Thread: Panasonic DMR ES10 |
New member Username: Nikkiparker
Post Number: 1 Registered: Jun-05
| Posted on Sunday, June 05, 2005 - 11:18 am: |
Can anyone help me and let me know how to unlock the above player. I have just purchased and my daughter is going nuts as it won't play any of our Region 1 Disks!!! |
New member Username: Phil1919
DC
Post Number: 2 Registered: Jun-05
| Posted on Wednesday, June 29, 2005 - 12:27 pm: |
I can't help you on this, but question.. I just bought this recorder 2 days ago, sitting in the box still. How do u like it?? |
Bronze Member Username: Retiredjetp
Post Number: 13 Registered: Dec-04
| Posted on Wednesday, June 29, 2005 - 05:04 pm: |
Phillip, I just bought one, I can't get it to record to DVD-RW disks. After about an hour or so it stops and says an error has occurred. Chuck |
| Posted on Thursday, June 30, 2005 - 05:24 am: |
Hi Phillip, I am finding it great - very user friendly. I have plugged my old Sony back in for the time being to get round the region 1 business, but hopefully I will be able to unlock it in time. Nikki |
Post Number: 3 Registered: Jun-05
| Posted on Thursday, June 30, 2005 - 05:25 am: |
Hi Chuck, I have been using DVD-RW discs with no problems, so can't help you I'm afraid. Nikki |
Post Number: 14 Registered: Dec-04
| Posted on Thursday, June 30, 2005 - 08:04 am: |
Nikki What brand of DVD-RW disk are you using ? Chuck |
Post Number: 4 Registered: Jun-05
| Posted on Thursday, June 30, 2005 - 08:10 am: |
Hi Chuck, I will check when I get home tonight, it was a pack I was given by the store when I bought the recorder. I know that the RAM disks which I am using are Panasonic's own, which I have alo found completely reliable. Nikki |
Post Number: 15 Registered: Dec-04
| Posted on Friday, July 01, 2005 - 07:21 pm: |
I tried a different brand of dvd-rw disk and they work just great. Evidently Fuji dvd-rw disk just aren't compatible with this Panasonic recorder. |
