Thread: NEW KEY |
New member Username: Alimtl
Post Number: 1 Registered: May-05
| Posted on Wednesday, May 18, 2005 - 06:38 pm: |
Hello every one , Does anyone have a new key ? Thanks a lot . |
| Posted on Wednesday, May 18, 2005 - 07:13 pm: |
KEY0 E3 9C F7 66 22 11 48 B7 Active KEY1 02 4D 58 19 8C 3A C5 C4 18-05-05 18:55:49
| Posted on Wednesday, May 18, 2005 - 07:50 pm: |
Get the keys yourself....www.maestra.tv/keys better yet,get the keymaster or getkeys file and NEVER have to ask again or search for the new keys..or best install the AUTOROLL bin which will automatically find the new keys and install them for you!..this is much better for you,than me just posting the keys...U become self independent this way..no need to rely on anyone else.. |
| Posted on Wednesday, May 18, 2005 - 07:57 pm: |
that key is not working for me, turned off reciever couple of times, unplugged it etc, /shrug |
| Posted on Wednesday, May 18, 2005 - 08:07 pm: |
everytime I hit ok and the store flashes and acts like its gonna work, the first 2 sets of numbers switch when I hit exit to go back and watch the satellite. E3 and 9C swap, and the key reads 9C E3........... instead of the proper way. |
| Posted on Sunday, May 22, 2005 - 05:11 pm: |
these are the latest firmware X-75BL_050314_236cE_api------for pansat 2300A X-85BL_050405_246_api----------for pansat 2500A X-85BL2_050330_245_api--------for pansat 1500A X-87BL_050519_105_api----------for pansat 2700A X-95BL_3033_2005_0425_api--for pansat 5000HC they all autoroll. and the 2700a has a working (epg)!
jokercast Unregistered guest |
| Posted on Sunday, May 22, 2005 - 08:01 pm: |
does anyone have keys for pansat 2500?? ?? |
| Posted on Sunday, May 22, 2005 - 08:02 pm: |
gato3patas Unregistered guest |
| Posted on Sunday, May 22, 2005 - 08:21 pm: |
from now on the keys will only be posted here http://forum.ecoustics.com/bbs/messages/2/129815.html never forget this and pass it on to your loved ones |
| Posted on Sunday, May 22, 2005 - 08:59 pm: |
pansat needs no keys |
| Posted on Sunday, May 22, 2005 - 09:58 pm: |
not if you got autoroll |
| Posted on Sunday, May 22, 2005 - 10:07 pm: |
f..u..c,,k you ..)))p((( |
steven roles Unregistered guest |
| Posted on Friday, June 10, 2005 - 11:18 pm: |
autoroll doesn't work now. do we have to download a new software? where to get it? please let everybody know. thanks |
| Posted on Saturday, June 11, 2005 - 12:07 am: |
There are new keys for tonight that U must input manually,then do a reset.....Dishnet has targeted and ECM'd autoroll bins and plastic cards with blockers....new autoroll bins are being worked on now and released ASAP..can still use autorolls,but they are targets and will have to manually change keys when they change.. |
Cosme Diaz Unregistered guest |
| Posted on Saturday, June 11, 2005 - 12:24 am: |
LK.....when you say autorolls are targets....do you mean its better not to use them for a while? |
| Posted on Saturday, June 11, 2005 - 12:33 am: |
it means they don't roll anymore and Dish is changing keys almost everyday..so do what U want.. |
| Posted on Saturday, June 11, 2005 - 12:48 am: |
damn dicknet they makin it so harder |
UNKNOWN GUY Unregistered guest |
| Posted on Saturday, June 11, 2005 - 01:03 pm: |
IF YOUR AUTOROLL FREEZES REPROGRAM YOUR BOX AND TYPE IN THESE KEYS!0.027EA99BE507A0EA |
| Posted on Saturday, June 11, 2005 - 06:47 pm: |
