Home > Message Board > Home Video > Satellite TV > Archive through March 29, 2005 > BIN 245 for Pansat 2500a works for 11...
Author Thread: BIN 245 for Pansat 2500a works for 110 + 119 and kills everything else
Anyone experiencing the same problem on autoroll?
Username: Bobs35
Post Number: 8
yes i am also. bev keys are valid can't get it blind scan either
Autoroll2700A
The new autoroll bin for pansat 2700A works fine on one sat and when i try to select a channel from a different sat, it freeze and i have to reset the mechine by turning it off in the back. Is anyone experiencing the same thing? It happens all the time when i switch channels between sat 110 and 119.
This new little program that get the keys instantly. you can download it and keep it on your desktop. this and much more can be found in the fta files section of hashu. FTA INFO
Home > Message Board > Home Video > Satellite TV > Archive through March 29, 2005 > BIN 245 for Pansat 2500a works for 11... [ « Previous ] [ Next » ]
