Thread: Philips 55PP9352 has a slight red tint? |
Paul 001 Unregistered guest |
| Posted on Friday, April 08, 2005 - 08:22 pm: |
Hello. I just bought this Philips 55PP9352 TV and I notice a slight red tint or hue through out the TV except for about 6 inches on each side. Any white looks a little pink and everything else looks a little red, its not too bad but I would rather not have it if it is fixable. Im not familiar with projection TVs and I am wondering if it is something serious or maybe just a simple adjustment that can be done. I have messed with the settings in the menu of the TV but it is consistant no matter what I change them to. Any ideas? |
| Posted on Thursday, April 14, 2005 - 07:04 pm: |
you may need to do a manual convergence if you havent done so already. Hit menu/select then picture option. You have to do the red, blue then the multi convergence for red and blue. |
| Posted on Tuesday, April 19, 2005 - 02:01 am: |
Also have the same problem like you, Have done manual convergence, but it does help. Do anyone know how to go service adjustment. THANK |
