Home > Message Board > Home Video > Satellite TV > Archive through April 16, 2005 > DISH PRO 500 with Multi Switch LNB
Author Thread: DISH PRO 500 with Multi Switch LNB
I have the new mulitswitch LNB's i think so only one cable comes into my house into the pansat. I don't have two cables going into the 22mhz switch.
Thus, I only get 119. I want to get 110. WHat should i do to switch it? Diplexer, splitter, multiswitch?
Username: Juanchispas
Post Number: 8
I'm having the same problem with mine. I can get 119 but I can't get 110. I was thinking that I would need a multiswitch where you can hook two cables out of one LNB to solve the problem but then again... Anyone else out there help?
L BO
Dish Pro 500 have a built in switch. Make sure your disq setting are right. 119=1 and 110=2. You might need to load a channel list if not already done so.
Home > Message Board > Home Video > Satellite TV > Archive through April 16, 2005 > DISH PRO 500 with Multi Switch LNB [ « Previous ] [ Next » ]
