Thread: Archive through January 02, 2005 |
New member Username: Naomie
Post Number: 2 Registered: Aug-04
| Posted on Thursday, August 05, 2004 - 12:48 am: |
Hi - can anyone give me the codes to make LG dvd models DV6812P and V8824W zone free???
Relevant Product Info
AlexKKK Unregistered guest |
| Posted on Friday, August 06, 2004 - 07:21 am: |
This is for DV 6812P - Ensure that there is no disc in the player (ie: "no disc" is displayed). - Press PAUSE - Enter 314159 immediately without delay - Enter the region code (0 for region free, or 1-6). - Press PAUSE - Turn the player off for a few seconds. - Turn the player back on - Here it goes Not sure whether it works with V8824W |
Post Number: 3 Registered: Aug-04
| Posted on Friday, August 06, 2004 - 07:50 pm: |
Alex - thanks heaps for this. When i play region 1 dvd's (im in aust region4) they scroll and arent viewable - any ideas re this? btw it also worked with V8824W however same problem - it also doesnt play certain copied dvd's...any ideas?  |
| Posted on Saturday, August 07, 2004 - 11:43 am: |
Naomi, I guess its due to Region 1 is on NTSC but you are in PAL in Australia. If your TV can display NTSC signal, and you set the DVD output signal system to AUTO, than it should work.
| Posted on Wednesday, August 11, 2004 - 07:21 am: |
Thanks from me too Alex. Now I can watch dvds in Australia sent from the uk. Got to love the internet and those who use it to help ;) |
| Posted on Thursday, August 26, 2004 - 06:41 am: |
i have a dv8721p LG dvd, how do i make it region free |
| Posted on Thursday, August 26, 2004 - 07:27 am: |
have you tried the same method as the 6812p? |
| Posted on Thursday, August 26, 2004 - 08:15 am: |
Hey AlexKKK,Thanks for the region free code for the V8824W. Dunno where you got from but it works great!
Ollypig Unregistered guest |
| Posted on Tuesday, August 31, 2004 - 12:13 pm: |
Does anyone have a region free code for an LG8621 dvd player? |
| Posted on Wednesday, September 01, 2004 - 10:19 am: |
why not try the same steps for LG6812, it may also work. |
Wattsie Unregistered guest |
| Posted on Sunday, September 05, 2004 - 02:30 am: |
Hi, Does anyone know the region free code for the LG DVD/VCR Combo recorder RC6821W |
| Posted on Thursday, September 09, 2004 - 01:42 am: |
Having troubles with the V8824W when playing DVDs. At the end of the DVD the picture starts to skip and after a couple of times doing this it freezes. What's going on??? |
| Posted on Thursday, September 09, 2004 - 09:23 am: |
If this happens only to one DVD, its the DVD defect.
| Posted on Monday, September 13, 2004 - 07:28 pm: |
Guys please i can't get work the V8824W.. are you sure the above code helps. i have been trying for hours.. i would really appreciate it if you could go more indepth.. as in exactly how much time i have to put it in and what am i supposed to see on the screen as i am doing it |
| Posted on Tuesday, September 14, 2004 - 05:50 am: |
Could you tell me what did you see on screen after you pressed 314159? |
Post Number: 4 Registered: Aug-04
| Posted on Tuesday, September 14, 2004 - 06:52 am: |
Hi - when i entered 314159 i got a blue screen which gave me the choice of entering region codes up to 6 - I entered 0 to make it region free. |
| Posted on Wednesday, September 15, 2004 - 08:23 pm: |
I have used 314159 code successfully on my LG player. I have also passed code onto several friends with different LG machines and this code has worked every time. The only difference is sometimes the prompt to change region code ('0' for multi) appears on TV screen (obviously have DVD channel selected) and sometimes on DVD player itself. |
| Posted on Saturday, September 18, 2004 - 04:04 am: |
Rose, I have a V8824W LG Combo driver too. Sometimes my movies also skip a little when playing. I was using LASER brand media and also PRINCO brand. I tested a TDK brand and it worked fine. May I know if you've had the same problems with the above brands? Can anyone offer any suggestions? Could it be something to do with the progressive scan feature? LG is supposed to be compatiable with everything. |
| Posted on Thursday, September 23, 2004 - 12:12 am: |
Hi, I have an LG DV7821P player. Will the unlocking code for DV6812P work the same for mine? |
| Posted on Thursday, September 23, 2004 - 07:20 pm: |
Stella, No harm trying |
| Posted on Saturday, September 25, 2004 - 03:05 am: |
I have a Nihon NDV-800K DVD Player my sister sent from Saudi. Some DVDs play others don't, they give error message "wrong region". Any DVD code to make this model region-free? Thanks and more power to the free world! Pls send me email if you have this code. |
| Posted on Saturday, September 25, 2004 - 11:24 am: |
AlexKKK, you're the man! I've just unlocked my Lg DVB318 with your tips. Tks. |
| Posted on Sunday, September 26, 2004 - 03:31 am: |