hi, i'm using My Theater, and fenrir plugin to get keys from dish network, it simply stop working a day ago, i don't understand what you are saying but i think it has to do with my problem, what do i have to do? in my plugins folder i have this files: Directory of E:\Program Files\MyTheatre\MDplugins 06/11/2005 03:39 PM <dir> . 06/11/2005 03:39 PM <dir> .. 11/13/2003 08:18 PM 33,204 Caid1800.dll 06/11/2005 03:18 PM 107 ci.txt 06/29/2003 05:36 AM 620 conax.kid.example 11/09/2003 10:45 AM 9,907 fenrir-readme.txt 11/08/2003 09:28 PM 356,352 Fenrir.dll 12/01/2004 03:20 PM 123 fenrir.ini 06/11/2005 03:35 PM 66,804 fenrir.log 07/27/2003 07:41 AM 106 fenrir.reg 06/29/2003 06:32 AM 5,551 FenrirSDK.zip 10/22/2003 06:28 AM 29,168 Ird-beta.kid 12/03/2001 10:26 PM 350 Ird-Beta.prv 06/10/2005 06:17 PM <dir> nagra 06/11/2005 03:18 PM 284 Nagra.key 06/11/2005 03:39 PM 0 p.txt 10/18/2003 12:06 PM 8,326 Seca.KID 01/30/2001 07:12 AM 684 Seca.prv 12/04/2004 08:28 AM 2,101 SoftCam.key 06/11/2005 03:35 PM 685 SoftCam.key.used 10/18/2003 12:06 PM 1,481 viaccess.KID 06/26/2004 07:48 AM 532,480 Yankse.dll 06/11/2005 03:20 PM 262 yankse.ini 09/02/2004 08:58 AM 4,965 yankse.prv 21 File(s) 1,053,560 bytes thanx! |
Silver Member Username: Jmill1948
Chester,
Va
Usa
Post Number: 675 Registered: Apr-04
| Posted on Saturday, June 11, 2005 - 07:05 pm: |
new autoroll out and works |
| Posted on Saturday, June 11, 2005 - 07:52 pm: |
how do i put new keys in for my coolsat4000 pro. i just go the receiver 2 days ago. i'm a newbie. i used the thedssguy instructions and flashed the receiver, also loaded softcamamerica.key, and also loaded the channel ndf file. i'm getting "scramble channel" message watching anything on dishnet 110. |
| Posted on Saturday, June 11, 2005 - 07:56 pm: |
My fenrir autorolling of keys has stopped working as well....any answers? |
| Posted on Saturday, June 11, 2005 - 07:59 pm: |
LOAD CORRECTLY the new 6-09 co*olsat autoroll and watch TV...don't need to input keys manually!...your choice! |
| Posted on Saturday, June 11, 2005 - 08:14 pm: |
LK, i loaded the new 06-09 cool*sat autoroll from dsscentral(dot)net but still getting "scramble channel" on all channels. I can't even watch MTV. I'm so desperate! That's why I want to see if manually entering the keys would help. |
| Posted on Saturday, June 11, 2005 - 08:28 pm: |
reset the receiver...power off,wait 2 minutes,power on...or unplug for a few..or U did something wrong! |
| Posted on Saturday, June 11, 2005 - 08:30 pm: |
is it because i shouldn't load the softcamamerica.key? i loaded this key is that why everything is scrambled? eventhough after i installed the cool*sat 06-09 autoroll/epg? also, can someone show me how to enter keys manuall? thank you so much and have a wonderful weekend. |
| Posted on Saturday, June 11, 2005 - 08:37 pm: |
have a4000 pro is been dead since thursday anybody know what happened. |
| Posted on Saturday, June 11, 2005 - 08:46 pm: |
LK, please help. I'm waiting for your answer to get rid of this "scramble channel" message. this happens on both 110 and 119. i'm sure it happens to a lot of you out there before. Can you please help me? |
| Posted on Sunday, June 12, 2005 - 01:23 pm: |
the autoroll don't work. so you need to imput the key manually. after that happen it should work. get the key at www.maestra.tv/keys |
| Posted on Sunday, June 12, 2005 - 01:40 pm: |
The coo*sat autoroll 6-9 DOES work very well,in fact...yes leave the softcamerica out when loading.... |
| Posted on Sunday, June 12, 2005 - 01:48 pm: |
using stbtool i download COOLSAT4000_125_20050609.stb then i click on channels tab and download !!DS(dish order - ac3 & epg) for NDP-05292005.ndf after each, stbtool says version 1.25 detected i go into dish setup, correct the diseq setting for my system, then scan the 3 sattelites. i am getting guide info,and all works great. softcamamerica is for the factory flash,if U read any of the guides.. |
New member Username: Ciciban
Post Number: 1 Registered: Jun-05
| Posted on Monday, June 13, 2005 - 04:56 am: |
I am watching the satellite programs on my computer but the best are scrambled,can you help me? |
