Home > Message Board > Home Video > Rear Projection TVs > Archive through May 05, 2005 > Dirty Projection Screen
Author Thread: Dirty Projection Screen
Username: Bigmike74
Saint Louis, MO
I have a Panasonic 53-in widescreen HD bought in Dec. 02. It now has major fingerprints and dirt on the screen from my 2 yr old. Is there anyway to clean that, or can a replace the screen? They are beginning to be a pain to look at.
Username: Jbecvar
Post Number: 46
If it has a screen protector on it then you can clean it with just normal window cleaner and a rag. Check in your instructions book to see if it says you have one or not.
Username: Paul_ohstbucks
Post Number: 570
yep,
I usually just use a damp handtowel. Just dont go scrubbing away like a madman because you might leave permanent streaks/scratches behind.
I did that to my bathroom mirror not too long ago.....
geez, how was I supposed to know it was glass with a coating??? "laugh"
Username: Mr_lynch
Seattle, WA
Post Number: 695
Micheal-
You can find a replacement/protector screen here:
http://www.bestbuy.com/site/olspage.jsp?skuId=5405572&type=product&id=1051806321 569
Home > Message Board > Home Video > Rear Projection TVs > Archive through May 05, 2005 > Dirty Projection Screen [ « Previous ] [ Next » ]
