Thread: Recording TV Shows with a VCR onto VHS (how??) |
New member Username: Newb4life
Post Number: 1 Registered: May-05
| Posted on Thursday, May 05, 2005 - 08:53 pm: |
Hello, I have a DV HiFi VCR and I was wondering how you would go about recording TV shows with a VCR onto a blank VHS tape? I do not have cable (just 3 channels) so I can not do anything though a coax cable. |
Post Number: 2 Registered: May-05
| Posted on Thursday, May 05, 2005 - 09:01 pm: |
****Hi-Fi DA4 VCR -correction
Silver Member Username: Samijubal
Post Number: 999 Registered: Jul-04
| Posted on Thursday, May 05, 2005 - 09:15 pm: |
What are you trying to record from? |
Post Number: 3 Registered: May-05
| Posted on Thursday, May 05, 2005 - 09:46 pm: |
I am trying to record a regular television show from my Mitsubishi televison set... |
Gold Member Username: Samijubal
Post Number: 1001 Registered: Jul-04
| Posted on Friday, May 06, 2005 - 12:33 am: |
You don't record from a TV. You have to have a source to record from, cable, antenna, etc. |
Troy Heagy Unregistered guest |
| Posted on Friday, May 06, 2005 - 09:50 am: |
TWO POSSIBILITIES: (1) Off-the-air - Set up your antenna - Run the cable from the antenna, to the VCR - Run a round phono plug from VCR's Video Out to TV's Video In (to get a picture) - Turn on VCR - Select Channel on VCR - Press record on VCR (2) Cable TV - Run the cable directly to the VCR - Run a round phono plug from VCR's Video Out to TV's Video In (to get a picture) - Turn on VCR - Select Channel on VCR - Press record on VCR NOTE: I've vastly over-simplied this, but this will at least get you started & recording. troy |
Post Number: 4 Registered: May-05
| Posted on Friday, May 06, 2005 - 02:49 pm: |
Thanks Troy that really help |
| Posted on Wednesday, May 25, 2005 - 06:04 pm: |
I am trying to record "Lost" for tonight. I have a RCA vcr and I do not have the directions. Can you help me? |
| Posted on Monday, May 30, 2005 - 06:21 pm: |
THESE PEOPLE ARE FUKIN STUPIF THAT DONT KNOW HOW TO UESE A VCR!!! |
New member Username: Marble
Post Number: 1 Registered: Jun-05
| Posted on Monday, June 20, 2005 - 04:02 am: |
It's been many years since I recorded TV shows on a VCR. Would someone please assist me with the absolute basics? I've got a Zenith TV, Model SS2025Y; and a Phillips Magnavox VCR, VR2222AT22. (The connections are all correct; I can play rented movies.) I remember that the TV needs to be on Channel 4 (not 3). But here we go: How do I get a menu on screen? How do I program VCR for the particular channel of show I want (since the TV is necessarily set on Ch 4 to operationalize whole deal)? Once I've designated the show to record, once or weekly, do I turn off power on both TV and VCR? Or only on TV? Finally, assuming I succeed in recording several shows on a tape, how do I find a given show fast? As I recall, I used to have to fast forward endlessly to FIND the show I wanted, because the equipment was not functioning properly (really, I think it wasn't--however, I suppose it COULD have been a malfunction of my brain). I.e., how do you code the show and zip to it when you put the tape in? I assume you can pull up a list of recordings you've done--but how? So I need steps 1,2,3 etc. Any person generous enough to take the time to answer these Little Kid Questions (kind of like one level above asking "How do I go about breathing--can someone tell me?") must be patient indeed, and I thank you in advance. (By the way, I have a Ph.D.--honestly! But, as you can tell, it's in a human development area, not physics. We deal with the "hard-wired" aspects of personality only as metaphor, right? Unless I'm confused about that!) Cheers. |
| Posted on Tuesday, July 12, 2005 - 12:41 am: |
how do you record a vhs that has like a block on it . because it dosent record right when you push record it gets dim and bright agian . please email me. |
Post Number: 1301 Registered: Jul-04
| Posted on Tuesday, July 12, 2005 - 01:02 am: |
It's copy protected, you need a stabilizer. |
someone betta than u panny Unregistered guest |
| Posted on Saturday, July 16, 2005 - 03:16 pm: |
the ones who are stupid are the ones who cant type MORON |
