Thread: Record from Comcast DVR to VCR |
New member Username: Rfeigels
Post Number: 1 Registered: Apr-05
| Posted on Thursday, April 14, 2005 - 04:09 pm: |
Okay, I'm pulling all the hair out of my head. All I want to do is record a movie that is stored on my DVR to my VCR. On the front of my VCR are three RCA jacks...yellow for video, red and white for audio. When I connect from the audio and video outputs on my Comcast Cable box to these jacks, I get video fine, but no audio. Am I doing something fundamentally wrong? This doesn't seem like it should be brain surgery, but it's turning into it! Thanks! |
Relevant Product Info
formerly xvxvxvx Unregistered guest |
| Posted on Thursday, April 14, 2005 - 11:26 pm: |
You need to go into the audio menu of your DVR and set the audio output to either analog or PCM depending on what options are listed. xvxvxvx |
| Posted on Thursday, April 14, 2005 - 11:32 pm: |
Post Number: 2 Registered: Apr-05
| Posted on Friday, April 15, 2005 - 01:32 am: |
Well...darn. The DVR's only options in the audio menu is stereo, matrix, or mono. Is it possible it only outputs digital stereo? Therefore there'd be no way to convert the digital signal to analog. Are there any VCRs that can accept and convert a digital signal? |
| Posted on Friday, April 15, 2005 - 06:15 pm: |
Roger, Try all three settings and see which one works. Another common mistake people make is they accidentally connect the audio cables to the DVR's input instead of the output jacks. xvxvxvx |
AuNatural2005 Unregistered guest |
| Posted on Tuesday, May 17, 2005 - 11:49 am: |
Roger, did you ever figure this out? I am having the same trouble |
iworkincable Unregistered guest |
| Posted on Friday, May 20, 2005 - 12:03 pm: |
aunatural - use the video and audio out feeds on the back of the box to inputs of vcr change vcr to line in 1 or 2 depending on which your using |
AuNatural Unregistered guest |
| Posted on Friday, May 20, 2005 - 05:05 pm: |
iworkincable, Thanks for your response. I will try your advice, but what is vcr line one and two? |
| Posted on Saturday, May 21, 2005 - 03:27 pm: |
Is it possible to transfer stored comcast DVR recordings onto a home computer? |
New member Username: Doc_chiron
Post Number: 4 Registered: May-05
| Posted on Friday, May 27, 2005 - 05:23 pm: |
web search: "How to record via IEEE 1394 (Firewire) to Windows XP" |
| Posted on Wednesday, June 15, 2005 - 01:58 pm: |
I tried recording from DVR onto VCR but as soon as I press the record button on VCR the TV screen goes blank (that is)DVR connection to TV is cut and VCR connection gets on. Because of this I am not able to record any programs from DVR. Kindly help |
Post Number: 3 Registered: Apr-05
| Posted on Monday, August 01, 2005 - 05:40 pm: |
I have not been able to get this to work yet. Everything looks to be in order...there's no logical reason for it not to work. Unless there's just something wrong with my VCR. Cheap piece of @#@#&$ |
Gold Member Username: Samijubal
Post Number: 1378 Registered: Jul-04
| Posted on Monday, August 01, 2005 - 06:00 pm: |
Connect with RCA jacks and set the VCR to line. |
Post Number: 4 Registered: Apr-05
| Posted on Monday, August 08, 2005 - 01:34 pm: |
Okay, I figured it out. Actually not much to figure out, save to stop being lazy. Rather than reach around behind the units with a diagram of the back in hand, a flashlight, and a mirror, I just pulled the cabinet out (not particularly fun, since it has a 60" TV on it). Once behind the units I easily connected the outputs of the DVR to the inputs of the VCR and voila! It worked. Quality of recording to the VCR isn't spectacular, but should be sufficient. |
| Posted on Tuesday, November 22, 2005 - 10:21 pm: |
I GOT A DVR FROM BRIGHTHOUSE AKA TWC scientific alanta z8300 and i got a IEEE firewire cable 1394 connect to my pc and its not pulling up on my pc to burn to my dvd burner from what i have record on my dvr |
New member Username: Hcg
Post Number: 1 Registered: Dec-05
| Posted on Thursday, December 22, 2005 - 08:02 pm: |
All: Just got an DVR from Warner Cable. Is SA Explorer 8300HD DVR. The manual indicates that I can download saved dvr programs to my VCR, but that option does not come up when I follow the manual instructions. Has Warner eliminated the option? Any work arounds? hcg |
| Posted on Thursday, January 05, 2006 - 03:10 pm: |
Thanks to Roger for solving my recording problem! I didn't even think that I needed to connect my VCR to my DVR. I thought whatever was being displayed on the screen would automatically record to the VCR. But, now that I think about it, the TV screen is acting as a monitor while the actual program is stored on the DVR...even during "live" mode. Thanks for the help! |
Awagunda Unregistered guest |
| Posted on Thursday, January 26, 2006 - 07:42 pm: |
I am having trouble recording something from my DVR to the VCR. When I connect the outputs from the DVR to the inputs of the VCR, I lose the color from the television and the program I recorded. Does anyone know why this happened? |
crb61388 Unregistered guest |
| Posted on Wednesday, February 15, 2006 - 01:15 pm: |
how do you change you vcr to line when you want to record |
| Posted on Saturday, February 18, 2006 - 07:03 am: |
Two things: the colors on your L,R, and Audio jacks (red, yellow and white) do not necessarily match from the DVR box out2 to the VCR line 2 in. Make sure you check the lettering on your machines. Match L to L, R to R and Audio to Audio, regardless of the lead's colors. Also, don't use the random jacks in the back of your VCR unless; you may need to read the delineation "L2" for line 2. Then, when you are manipulating your VCR to record, you must use the remote and toggle the "input" button so that you switch your input from "Line 1" (which is always tuned to your cable input) to "Line 2". It will show up on your TV legend. Then from your DVR "Play" menu, you should be able to scroll to the line item that says "Record to VCR". When you select this, the program starts instantaneously, so you may want to hit record first, if you really treasure that first second or two. Good luck.
| Posted on Saturday, February 18, 2006 - 07:04 am: |
Okay, that's three things...long nite.
New member Username: Cannon_p
Post Number: 1 Registered: May-06
| Posted on Friday, May 12, 2006 - 11:02 pm: |
i have followed all the steps that tech told me and others even the book that is with my satalite dish but still nothing. can anyone out there help me. please. |
New member Username: Pr_latin_girl
Miami,
FL
United States
Post Number: 1 Registered: Sep-06
| Posted on Sunday, September 24, 2006 - 12:01 am: |
can i save, using the usb 1.1 port, a recorded program? i have a DVR from Comcast Cable |
New member Username: Pasionet
Post Number: 1 Registered: Aug-07
| Posted on Saturday, August 18, 2007 - 12:03 pm: |
OMG I had NO idea so many people had the problem! I am having it, too!!! I'm gonna go try out some of the suggestions on my stuff. Only difference is that my TV doesn't have the input/output jack thingys, so we have a converter box thingy. Wish me luck! I've been fighting with the stupid thing since beginning of April!!! |
