Home > Message Board > Home Video > Satellite TV > Archive through April 16, 2005 > Can someone help out......
Author Thread: Can someone help out......
Username: Thegame
Miami, Florida
Post Number: 17
i need the keys i have a coolsat4000........i need to know why do i get more channels when someone gives me a coolsat4000 code.....and with the pansat codes i get less channels
Username: Morganlucas
TX
I`m not sure what you can solve your problem on your fta, but in my Pansat 2500 enter the Menu and search for the satellites signas and then I SCAN FOR ALL CHANNELS, and I got more channels that I had before....
Look on you menu to scan satellite channels....
Thats, all I could say.... good luck
Username: Pawnmaster
Post Number: 151
Correct me if I am wrong here but did you not just answer your own question? If you use the correct software you will solve your problems.
Home > Message Board > Home Video > Satellite TV > Archive through April 16, 2005 > Can someone help out...... [ « Previous ] [ Next » ]
