Thread: Burn in with widescreen in 4:3 mode |
Bronze Member Username: Jbecvar
Post Number: 38 Registered: Mar-05
| Posted on Friday, April 01, 2005 - 01:32 pm: |
I just picked up a JVC AV-48WP30 widescreen, and I was wondering that if you watch t.v. in the 4:3 mode all the time, will that cause the sides to get burn in from the grey bars? Also, can anyone recommend a good calibration/repair service in the Kankakee, IL area? |
Bronze Member Username: Sause
Post Number: 44 Registered: Oct-04
| Posted on Friday, April 01, 2005 - 03:39 pm: |
Burn in really only happens when bright images stay still for a long time. |
xvxvxvx Unregistered guest |
| Posted on Friday, April 01, 2005 - 04:45 pm: |
Burn in really only happens when bright images stay still for a long time. This I hope is your version of an April Fools joke. xvxvxvx |
HD Fanatic Unregistered guest |
| Posted on Friday, April 01, 2005 - 05:32 pm: |
Josh, Concerning your CRT bigscreen, if the bars are gray, then there is a possibility of burn in. Some TV's have a setting somewhere in the setup where you can make the bars black. Another work around is to put it in wide (stretch) mode. Personally I do not like that setting since it distorts the picture, but it's better than the possible consequences. |
