Home > Message Board > Home Video > Satellite TV > Archive through March 29, 2005 > Lastest Pansat2500 Autoroll bin
Author Thread: Lastest Pansat2500 Autoroll bin
LK
Located at www.dsscommunity.com/forums ..."File Share" area...(FTA link) at bottom of page...this file did autoroll on 3-17,when last key change,therefore U still had TV and Dis NOT have to manually change the keys,if U used this bin..READ the README in the zip file ..
2500a_AutoRoll-v031205.zip
(size: 348.9 KB last modified: 03-18-2005 )
2500a_AutoRoll-v031205 v245
BTW..here was a suggestion posted for some who had difficulty with this bin..
Bin 245 will autoroll... here are a few things you could try:
1. Try changing the channel and wait for downloading % sign to appear.
2. If the % sign takes a long time then try turning the channel to a "regular channel" such as USA (105) and not HBO or Cinemax (the autoroll % seems to go faster).
3. Go into MENU and parental control, and then into the next screen and hit..set default keys..exit out.
LK
BTW...thw Pansat 2700 latest autoroll bin is there too..
SAD LITTLE SPAMMER GO HOME
PEOPLE IF YA WANT REAL INFO FROM REAL SITES WITH THOUSANDS OF MEMBERS GIVE THIS A SHOT AND STOP GETTING THE BUM STEER FROM A WANABE MOLE
how about sending people to a real landing page they can bookmark and get all the latest info right away instead of you putting peeps in a loop?
BAD HELPER!!!
for some no BULL info and a choice of the top sites try here
REALY BIG SITES
LK
that is a good link U provided..I am ONLY stating where to get the latest V245 working autoroll bin..especially at a time like this when U can't get into some of the Larger sites that U have in YOUR link!...so kiss off pal!..aka Gordo,kneegrow,analman,Larry D,anon,Ecoustics mod etc..
dsscommunity is a dave ip logger
Username: Bobs35
Post Number: 9
I loaded it worked fine for dishnet but took out bev any suggestions?
This new little program that get the keys instantly. you can download it and keep it on your desktop. this and much more can be found in the fta files section of hashu. FTA INFO
Home > Message Board > Home Video > Satellite TV > Archive through March 29, 2005 > Lastest Pansat2500 Autoroll bin [ « Previous ] [ Next » ]
