Samsung DVD-HD941 'HDMI AUDIO NOT SUPPORTED' Error Message: A Fix
Username: Larryc
Gahanna, OH United States
For anyone still dealing with this issue, I have good news: Samsung has finally issued a firmware update for the DVD-HD941. I just installed the update, and although it's not mentioned in the release notes, the update does get rid of the annoying "HDMI AUDIO NOT SUPPORTED" message.
Visit the Samsung Web site, download the Zip file, extract the two files, then burn the two files to a CD. Load the CD into the DVD-HD941 and folow the on-screen directions. That's it!
--Larry
Username: Paul_t
Post Number: 74
I still get this message and it takes me around 10 minutes of rebooting the cable box and tv before I get the "handshake". This only happens after we watch a DVD which is connected via component cables, my SA 3250HD is connected via Svideo and DVI but when going back to either after watching a DVD I get this message.. Will this Zip file correct this and does it matter my DVD does not have DVI connections?? Also where at Samsung site is this file? Thank you and boy do I hope this corrects my problem.
Username: Dmwiley
Post Number: 725
Samsung sucks.
