Thread: Can only get 15 channels |
New member Username: Cpg
Post Number: 1 Registered: Mar-04
| Posted on Thursday, March 04, 2004 - 08:18 pm: |
I have an old Magnavox VCR. I haven't used it for a couple of years. It was in storage but now that I've hooked it up again, I can only get 15 channels. Everything above that, which is only a few more, is local stuff that you get without cable. My brother-in-law said something about the possibility that some broadcasting standard has changed since I stopped using the unit and now it won't work with the new standard. Has anyone every heard of that? Any other ideas as to what might be going on and how to fix it? I'm sure it's hooked up properly. |
Bronze Member Username: John_s
Columbus,
Ohio
US
Post Number: 11 Registered: Feb-04
| Posted on Thursday, March 04, 2004 - 09:00 pm: |
Alana: Reading between the lines here I assume that: 1. You're using a no cable box hookup, and 2. The VCR isn't ancient-- You then need to access the VCR's on-screen setup menu, select "cable" then "channel scan" (or words to that effect) and wait for the VCR to scan the channels. |
Post Number: 2 Registered: Mar-04
| Posted on Sunday, March 07, 2004 - 12:26 am: |
Thanks John. I tried that but no go. The weird thing is that it used to work fine. Thanks anyway. |
| Posted on Tuesday, March 09, 2004 - 09:26 am: |
Alana, Are you using the same cable service as you did before? How many channels can you vcr dial go to? Does your VCR have separate VHF and UHF input? When you said "it used to work fine", how long ago was that? Through cable or antenna? I assume you are sure that your cable service provides more than 15 channels. Answers to these questions may help to identify your problem. |
| Posted on Saturday, January 08, 2005 - 12:16 am: |
I know this is an old thread, but I have the same problem. You might be in better shape than me though because I don't have the (apparently?) necessary original remote control. I'll bet the auto channel scan is not accessed on-screen but on the remote. Look for a button on the remote that says "channel scan" or "channel search". Press it and it should start scanning channels. Leave it alone until it goes through its whole routine and it will stop on its own when its done. Anyone have any advice for me (no remote with channel search button) short of finding an original remote or using a cable box? I thought my new u-remote might do the trick but its scan button functions only to surf channels, not set them. TIA Davey |
Silver Member Username: Samijubal
Post Number: 557 Registered: Jul-04
| Posted on Sunday, January 09, 2005 - 10:31 pm: |
If you have cable make sure it's set on cable in the menus, if antenna set to antenna. If your remote won't access menus, buy a One For All remote. They have the highest compatibility. |
| Posted on Thursday, March 10, 2005 - 04:25 pm: |
I had the same problem. I finally figured out that there was a small button labeled "CH MEMORY". This brings up a menu that will allow ANT to Cable switching, then you can set the channels. I'm not sure how you would change it without the original remote. |
remote challenged Unregistered guest |
| Posted on Thursday, April 28, 2005 - 06:31 pm: |
i am trying to program a Magnavox tv with a universal remote (the one with the tv,vcr,cbl, aux) buttons across the top. I have cable service going in to the tv without a cable box. I am only able to get 5 cable stations. What is the procedure to program the tv to get all the cable channels. |
Post Number: 950 Registered: Jul-04
| Posted on Thursday, April 28, 2005 - 07:02 pm: |
Go into the setup menus and under cable/antenna select cable. |
| Posted on Thursday, April 28, 2005 - 09:38 pm: |
thanks for the reply, but I am I not able to get any menus. the magnavox tv has a build in vcr. I have tried the following steps. / Turn ON your TV 2/ Press SET button for approximately 2 seconds. 3/ Press TV button 4/ Enter 4-digit code No. (several codes) 5/ Press SET button also tried / Turn ON your TV 2/ Press SET button for approximately 2 seconds. 3/ Press TV button 4/ Enter 4-digit code No. 5/ Press SET button I even tried the scan button on the remote. I still only get 5 random numbers. Perhaps I just need to attach a vcr.
Post Number: 952 Registered: Jul-04
| Posted on Thursday, April 28, 2005 - 09:44 pm: |
If it's a Magnavox it's actually a Funai, try a Funai code. Some universal remotes don't have very good compatibility. Try a One For All, they are the best. |
| Posted on Thursday, April 28, 2005 - 10:18 pm: |
i have a rca universal remote also. I have tried their instructinos; 1. turn on tv 2.press and hold code search until light stays on, then release. 3. press tv button 4. press power repeatedly until tv turns off 5. press enter (repeat for vcr and cable) The tv never turns off in step 4. Oh well I guess i cant cable in my office while I am at work (ha ha). Thanks for your help.
Post Number: 953 Registered: Jul-04
| Posted on Thursday, April 28, 2005 - 11:09 pm: |
You need to be using a code for a TV/VCR, VCR codes aren't the same as TV/VCRs. |
| Posted on Thursday, April 28, 2005 - 11:31 pm: |
Thanks, I will search the internet for those codes. I am so determined to resolve this issue, I havent done any work. |