Hi, sorry to take so long to reply Alex!! It wasn't with only one DVD, it was with burnt ones and bought ones and it only did it and the end of the movies. It doesn't seems to be doing it any more. Just teathing problems I guess. Thanks anyway! Rose |
| Posted on Sunday, September 26, 2004 - 10:17 am: |
Just unlocked my sister's LG V8824W....ruling :-) Thanks for the code |
| Posted on Sunday, October 03, 2004 - 06:44 am: |
I'ved got a new V8824W DVD/Video combo and I need the code for a Panasonic TV so I can control the TV using the V8824W remote. Can anyone give me the code - Panasonic is not in the manual |
| Posted on Saturday, October 09, 2004 - 11:13 am: |
Does anyone know how to get LG DC-596M free zone ? Plz Thx |
| Posted on Tuesday, October 12, 2004 - 04:00 pm: |
Does anyone have any idea on how to get lg dvd6194 region free? I've already tried a few different ways, which I was advised to, but they don't seem to work. I'm getting really frustrated. The RMTM5000 or whatever did not function. |
| Posted on Tuesday, October 19, 2004 - 08:02 am: |
Does anyone know the region free code for the ; LG DVD/VCR Combo recorder RC G8221W . Thanks ! |
Smintie Unregistered guest |
| Posted on Tuesday, October 19, 2004 - 08:16 am: |
I have just successfully unlocked LG DW 6522P |
| Posted on Tuesday, October 19, 2004 - 08:18 am: |
I have just successfully unlocked LG DW 6522P using: Ensure that there is no disc in the player (ie: "no disc" is displayed). - Press PAUSE - Enter 314159 immediately without delay - Enter the region code (0 for region free, or 1-6). - Press PAUSE - Turn the player off for a few seconds. - Turn the player back on THANX A MIL!!!! |
| Posted on Tuesday, October 19, 2004 - 10:34 am: |
Hi, I am from Australia and I have an LG dvd/vcr combo model V782W. What code or method should I use to make it region free? Thank You!! |
| Posted on Tuesday, October 19, 2004 - 04:12 pm: |
I have LG DV8851C (8751 and 8651 should be the same) and the above doesn't work..Any other ideas? |
| Posted on Tuesday, October 19, 2004 - 04:20 pm: |
I'll answer myself. It worked when i first pressed Open, then Pause and 314159. This works atleast for LG DV8851C
| Posted on Wednesday, October 20, 2004 - 07:26 pm: |
Can anyone tell me how to unlock - LG DVD/VCR - Recorder/Video cassette recorder . Model : RC6821W . Thank You ! |
| Posted on Thursday, October 21, 2004 - 07:43 pm: |
Wow, there was I looking for an region unlocking code for my LG DVD/VCR and found this forum....My first thought was 'not another forum where no-one replies'..Only to be proven wrong..Thankfully your forum gave me what I needed. Many thanks. |
| Posted on Sunday, October 24, 2004 - 11:22 am: |
Hi....i have my DVD player locked!!! The model is FFH-DV25A, PLEASE HELP ME!!! Thanks! |
| Posted on Tuesday, October 26, 2004 - 07:12 am: |
I am also after the hack for the LG R6821W - the normal 314159 doesn't seem to work on this partcular unit. This unit doesn't bring up a "No Disc" warning as it just switches back to TV/VCR mode (this is a combi unit) if no Disc is present. Any help would be greaty appreciated |
| Posted on Wednesday, October 27, 2004 - 12:58 pm: |
Hi. I have a LG DV7821P DVD player. I've done the region unlocking, but can't seem to play any DVD's on a TV here in Canada (NTSC TV). The sound of the DVDs come through, but the pictures is rolling and distorted. |
Templar Unregistered guest |
| Posted on Thursday, October 28, 2004 - 01:18 pm: |
Thanks for the code. Just to let everyone know, the code for the dv6812p works for the dv8721p. |
| Posted on Tuesday, November 02, 2004 - 07:14 am: |
You guys are great - worked fantastic with my dvd/vcr combi v692wk - thanks! |
| Posted on Tuesday, November 02, 2004 - 08:06 pm: |
alexKKK, thank you VERY much. I just unlocked the V8824W LG player, and can now play LEGITIMATELY BOUGHT u.s. videos in australia. What an absurd and unusable practice to limit the regions in a global economy. |
| Posted on Saturday, November 06, 2004 - 07:20 pm: |
Thank You!!!!!!! I just unlocked my LG V692WK |
| Posted on Sunday, November 07, 2004 - 09:21 am: |
Can anyone help with unlock code for LG 6821 VHS/DVD Recorder. |
| Posted on Sunday, November 07, 2004 - 01:41 pm: |
Hi guys, I really need a post for code to LG DV-8800c. Bought it in Russia. |
| Posted on Monday, November 08, 2004 - 10:48 pm: |
Can anyone tell me how to unlock , LG RC6821W VHS/DVD Recorder ! Thanks ! |
| Posted on Monday, November 08, 2004 - 11:42 pm: |
Unlocking the LG V782W DVD player * Ensure that there is no disc in the player (ie: "no disc" is displayed). * Press PAUSE * Enter 314159 (the first 6 digits of pi with no decimal place). * Enter the region code (0 for region free, or 1-6). * Press PAUSE * Turn the player off for a few seconds. * Turn the player back on * Voila!
