Thread: How to change keys..Pansat and Fortec |
| Posted on Friday, March 25, 2005 - 10:46 am: |
How to change Dishnet keys: 00 or 01 press menu go down to parental controls, and press OK press down arrow and enter 0000 thats 4 zeros now go down to nagravision and press ok now press the right side arrow next to the ok button 11 times until it says dish network now press the down arrow 1 time key number should read 00 now now press the down arrow 1 time using the buttons on the remote (number buttons, To type the letters into the new keydata, press the appropriate button on your remote: Audio = A, Info = B, Signal = C, Pause = D, Sat = E, EPG = F) set the key to whatever the latest key code is 8A C4 96 93 EC 79 9D 57...(example only) now press the ok button! then press exit 3x to exit the menu Lastly, on BACK of receiver (not remote)..power OFF,wait 1 minute ,power ON..this is a reset This is how to change your public keys when needed, these instructions should work for both 2300 and 2500 pansats. ............................................................ FOR FORTEC ULTRA: Press MENU on the remote control Then right side arrow to CHANNEL EDIT Go down to CODE, and press OK, and enter 1010 (Could also be 1668 or 1688) Then right side arrow to turn OFF, KEYCODE FUNCTION Go down to NAGRAVISION and press OK Now press the right side arrow next to the OK button 11 times until it says DISH NETWORK Go down to KEY NUMBER, change to 00 Enter the following KEY with your remote control (enter latest key code) 8A C4 96 93 EC 79 9D 57 ...(example only) Now press OK, Now press EXIT once Then right side arrow and enter 1668, this will turn ON, KEYCODE FUNCTION Then press EXIT twice to turn off the on screen menu Lastly, on BACK of receiver (not remote)..power OFF,wait 1 minute ,power ON..this is a reset You are finished, and ready to watch TV. Fortec buttons to use for letters Sat=a info=b tv/radio=c pause=d ?=e |
| Posted on Friday, March 25, 2005 - 01:07 pm: |
I think these Fortec instructions are a little more precise.. Fortec key change method 1)With receiver hooked up to TV and satellite: 2)Press MENU on the remote control 3)Then right side arrow to CHANNEL EDIT 4)Go down to CODE, and press OK, and enter 1010 (could also be 1668 or 1688) 5)Then right side arrow to turn OFF, KEYCODE FUNCTION 6)Go to NAGRAVISION and press OK 7)Now press the right side arrow next to the OK button 11 times until it says ((DISH NETWORK)) 8)Go down to KEY Number, then right side arrow to set to "00". 9)Go down to Key Data and enter the latest KEY with your remote control. D5 6F BB 83 00 D8 B0 4E ...(example only) 10)Press OK, "you will see the STORE button blinking, when it stop you know that KEY Number “00” is saved. 11)Go up to the Key and Go to the right "1 time" (that will change key 00 to 01 12)Go Down and enter latest Key 01 change ..11 B1 AA A7 8B 9E 45 8B (example only) 13)Press OK, "you will see the STORE button blinking, when it stop you know that KEY Number “01” is saved. 14)Press EXIT once. 15)Then right side arrow to turn Code back "ON" and enter "1668" then EXIT, EXIT. 16)Lastly, on BACK of receiver (not remote)..power OFF,wait 1 minute ,power ON..this is a reset Fortec buttons to use for letters Sat=a info=b tv/radio=c pause=d ?=e |
| Posted on Friday, March 25, 2005 - 01:10 pm: |
Latest Dishnet keys KEY 00: D5 6F BB 83 00 D8 B0 4E KEY 01: 11 B1 AA A7 8B 9E 45 8B |
| Posted on Friday, March 25, 2005 - 01:20 pm: |
| Posted on Sunday, March 27, 2005 - 02:06 am: |
Can someone tell me how to enter keys for pansat 2700a. I cannot "down arrow", it makes me enter "old pin" first then "new pin" and "confirm pin" I don't see this "nagravision" option anywhere. Help, tips, advice appreciated... thanks |
