPLE!...and its posted everywhere here.. BTW ...most don't sell preprogrammed...and much cheaper to buy NOT programmed...and VERY SIMPLE to program...BUT U would know that if U had READ for a few minutes at any DSS site.. Also NOBODY is going to email U,U must GO out and SEARCH for the answers...only scammers will come to U! |
squeakety Unregistered guest |
| Posted on Saturday, March 19, 2005 - 09:28 pm: |
Help please! I used the new blacklist downloader and flashed my pansat 2500a with the pansat 2500a knightrider fix, which included three files. One was a boot file. I flashed all three files. Now, my receiver doesn't show anything on the front display. No image on tv. How can I reset the pansat 2500a to its original boot. |
| Posted on Saturday, March 19, 2005 - 09:29 pm: |
Help please! I used the new blacklist downloader and flashed my pansat 2500a with the pansat 2500a knightrider fix, which included three files. One was a boot file. I flashed all three files. Now, my receiver doesn't show anything on the front display. No image on tv. How can I reset the pansat 2500a to its original boot? |
| Posted on Saturday, March 19, 2005 - 09:34 pm: |
| Posted on Saturday, March 19, 2005 - 09:55 pm: |
First reset the receiver...power switch on BACK OFF,unplug,wait 1 minute,plug back in,Power on Back of receiver turn back ON..now flash back to original factory 222 bin..also read this link ..then bookmark (favorites) the page http://forums.al7bar.tk/forumdisplay.php?f=30 |
| Posted on Saturday, March 19, 2005 - 10:37 pm: |
| Posted on Saturday, March 19, 2005 - 10:40 pm: |
squeaky...put down the crack pipe...look above your last post...I answered U 45 minutes ago.. |
| Posted on Saturday, March 19, 2005 - 11:07 pm: |
| Posted on Saturday, March 19, 2005 - 11:26 pm: |
LK DO YOU KNOW THE NEW KEY FOR TODAY? CAN YOU TELLME PLEASES |
| Posted on Saturday, March 19, 2005 - 11:33 pm: |
How to flash..and fix problems link.. http://forums.al7bar.tk/showthread.php?t=20310 As of 2 hours ago I have not heard of any new keys change today..were still same keys since the last change 3-17 which are posted everywhere here.. |
| Posted on Saturday, March 19, 2005 - 11:38 pm: |
here's the setup manuals for pansat..fortec etc.. http://forums.al7bar.tk/showthread.php?t=38188 and this link will answer almost any problem...just need to do some reading.. http://forums.al7bar.tk/forumdisplay.php?f=30 |
Bronze Member Username: Allic
Post Number: 76 Registered: Jan-05
| Posted on Saturday, March 19, 2005 - 11:43 pm: |
what a looser ya cant link like that yur links dont work unless your logged in MORON |
| Posted on Saturday, March 19, 2005 - 11:52 pm: |
Gordo..no ship...U're a real brain surgeon!...thats obvious U have to be logged in!...did your parents have any kids that weren't brain damaged?..U are so intelligent!....LOL |
| Posted on Saturday, March 19, 2005 - 11:55 pm: |
Gordo..no ship...U're a real brain surgeon!...thats obvious U have to be logged in!..(just register and check off "stay logged in always"...its no biggie)....did your parents have any kids that weren't brain damaged?..U are so intelligent!....LOL |
LK'S_MOM Unregistered guest |
| Posted on Sunday, March 20, 2005 - 12:04 am: |
I tried to raise him right but he was a liar from the day he could talk.. but i own a sat and no that there going to make you pay soon these ones will always be free ALLWAYS FREE |
| Posted on Sunday, March 20, 2005 - 03:06 am: |
lost my bell/vu adult channels on my pansat 2500. can anyone please help? |
New member Username: Any
| Posted on Sunday, March 20, 2005 - 11:04 am: |
i need the new key for Pasant 2500A. Can somebody help me? |
| Posted on Sunday, March 20, 2005 - 11:36 am: |
Bev adult channels are now Nagra2 (gone for you)..unless U subscribe The latest Keys are posted 1000x places here now...READ...LOOK |
| Posted on Sunday, March 20, 2005 - 12:12 pm: |
Pansat down. I need a new key. Thanks so much. |
Post Number: 3 Registered: Mar-05
| Posted on Sunday, March 20, 2005 - 12:34 pm: |
i can't find the ney key. where is it? i didnt wath TV since yesterday help me!!!!!!!! |
| Posted on Sunday, March 20, 2005 - 12:50 pm: |
Any. Si encuentras la llave, mucho te voy a agradecer que me la envíes. Saludos...Chodo |
| Posted on Sunday, March 20, 2005 - 01:49 pm: |
