Thread: Fortect Lifetime Ultra No Code option |
New member Username: Pkaayaa
Metuchen,
NJ
Post Number: 1 Registered: Mar-05
| Posted on Friday, March 18, 2005 - 02:32 pm: |
Need help! please. I don't have an option for "Code", for step 3... in following the steps below. STEP 1-PRESS: M E N U STEP 2-FIND CHANNEL EDIT (ARROW RIGHT UNTIL YOU SEE CHANNEL EDIT AT TOP) STEP 3-ARROW DOWN UNTIL YOU HIGHLIGHT CODE AND PRESS: O K STEP 4-FOR PASSWORD ENTER: 1010 STEP 5-ARROW DOWN AND HIGHLIGHT NAGRAVISION AND PRESS OK STEP 6-PRESS RIGHT ARROW 11 TIMES (YOU WILL SEE DISH NETWORK) STEP 7-PRESS DOWN ARROW 1 TIME STEP 8-PRESS LEFT ARROW 1 TIME (YOU WILL SEE KEY 01) STEP 9-PRESS DOWN ARROW 1 TIME (YOU WILL SEE A SERIES OF NUMBERS AND LETTERS STEP 10-ENTER THIS NUMBER 01 C5 FB 21 37 B6 C0 5E INTO THIS AREA, (IGNORE THE LAST 4 NUMBERS). STEP 11-PRESS: OK TO SAVE THIS NUMBER TO MEMORY STEP 12-PRESS: EXIT UNTIL BACK TO TV CHANNEL. YOU ARE DONE. |
| Posted on Friday, March 18, 2005 - 09:55 pm: |
need new key for pansat2500a |
| Posted on Saturday, March 19, 2005 - 08:42 pm: |
I would see waht people are saying first fortec |
| Posted on Saturday, March 19, 2005 - 08:45 pm: |
Bev/bell has NOT changed Keys since November 2003....and I have posted those keys here at numerous places..also KEY changes APPLY to ANY FTA receiver...all the same,make-model makes no difference Current BEV/ Bell Keys AUX0 is active, changed Tue Nov 18 20:00:00 2003 AUX0: 82 D7 51 E4 5B 97 9D 81 AUX1: 65 57 46 14 36 02 D8 DA The Dishnetwork Keys work on ALL makes/models of FTA receivers...Pansat..Fortec etc.. Current Dish Keys KEY1 is active, changed Thu Mar 17 17:00:00 2005 KEY0: F0 C9 59 D8 7F 8D 34 13 KEY1: 0B 51 9E B7 EB 20 E7 4D BTW...here's where/how to get and use BOTH the Pansat 2500 and 2700 autoroll bin v245,which does work..its in this linked thread below..READ! http://forum.ecoustics.com/bbs/messages/2/127878.html If missing channels after a Key change install,..always shut power OFF on BACK of receiver,unplug,wait 1 minute,plug ,turn back ON..if that doesn't fix it,then do a AUTOSCAN (or can add new channel list using Gtools 1.86) via the remote in your installation setup again. |
| Posted on Saturday, March 19, 2005 - 11:28 pm: |
What do i do with this? |
Unregistered guest |
| Posted on Monday, March 21, 2005 - 04:26 am: |
why dont i have a code box under channel edit for fortec ultra please respond |
Metuchen,
NJ
Post Number: 4 Registered: Mar-05
| Posted on Monday, March 21, 2005 - 11:15 am: |
Pgg1, I had the same problem. I bought a brand new Fortec star which doesn't come with the street firmware. You need to go and find a new bin file and load using the serial cable. the File can be found .... Read and read....
| Posted on Tuesday, March 22, 2005 - 07:29 pm: |
Does anyone have the new key for fortec star free to air reciver. |
