Thread: Hook up between JVC DR-MV1S & Sima GoDVD |
| Posted on Wednesday, April 13, 2005 - 04:31 pm: |
I'm having problems hooking up my Sima GoDVD to my JVC player/recorder. I don't know which connection to use. I tried using the composite video connection because I'm already using the S-Video to hook up my player/recorder to my TV. What do I do? |
Silver Member Username: Samijubal
Post Number: 845 Registered: Jul-04
| Posted on Wednesday, April 13, 2005 - 05:01 pm: |
I believe that only has 1 set of input/outputs. There are composite and s-video, but they are the same input/output, they can't be used for 2 different sources. You can connect it to the recorder or the TV, not both. |
New member Username: Josip
Post Number: 2 Registered: Apr-05
| Posted on Sunday, April 17, 2005 - 05:01 pm: |
Hi, I was wondering if any of you know of a DVD recorder with digital terrestial tuner (DVB-T, as I'm in Europe) and a DVI-D in/out ? Thanks for your reply in advance Josip |
Unregistered guest |
| Posted on Monday, June 20, 2005 - 12:07 am: |
Where abouts can i purchase the Sima ct-2 go disk? |
Gold Member Username: Samijubal
Post Number: 1185 Registered: Jul-04
| Posted on Monday, June 20, 2005 - 08:34 pm: |
http://www.simacorp.com/ |
