Thread: RCA DTC 210 Receiver with VCR HELP |
New member Username: Sept29
Post Number: 1 Registered: Mar-05
| Posted on Sunday, March 20, 2005 - 01:57 pm: |
Have Direct TV with RCA 210 receiver. Am trying to get the receiver to control a VCR via a IR emitter. Sony, JVC, Mitsubishi VCRs do not work, Synphonic (junk) does work. Any one have a VCR connected to this receiver with sucess? What make and model? |
Silver Member Username: Dmwiley
Post Number: 153 Registered: Feb-05
| Posted on Monday, March 21, 2005 - 11:05 am: |
I have a Sony DVD recorder hooked up to the RCA DTC210 and obtain excellent recordings. However, I do not use the "IR emitter" but seperately program the recorder. You may need to contact RCA. |
Unregistered guest |
| Posted on Tuesday, April 26, 2005 - 12:10 am: |
I also have an RCA-210 Satellite receiver and the VCR control isn't working on mine either. I've tried a JVC and a Sony VCR. I also plugged in an IR emitter cable from a Sony receiver (the plugs are compatible) and that doesn't work either. RCA obviously has a problem. I bought mine on eBay ("new in the box") but I doubt if they'll honor the warranty. |
