Home > Message Board > Home Video > Satellite TV > Archive through April 16, 2005 > Dish 500 Pro Issue
Author Thread: Dish 500 Pro Issue
zvcxvzcxvzcxv
I had my dishnetwork installed. I replaced the Dishnetwork 311 receiver with the Pansat 2500a. But only one cable is coming into the reciever. Thus, what is the point of the disq switch i have in my hand? I plug the cable into the back of the Pansat 2500a and I only receive channels 119. Can you run a trick to receive just 110, and not 119? Let me know.
help is here
either realign the dish so U only get the 110 (no disque switch use) ...it was installed and aligned with using BOTH the 110 and 119 in mind to receive signals...if U leave it alone AND use the disque switch and Dish Pro channel lists ,then U will get both the 110 and 119...without the disque switch U will only get 1 satellite based upon the dish alignment
AttaKnee
What a sad pathetic place this has turned out to be.
I think they will sadly regret putting Knee Grow in charge. What a loser.
Home > Message Board > Home Video > Satellite TV > Archive through April 16, 2005 > Dish 500 Pro Issue [ « Previous ] [ Next » ]
