Home > Message Board > Home Video > Satellite TV > Archive through March 29, 2005 > Pansat 2500a
Author Thread: Pansat 2500a
xtk
i have a pansat 2500a,,, and yestarday i put the new march keys (both 01 00) and evrything was going fine but when i try to see any channel it appears this messeage: PLEASE WAIT FOR PICTURE.... and it never quits my signal is 89% and my quality is almost 97% i dont know what could it be the pr0blem..
thanks for your time
LK
afeter exiting 3x when completeing the new keys,then reset the receiver...power OFF on BACK,unplug,wait a few minutes.then Turn back on..
Username: Truth_seeker
Please advise me as to what is the original "PANSAT COMPANY" that produces these PANSAT RECEIVERS?
WHAT is the best internet site to purchase a "PANSAT RECEVER"?
That is where can you obtain the "BEST DEAL when purchasing a PANSAT RECEIVERS?
What is the difference between "BLIND SEARCH" and "SMART SEARCH"?
What is the difference from "PANSET RECEIVERS" and "COOLSET" and ETC?
go here
Pansat 2500a
hey...i have a problem..i recently bought tha quantum 3000 which ive been told is the one after the pansat. alright..so i got the codes from a friend...put um in or w.e. and i go to see the channels and it says scrambled or bad channel. Now...is this because i dont have the multiswitch? is that really needed? must it be a dish antenna? plz help!! thanks!!
Home > Message Board > Home Video > Satellite TV > Archive through March 29, 2005 > Pansat 2500a [ « Previous ] [ Next » ]
