Thread: Panasonic DMREH50, any good? |
New member Username: Yo_goeng
Post Number: 2 Registered: Apr-05
| Posted on Wednesday, April 06, 2005 - 02:32 pm: |
I've decided to get a recorder with built in HDD, not really sure which one is best, but presumed Panasonic wasn't going to be bad. Kinda want a fairly cheap one and saw the new DMREH50 on their website. Can record both formats which sounds great and has 80GB HDD. But £400! 1. Is it any good? 2. Anywhere I can get cheaper online? (UK) 3. If not, what other ones are good for a first time HDD user? Many thanks1 |
Post Number: 3 Registered: Apr-05
| Posted on Thursday, April 07, 2005 - 04:03 am: |
sorry, another really silly question, if i used EP to record on a 4.7GB disc and lets say it was 8 hours long, that disc is fine to play in other dvd players right? it doesn't have to be another dvd recorder does it? the same with LP for 4 hours... that disc will be fine in most other dvd players right? sorry again, complete novice at this! |
New member Username: Rupert
Edegwater,
FL
United States
Post Number: 5 Registered: Apr-05
| Posted on Thursday, April 07, 2005 - 04:07 am: |
YOU R RIGHT |
Silver Member Username: Samijubal
Post Number: 798 Registered: Jul-04
| Posted on Thursday, April 07, 2005 - 02:36 pm: |
I never go over 2 hours when recording. 8 hours would be pathetic quality, I can't stand LP myself. |
Post Number: 6 Registered: Apr-05
| Posted on Friday, April 15, 2005 - 02:06 pm: |
i've finally got my machine now, been recording everything in SP mode. in the dubbing menu, if i don't do high speed recording it gives me the option of recording normal speed in SP, LP etc... if i recorded from my video in SP mode and then burned at normal speed in LP, (obviously it would be slow) but would the quality be still as good as SP or will it be degraded to LP? |
formerly xvxvxvx Unregistered guest |
| Posted on Friday, April 15, 2005 - 06:21 pm: |
It will be LP, no free lunch, DVD-r media is dirt cheap these days. Too cheap to not use SP for your archiving needs. xvxvxvx |
New member Username: Stefano7007
Rome Italy
Post Number: 1 Registered: Apr-05
| Posted on Wednesday, April 20, 2005 - 09:44 am: |
Hi, I'm writing from rome italy. I bought the same panasonic dmr eh50 unit and I am unable to playback on my Sony DVD player a film I burned from the HDD to +R DVD. I checked the sony dvd player technical specs and it says it is able to playback DVD-RAM, DVR-RW, DVD+RW, DVD-R, DVD+R. However I tried and it doesnt work. Are there any settings I must change before burning (dubbing) from HDD to DVD. Which blank DVD format is most compatible??? Thanks |
Post Number: 885 Registered: Jul-04
| Posted on Wednesday, April 20, 2005 - 02:32 pm: |
Did you finalize the disc? |
Post Number: 7 Registered: Apr-05
| Posted on Wednesday, April 20, 2005 - 05:39 pm: |
i think when you are burning to dvd on the panasonic you have to use dvd-r discs. you can play dvd+r discs if they were burnt and finalised from another machine (or computer) but use dvd-r discs and should be ok. (he says, but could be completely wrong!) |
Rome Italy
| Posted on Thursday, April 21, 2005 - 05:01 am: |
Thanks for the help. One last question. What do you mean by "finalize" the disc?? And how is it done? Thanks again.
Post Number: 8 Registered: Apr-05
| Posted on Thursday, April 21, 2005 - 05:33 pm: |
because you have to use dvd-r discs to record on the panasonic, that disc is not compatible with most other dvd players, so you need to finalise the disc so that it can be played on other dvd machines. once finalised then you can't add any more to the disc though. to finalise you press "function" and go to the bottom "Other" and then "finalise" should be right at the bottom i think. anything just ask if i can help, but i'm still a novice myself... |
Rome Italy
| Posted on Friday, April 22, 2005 - 05:03 am: |
Thanks for this extra tip. I'll try again tonight and let you know if it worked out. Ciao |
New member Username: Jerry0
Post Number: 1 Registered: May-05
| Posted on Thursday, May 05, 2005 - 10:26 am: |
How many programs can the Panasonic DMR-EH50 be set to record. How far in advance can it be set to program? \ Thanks, Jerry |
| Posted on Monday, May 09, 2005 - 05:32 pm: |
Hi, I've been looking at the Panasonic DMREH80. It seems quite a good product and i have found it for £318 inc UK delivery from Cheapelectricals.co.uk. My main interest is its capability to be used in conjunction with Sky Digital. Apparently you can select progams to record using the Sky menu a bit like sky+. Has anyone any experience of this side of its functionality? Thanks |
squidge Unregistered guest |
| Posted on Friday, May 20, 2005 - 07:18 am: |
Hi, Panasonic DMR EH50 available for £289 including delivery from Multizone and Prodirect on the net. |
| Posted on Friday, May 20, 2005 - 07:20 am: |
Hi, Panasonic DMR EH50 available for £289 including delivery from Multizone and Prcdirect on the net, has anybody had any dealings with these companies. Thanks. |
| Posted on Friday, May 20, 2005 - 05:38 pm: |
Hi, not heard of Multizone or Prcdirect but cheapelectricals.co.uk are now offering the DMREH50 for £282.99 inc delivery. They have responded to my questions quite well but I have not taken the plunge yet! |
