Home > Message Board > Home Video > Satellite TV > Archive through March 20, 2005 > Password recovery for a 301, already ...
Author Thread: Password recovery for a 301, already tried methods
Username: Moogle
hi, i'm pretty new, i already tried LK's instructions from another thread
DP 301, 3100
With your remote control, press "menu", then "6" (system setup),
then "3"(diagnostics), now press "info", then "right", then "left"
you should be in the Memory Dump Page now,
scroll down (press "down") to line NVM 0320,
look to the 2nd column on right, your 4 digit password should be there,
seperated by 3's
For example, if your password is 9999, the number should look like
this: 39393939........
the problem i'm getting is, when i get to the diagnostics screen, i press info, it just brings up info about that screen, mainly what all the options do, for example what dial out and phone check etc do,
so when i press browse and theme, nothing is happening, i cant get to the dump screen
what am i doing wrong here? help me out please
Username: Caly
Post Number: 7
hello i would wanna know some info about how the pansat 2500A works - for example when u buy it does it have auto roll ? does it have the software installed ? anyone wanna help me tnx if u wanna chat contact me on messenger at calin_olariu2001@yahoo.com or calin_olariu2001@hotmail.com ok i am gonna wait for somebody to answer me
LK
Chris...go to www.dsscommunity.com/forums ...ask/copy same question/post in Dishnet/bev "getting started" area...U will get some help there..can also use the "help Chat" area at bottom of page there at the forums at dsscommunity..very friendly helpful peeps there
LK
or you can go to www.hashhu.com ....the website I posted above is ran by idiots, so you might want to use this one...sorry for the confusion Chris
Username: Moogle
alright thanks for the help LK,
i will try your suggestions
Home > Message Board > Home Video > Satellite TV > Archive through March 20, 2005 > Password recovery for a 301, already ... [ « Previous ] [ Next » ]
