Home > Message Board > Home Video > Projectors > Archive through October 31, 2005 > Plug a Cable wire into a projector?
Author Thread: Plug a Cable wire into a projector?
jdsneedshelp
Is ther any way to take your standard cable wire and plug it into a projector without going through a cable box? For example, take my cable wire from my wall, plug it into so kind of wire converter which would convert the wire to an S-video wire? I know you can get a converter wire to go from s-video to rca plugs, but can you get a cable wire to go to s-video or rca or anything that i can just plug into my infocus X2? thanks
hiudfsohay
i was wondering the same thing, i guess lack of responses means that its not possible???
Username: Ziggyzoggyoioi
Outside Philadelphia, PA
Post Number: 111
They sell Coax Type F (cable standard) to RCA video converters at Home Depot for $1.99 each. I just bought some last week.
But unless your projector has a tuner, you won't be able to switch channels without using a box somewhere.
Home > Message Board > Home Video > Projectors > Archive through October 31, 2005 > Plug a Cable wire into a projector? [ « Previous ] [ Next » ]