| Posted on Sunday, May 22, 2005 - 06:10 am: |
Hi, I have used multizone three times and found they provide an excellent service |
New member Username: Nickyt
Edinburgh Scotland
Post Number: 6 Registered: May-05
| Posted on Friday, June 24, 2005 - 06:18 am: |
R Peach, you asked about using the recorder in conjunction with Sky digital... I myself have this set-up. I; o select programs from the Sky program guide to add them to the reminder section. Once in the reminder section, I simply add the 'autoview' option which makes Sky change the channel once the program begins. o I then set the recorder timer to record the programs at the specified time (I always allow 10 minutes either side as it's easy to trim out the excess and the adverts) |
Rome Italy
Post Number: 4 Registered: Apr-05
| Posted on Tuesday, June 28, 2005 - 03:37 am: |
Nicola, I agree with you. However there is one little problem with the Autoview and that is that once the channel has changed the autoview banner does not dissappear from the screen until after 5/10 minutes. I suppose that is the reason you allow for 10 minutes before? |
Edinburgh Scotland
Post Number: 7 Registered: May-05
| Posted on Wednesday, July 06, 2005 - 08:07 am: |
Stefano, I set the timer this way to ensure I catch any small changes in the showing times. I would have to set the autoview on an earlier program to make sure I avoided the autoview banner. It's a shame you can't switch the banner off! |
| Posted on Wednesday, August 10, 2005 - 06:56 pm: |
There seems to be quite a few DMR-EH50 owners out there. Anyone who knows how to make the player region free? Paysites are OK if it's certain that they provide unlocking codes. |
Colin Walker Unregistered guest |
| Posted on Monday, August 15, 2005 - 11:50 pm: |
I bought a DMR EH50 6 weeks ago. Fantastic, except for the fact that it randomly (about 3*/hour) loses the picture & sound for about 3 seconds a time. Got it replaced yesterday, the new unit does the same! This happens on DVD, HDD, TV, even pause. It must be in the output because can backtrack on HDD and replay fine. I'm reasonably sure it's not my TV because I used to have cable plugged into same port and had no problems. Does any one have any information? |
| Posted on Thursday, September 22, 2005 - 12:27 pm: |
this player is advertised as "multiregion" in most places....has anyone tried playing a non region 2 disc on it? did anyone get it region free out of the box? or does anyone know how to make it region free? |
New member Username: Gi58
Florida
Post Number: 1 Registered: Sep-05
| Posted on Thursday, September 22, 2005 - 02:15 pm: |
Jorge, On how far in advance you can set the timer: In the US, the DMR-EH50 uses the TV Guide electronic guide, which shows roughly two days of programming at a time, so we can choose only 2 days in advance. However, after selecting a particular program, it's possible to designate it to be recorded every week. Using manual programming and schedule information gotten elsewhere (like a paper guide, or a channel's Web site), there shouldn't be any limit as to how far in advance you set to record. Hope this helps. |
Rome Italy
| Posted on Friday, September 23, 2005 - 03:23 am: |
Yes, I live in Rome, Italy and have played a non Region 2 on it...a dvd I bought, through the internet, from the USA. I'f I remember correctly it will ask you to manually change the settings from PAL to NTSC. Hope ths helps. |
| Posted on Monday, September 26, 2005 - 05:26 pm: |
In the US, the DMR-EH50 uses the TV Guide electronic guide, which shows roughly two days of programming at a time, so we can choose only 2 days in advance. It should populate out to 8 days in advance if you leave the unit off long enough. xvxvxvx |
Bronze Member Username: Gi58
Florida
Post Number: 20 Registered: Sep-05
| Posted on Friday, September 30, 2005 - 10:15 am: |
fx, That's good to know, but how long is "long enough"? The unit has been turned off for as long as 48 hours, but still doesn't show more than 2 days of listings.
| Posted on Friday, September 30, 2005 - 11:25 pm: |
Guy, It could be a local restriction however I've chatted with Panny owners all over the US and every location so far if their gude is populated at all they eventually get 8 days worth. Be advised if you happen to have a programmed recording at the same time daily it could be interrupting the guide data download. If you can stand to do so temporarily disable all your programs in the guide menu for 24 hours or so and see if that helps. The guide data is only broadcast certain times of the day and for different date timeframes within those transmissions. Let me know if this works, xvxvxvx |
Florida
Post Number: 27 Registered: Sep-05
| Posted on Tuesday, October 04, 2005 - 11:30 am: |
fx, As of Sunday night, I had several days of programming listed: Mon, Tues, Wed, Sat, Sun. Weird that it skipped Thursday and Friday, I thought. You must be right about my unit recording during times when the guide is being broadcasted. Well, at least I know it really does get more than 2 days at a time. |
