Thread: Pansat 2500a new keys |
Unregistered guest |
| Posted on Wednesday, March 23, 2005 - 12:49 am: |
does anyone have the new key code for pansat 2500a 3/22/05 ? |
| Posted on Wednesday, March 23, 2005 - 07:57 am: |
http://www.dsscentral.ne*t/cgi-bin/hubblegram/CSUpload.cgi?command=viewupload&database=files%2edb Remove the * from the .ne*t link above..copy/paste it (all of it) into your browser...the link is the latest files and keys.. |
i hate boston Unregistered guest |
| Posted on Saturday, March 26, 2005 - 01:13 pm: |
outright scammers STAY AWAY from DSSCENTRAL..PEEPS...this Boston cream ppuff f a g is here to start trouble...LOOSER |
jeeshan Unregistered guest |
| Posted on Saturday, March 26, 2005 - 02:38 pm: |
i just got my pansat 2500a and i dont know how to insert keys because there is no second pin option under parental control. could you please help me. |
Silver Member Username: Jmill1948
Chester,
Va
Usa
Post Number: 589 Registered: Apr-04
| Posted on Saturday, March 26, 2005 - 02:43 pm: |
you need to flash the reciever if you are not getting second pin option.......... |
| Posted on Sunday, March 27, 2005 - 10:44 am: |
Just use the pansat autoroll v245 bin/flash using BLackist's updater...then U never have to change keys again!...the autoroll changes them for you in the future.. Go here for ALL the latest files.. http://dsscommunity.com/forums/viewtopic.php?t=3119 and download this file..its v245 bin with the BL updater and Gtools (optional)and an EASY README to follow.. Pansat 2500 Software Updater & Bin.zip (size: 731.8 KB last modified: 03-23-2005 ) 2500a bin 245 |
