Home > Message Board > Home Video > Satellite TV > Archive through March 29, 2005 > Second Key munber 3/24/05
Author Thread: Second Key munber 3/24/05
Username: Bikerjs
Key 00
D5 6F BB 83 00 D8 B0 4E
Username: 501sw64th
Florida
Thanks for all your help
that works...thx
Username: Bikerjs
no problem
Username: Bikerjs
no problem
MylkyD
Can't say thanks enough.
Username: Justme123
Post Number: 9
Thanks!
Italianos
So, they said the autoroll bin 245 what ever would automatically update the key is that right people or I am misreading the damn thing
Username: Kolive
I have the autoroll bin 245 and still had to input the keys however, I am not getting BEV does anyone know do I need to put in seperate keys for BEV and if so where?
Boston
Jenny..autoroll v245 works for EVERYONE using a Pansat 2500,and something is wrong if U had to input the keys..Bev was not affected AT ALL by these new DISHNET keys..Bev has not changed keys since November 2003!..if U had bev before the key changes,then U will still have Bev now!...U have other problems obviously..
Username: Kolive
Thanks Boston, after your reply I simply turned off receiver then back on and was good to go!
Boston
that is called a reset...U should always do that..in the BACK of the receiver (not remote)
Home > Message Board > Home Video > Satellite TV > Archive through March 29, 2005 > Second Key munber 3/24/05 [ « Previous ] [ Next » ]