Trusted Public News and Forum Links -= Royce's site - Dishnewsonline =- Main News Site - Dishnewsonline.tv Forums - Dishnewschats.com -= Al7bar.t*k =- Main page & forum - Al7bar.t*k -= KickinChicken =- Main page - kickinchicken.org(.info) Forums - kickinchicken.org(.info) -= Dss-Newbies =- Main page - dss-newbies.net Forums - dss-newbies.net -= Dishnewbies =- Main page - dishnewbies.com Forums - dishnewbies.com -= DssCentral =- Main site - dsscentral.ne*t Sister site - dsscommunity.com -= CTG - ConcernedTestersGroup =- Main Site - concernedtestersgroup.info Forums - concernedtestersgroup.info -= hashHU =- Main page - hashHU.com Forums - hashHU.com -= DssWord =- Main page - dssword.com Forums - dssword.com -= Maestra.tv =- Main page - Maestra.tv Forums - Maestra.tv
New member Username: Rasht
| Posted on Sunday, March 20, 2005 - 02:44 pm: |
how do i switch between 119 and 110 and what the hell do they each repersent? i want to switch from dish net to bell express |
New member Username: Jiza88
La,
Ca
Us
| Posted on Sunday, March 20, 2005 - 06:16 pm: |
can i use the same bin file for fortec and pan sat |
| Posted on Sunday, March 20, 2005 - 06:48 pm: |
Latest keys 3-17 are posted here everywhere...LOOK Paul...those are Dishnetwork satellites 110-119,and if U want to switch then realign your roof dish to the correct BEV satellites 82-91 David...different files for each |
| Posted on Tuesday, March 22, 2005 - 05:32 pm: |
We just bought Pansat2500A. We followed the instruction and installed flashpansat2500a, , set the STB model as Pansat 2500A, select the latest bin Blacklist-x-85BL_041106_237_api(n).bin. Downloaded the latest channel file called DISH PRO-110-119 with NFL.gtd. Now the biggest problem we have is we can not select Parental Control! The menu button is grayed out!Can anyone help? We also saw the level goes up 90%, but the quality is still zero. Appreciated for the help in advance!!! |
New member Username: Psych
| Posted on Wednesday, March 23, 2005 - 04:29 am: |
Hi, I have a pansat 2500A, and I have the key for 3-17-05 installed, but it is still asking for the key info. Is there another key code that has not been posted, and if so where else could I go that might have it? I just got this receiver within the last two months, am I suppose to do this flashing bit???? Thanks in advance, and God do I hope you can help me. |
| Posted on Wednesday, March 23, 2005 - 07:53 am: |
http://www.dsscentral.ne*t/cgi-bin/hubblegram/CSUpload.cgi?command=viewupload&database=files%2edb Remove the * from the .ne*t link above..copy/paste it into your browser...the link is the latest files and keys.. |
| Posted on Friday, April 01, 2005 - 10:42 am: |
lost bell/vu adults channels pansat 2500 help please |
New member Username: Forest
Bay st louis,
Ms
Usa
Post Number: 2 Registered: Nov-04
| Posted on Saturday, April 02, 2005 - 07:18 pm: |
Somehow I lost signal to my second receiver-the second receiver is fed from the IF output of the first receiver-all cables are okay. Is there anything in programming I messed up? The first receiver works fine-help, please. |
| Posted on Saturday, April 02, 2005 - 07:20 pm: |
Anyone have the new keys? |
Bay st louis,
Ms
Usa
Post Number: 3 Registered: Nov-04
| Posted on Saturday, April 02, 2005 - 07:54 pm: |
MylkyD Go to www.maestra.tv/keys/ to get new keys |
Bay st louis,
Ms
Usa
Post Number: 4 Registered: Nov-04
| Posted on Saturday, April 02, 2005 - 07:55 pm: |
Silver Member Username: Knee_grows_back
Post Number: 219 Registered: Jan-05
| Posted on Saturday, April 02, 2005 - 08:21 pm: |
why go there...looks like a mickey mouse site....the lazy cunte could of got the keys off of this site...all he had to do was look around, Some people are so fcuking lazy it's not even funny... |
| Posted on Saturday, April 02, 2005 - 08:53 pm: |
can some one please help me>>> i know i have to change the physical angle of the dish to get BEV but which way? and do i have to change anything in the receiver its self? thanks |
Post Number: 4 Registered: Mar-05
| Posted on Saturday, April 02, 2005 - 08:55 pm: |
sorry i forgot to mension i have a 2500A pansat |
Bay st louis,
Ms
Usa
Post Number: 5 Registered: Nov-04
| Posted on Saturday, April 02, 2005 - 09:58 pm: |
Funny you should say mickey mouse site - My boss makes me drive a car that mickey mouse would drive. Yeah some people don't like to do their homework, or any work at all. Still trying to figure out why my if output isn't outputing. I'll get it eventually. |
| Posted on Saturday, April 09, 2005 - 04:31 pm: |
can anyone tell which channel is the yes network |
lazywife Unregistered guest |
| Posted on Saturday, April 09, 2005 - 05:40 pm: |
i need help i got new keys but now i get no signal message what do i do please help !!! |
| Posted on Saturday, April 09, 2005 - 08:36 pm: |
how is your level and quality, lazywife |
Post Number: 428 Registered: Jan-05
| Posted on Saturday, April 09, 2005 - 11:10 pm: |
her level is horizontal and quaility is poor...I had to get out the KY jelly.....LOL |