Daeghran Unregistered guest |
| Posted on Wednesday, November 10, 2004 - 03:52 am: |
Excellent!!! My LG-8721P is now multi-zone thanks to AlexKKK's code. MANY Thanks. |
| Posted on Thursday, November 11, 2004 - 12:30 pm: |
Please can someone help me to mulit region my LG DVD LHC6235 my Phillips 622 I downloaded a file to put on my LG I followed the instructions and burned it with the newest nero but I keep getting disc error I am trying to change them from region 2. Thanks in advance |
| Posted on Friday, November 12, 2004 - 03:15 am: |
@homerforum Why not try AlexKKK's code on your LG. It isn't for my specific model but it worked nonetheless. Seems to work on a whole range of LG's as far as I can see. |
| Posted on Friday, November 12, 2004 - 06:22 pm: |
Hi there...I have the LG V8824W Progressive Scan DVD / VCR Combo...can anyone help me in knowing how to record from my tv to my vcr...my channels are from the sattelite...and i connected the s video cable but it didnt work! help |
| Posted on Saturday, November 13, 2004 - 06:03 am: |
With my LG DV8700C AlexKKK's code does work. Thanx. |
kingriz Unregistered guest |
| Posted on Thursday, November 18, 2004 - 04:08 pm: |
hey guys wat about the LG DA 5320 |
| Posted on Friday, November 19, 2004 - 06:54 am: |
DV-8751, easy! Eject the dvd-slot. Press three 0:s. 0 0 0 Then chose reg 0. In the meny that appears. Then press pause. CLose tray. Turn off player |
| Posted on Friday, November 19, 2004 - 08:55 am: |
Hi, Iīve tried to unlock my lg dvd6194, but the codes here donīt seem to work, no blue screen or code or anything is shown. Apparently nothing changes. What am I supposed to see when I enter the code? |
| Posted on Friday, November 19, 2004 - 06:24 pm: |
Thankyou thankyou thankyou!! The code 314159 also works on model DV7821P |
| Posted on Saturday, November 20, 2004 - 08:15 am: |
Can anyone help with unlock code for a LG RC 6821 W DVD/VHS recorder. I've tried the 314159 code and also 7 zeros and 4 zeros but no success. It's a pain not being able to play my US DVDs (I'm in Australia) HELP ! Please
SeanBoy Unregistered guest |
| Posted on Sunday, November 21, 2004 - 04:59 am: |
Thanks alexkkk i have a australian combo lg dvd player/vcr player model V782W and the 314159 thing worked.Excellent  |
Post Number: 5 Registered: Aug-04
| Posted on Sunday, November 21, 2004 - 05:50 am: |
wow alex you certainly have helped a lot of people! you are quite the legend! thanks again! |
| Posted on Tuesday, November 23, 2004 - 05:37 am: |
can someone confirm/second that the 314159 code also vorks for with LG DV 8700C ? thanks a lot. I"d rather have a second opinion before I go ahead and screw my friend's player!  |
Anonymouss Unregistered guest |
| Posted on Thursday, November 25, 2004 - 05:45 pm: |
Suggest you try. There should be no harm on doing it if it doesn't work. So many had tried and most successful. Some doesn't work but there had been no record of damage to the DVd.
| Posted on Friday, November 26, 2004 - 08:56 pm: |
I have tried the the 314159 thing on my LG V8824W combo and now it won't play any dvd's at all. I must have entered the numbers in the wrong order because I didn't get a blue screen. Now I've tried about 10 different dvd's and the player can't read them. Anyone have any idea on how to reset the player? |
| Posted on Saturday, November 27, 2004 - 03:54 pm: |
Hi spryan Try entering the code back in then setting the region code back to what you are; ie region 4 for aust etc.. alternatively try entering the wrong code ie 315149 and see if that makes a difference.... hope this helps. |
