Thread: Toshiba Service Menu Assistance 32AF43 |
New member Username: Techdude49
Tampa,
FL
Post Number: 1 Registered: May-05
| Posted on Sunday, May 08, 2005 - 02:26 am: |
Hi, My two year old TV seems to be having some trouble with the upper right hand corner. It seems to bow down. No matter what I adjust it in the service menu, I can't seem to straighten it out. I've tried the trap settings and all the Horizontal and Vertical settings with no success. I don't like messing around with the service menu settings, so I made sure I wrote all the existing settings down before I started. Unfortunately, I just can't take having the top portion of my letter boxed movies slanting down and to the right anymore. Any suggestions on correcting this issue, like the order of adjusting the settings, etc., would be greatly appreciated. Thanks! |
Tampa,
FL
Post Number: 6 Registered: May-05
| Posted on Thursday, May 12, 2005 - 09:05 am: |
Anyone? I just need a starting point... |
| Posted on Thursday, May 12, 2005 - 09:51 pm: |
I have a 20 inch Toshiba LCD tv, model 20vl14. I want to mount it on the wall. I can't seem to find the right size screw for the four mounting holes on the back. Any idea what size they are? |
donnamae Unregistered guest |
| Posted on Friday, June 17, 2005 - 09:55 am: |
I just purchased a Toshiba TV/VCR combo, MV20P2, so i'm still adjusting, BUT - can you record an program and watch a different program at the same time?? Thanks! |
Silver Member Username: Joe_c
Oakwood,
Ga
Post Number: 439 Registered: Mar-05
| Posted on Saturday, June 18, 2005 - 12:07 am: |
hey darren whats the code for the toshiba tv's?? |
New member Username: Misanthrope13
Toronto,
Ontario
Post Number: 9 Registered: Mar-05
| Posted on Monday, June 27, 2005 - 01:41 am: |
put the volume on 0, then hold the volume down button, while holding the number 9 on the remote. it should pop up. just try not to dick around with the settings tho. |
