Thread: DVDs Widescreen but not 16 :9 |
Bronze Member Username: Pugcharlie
N, E, PA
Post Number: 31 Registered: Feb-05
| Posted on Monday, May 02, 2005 - 10:17 pm: |
I'm not sure if this should be in the DVD thread but here's my question: I have a KDF50WE655. Some DVDs say "Widescreen" but display as a smaller picture within the screen. There is space on sides and top and bottom. I can zoom the picture but will then lose subtitles. Other, newer DVDs fill the entire screen or have even wider aspect ratios and have some black bands on top and bottom, which I can understand as the DVD has been formatted to display as the original fim did. Am I correct to assume that there are a lot of older DVDs out there that say "widescreen" but are widescreen or letter boxed only for conventional 4:3 TV screens? Playing them on 16:9 Widecreen HD TVs will not fill the screen properly. I am curious about this. Thanks |
Silver Member Username: Joe_c
Oakwood,
Ga
Post Number: 208 Registered: Mar-05
| Posted on Monday, May 02, 2005 - 10:31 pm: |
sounds like your dvd player is setup to play on a 4:3 screen , go into menus and change this and make sure tv's zoom is off |
N, E, PA
Post Number: 32 Registered: Feb-05
| Posted on Monday, May 02, 2005 - 10:54 pm: |
The DVD player IS set up for 16:9. New DVDs play correctly. Certain older ones that are labeled as "widescreen" do not correcly fill the screen put look like a smaller rectangle within a box. |
Oakwood,
Ga
Post Number: 211 Registered: Mar-05
| Posted on Monday, May 02, 2005 - 11:04 pm: |
not enhanced for wd tv's but dont know why it displays like that. maybe just the way the dvd displays it?? |
TV Psychic Unregistered guest |
| Posted on Monday, May 02, 2005 - 11:15 pm: |
Two possibilities: 1. The DVD's are really fullscreen not widescreen versions. If you bought them used this is quite common. 2. The DVD's have both versions of the film on them and you must select from the fullscreen or widescreen choices. TV Psychic
N, E, PA
Post Number: 33 Registered: Feb-05
| Posted on Monday, May 02, 2005 - 11:58 pm: |
I am thinking that they are "faux widescreen." On a conventional 4:3 TV, they do look letter boxed but on a true widescreen TV they don't appear to fill the screen unless you use zoom mode. Those in quesiton are older releases and may have not been formatted for 16:9 HD widescreen. |
Jimbo in Dallas Unregistered guest |
| Posted on Tuesday, May 03, 2005 - 09:40 am: |
I just bought a DND that said "widescreen" and thati it was formated approx. 1.85:1. I see the same problem on my Sammy DLP. It is widescreen format but is a smaller picture within the screen, black bands all around, just like Steve mentioned in post 1. I have double checked DVD player settings (Toshiba SD 5970) and TV settings. I can stretch to fit but I can't stand the fat images. Zooming will fill the screen top to bottom but leaves the black bands on the side. Is it just this DVD?? It's a 1998 movie. |
| Posted on Tuesday, May 03, 2005 - 09:42 am: |
I just bought a DVD that said "widescreen" and that it was formated approx. 1.85:1. I see the same problem on my Sammy DLP. It is widescreen format but is a smaller picture within the screen, black bands all around, just like Steve mentioned in post 1. I have double checked DVD player settings (Toshiba SD 5970) and TV settings. I can stretch to fit but I can't stand the fat images. Zooming will fill the screen top to bottom but leaves the black bands on the side. Is it just this DVD?? It's a 1998 movie. |
N, E, PA
Post Number: 34 Registered: Feb-05
| Posted on Tuesday, May 03, 2005 - 10:38 am: |
I believe I have the answer. Some older "widescreen" films are not anamorphic and thus not able to not fill a 16:9 HDTV. The DVDs need to say "anamorphic" or "enhanced for 16:9" TVs. |
Ben Wallace Unregistered guest |
| Posted on Tuesday, May 03, 2005 - 02:24 pm: |
not all widescreen dvd's will fil the screen even on a 16:9 display. It depends entirely on the original aspect ratio of the film. you can learn alot from this site, http://www.widescreen.org/aspect_ratios.shtml |
| Posted on Tuesday, May 03, 2005 - 03:46 pm: |
I think you are right, Steve. Here's a good article on the anamorphic vs. non-anamorphic DVD issue. http://www.thedigitalbits.com/articles/anamorphic/ |
N, E, PA
Post Number: 35 Registered: Feb-05
| Posted on Tuesday, May 03, 2005 - 05:17 pm: |
Great web-site, Ben. I, for one, welcome that band on top and bottom of certain DVDs as that means the integrity of the director's original vision (whether it be Cinemascope, Cinerama, or Super Panavision 70) is intact. |
