Home > Message Board > Home Video > Satellite TV > Archive through March 16, 2006 > Pansat and fortec new key codes and f...
  Thread Last Poster Posts Pages Last Post
Archive through February 15, 2006Rob Hart100 2006-02-15  00:10 ET
Archive through February 06, 2006Anonymous100 2006-02-06  16:23 ET
Archive through January 23, 2006GAP100 2006-01-23  09:17 ET
Archive through January 09, 2006LK100 2006-01-09  09:35 ET
Archive through December 21, 2005Mr. Bean100 2005-12-21  10:10 ET
Archive through November 23, 2005anonymously yours100 2005-11-23  14:18 ET
Archive through November 08, 2005h3lt3r_sk3lt3r100 2005-11-08  17:27 ET
Archive through September 22, 2005john kratz100 2005-09-22  21:33 ET
Archive through September 09, 2005Njrx795 2005-09-09  21:06 ET
Archive through August 26, 2005Anonymous100 2005-08-26  12:40 ET
Archive through August 17, 2005Maple Leaf100 2005-08-17  19:21 ET
Archive through August 05, 2005AEL100 2005-08-05  20:35 ET
Archive through July 15, 2005can't tell you100 2005-07-15  23:00 ET
Archive through July 05, 2005Anonymous100 2005-07-05  00:11 ET
Archive through June 28, 2005ELROLO100 2005-06-28  12:39 ET
Archive through June 22, 2005eral100 2005-06-22  20:48 ET
Archive through June 15, 2005Anonymous100 2005-06-15  19:24 ET
Archive through May 30, 2005Anonymous100 2005-05-30  18:31 ET
Archive through May 09, 2005Jose Bautista100 2005-05-09  09:10 ET
Archive through April 25, 2005Brandy100 2005-04-25  13:16 ET
Archive through April 18, 2005Farid Ali100 2005-04-18  22:38 ET
Archive through April 11, 2005d.j.f100 2005-04-11  18:42 ET
Archive through April 05, 2005someguy100 2005-04-05  02:51 ET
Archive through April 01, 2005Anonymous100 2005-04-01  18:47 ET
Archive through March 29, 2005minh100 2005-03-29  06:14 ET
Archive through March 25, 2005derrick sutton100 2005-03-25  09:52 ET
Closed Closed: New threads not accepted on this page
Author Thread: Pansat and fortec new key codes and flashes. all you need to know
Username: Zainmalik
Calgary, Alberta
guys keys for n-1 for dish net work plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz z
Relevant Product Info
TripleB
@RobHart,
Download the bin file from www.dsstester.c*m its posted under the Fortec Files section. I believe its the second fortec file from the top. This should get your receiver working again. Its obviously not set up to accept N2 key codes.
TripleB
@RobHart,
The file is called:
Al7bar FTA Ultra_140206_291t_api(NTSC) new keys.bin (640KB)
Do you know how to load a new bin file onto your receiver?
If not, I believe you're SOL until you learn, or get someone who knows to do it for you.
chris7777
IS YOUR DISH DOWN?
send me $5.00 through www paypal . com and i will fix your dish
my files are not the same bullshit that works for a week then goes down ..i program my own files and i guarantee them for 60 days min.
send payment to chrisaldridge7777@hotmail.com through paypal and you will recieve the proper fix for your dish along with complete instructions on how to fix your dish. Please include what model reciever you have to ensure the right fix is sent. using files you find on these free site can fry your reciever more often than not why not pay a small price for guaranteed piece of mind
vancouverman
Hey rob hart
go to parental control...go to second pin ..put in your pin..if no pin..thens its 0000. Go to Nagravision and press ok. Once there press right twice and you will dishnet. Go down to Key number and left top u see Nagravison 1. Press right twice and you will see Nagravision 2. Go down and input first set of codes and press OK and see Store Highlite. Go back up to Key number and press right once for key number 01 and put in second key and press ok and notice store highlite again. EXit and exit and exit.
I have put the new key code(s) in in many different ways but my Pansat 2500 is not coming back on. The key codes I've used are posted as
N2 00:9E.5B.7A.77.C0.FE.91.CA
O1:4D.2A.DC.33.D4.CD.E3.75
AND
01:FB.D9.F2.D9.D6.C9.EF.7A.
57.AD.32.24,67.42.6C.E6
The 01 keys are the old set received in January. What is happening? Do I now need a professional to input the key codes. I do not have a laptop therefore I cannot go directly into my Pansat. I don't know how to change the bin or what a bin is. When I try to pull up the information via zip I can't access this program. Help is needed from you.
Thanks
Username: Lklives
Post Number: 693
ECHOSTAR KEYS N2 ...From Keymaster Utility
Updated: Tuesday, February 14 2006 at 9:35 PM
Dish Network:
N 0101 00:.... *New Active Key
9E 5B 7A 77 CO FE 91 CA
4D 2A DC 33 D4 CD E3 75
N 0101 01:
BD E1 CA 94 04 E7 C3 D5
A9 A1 C9 2F E4 B6 37 27
lllllllllkllllll
LK where is the answer to my questions man ??? i need to program so i need an answer from sowmebody
thanx
Username: Lklives
Post Number: 714
yes...and read bin description so u don't use a killer bin..and don't DEMAND from me or U will get NADA...
lllllklllllll
LK sorry man im not trying to be demanding or anything. im just asking im new to this so im just trying to get some help from u cuz u know what ur talking about... if u dont mind telling me im wondering if my channels are already organized to i only load the new bin or i have to load Gtools ??? is Gtools just a tool to Load the channel or whats the exact function ? and whats is the Channel Master ???? Thank you
Username: Lklives
Post Number: 718
Gtools and channel master are for various uses with channel lists..if U already have channels, then just load the bin (set the default key if its an autoroll bin)...sometimes a scan of satellites is required every week or so..or blind scan ot TP scans because Dishnet moves channels around to diffrent TP's and satellites..
BTW..most use Channel master instead of Gtools now...but majority do scans instead of channel lists too..
IF U had read for 10 minutes at a DSS site U would know this..
Username: Jmill1948
Chester, Va
Usa
Post Number: 758
Hey guys, maybe someone could tell me, I have the Pansat 2500A and I guess the recent nagra 1 code just went out...if you could, could someone please tell me the new updated code? thanks guys...
Username: Lklives
Post Number: 727
crackhead!...or very stupid!
06
Lk if the reciever has a Loopback in the back of it. can u hook two recivers through that ??? and get all satellites working ??? im thinking that would elimintate the need for me to have run wires again ?? please tell me if it will work
hey ppl
i've just learned about this site from a friend and now i have one problem. when i enter in the keys for nagravison...the fukin F key doesn't work. can anybody help me on this...thankz
Username: Babakhan
Post Number: 64
which one dishnet or bev and wut receiver u got ?
i got something like fortec star
Username: Chem
Nina, all NBA TV do not work
Username: Babakhan
Post Number: 66
Well for Dishnetwork Nagra 2
These keys are working now.
00: 9E 5B 7A 77 C0 FE 91 CA
01: 4D 2A DC 33 D4 CD E3 75
For Bell ExpressVu
00: 47 77 F3 36 25 5B 59 A0
01: 77 60 58 35 7F DA F2 06
06
anybody knows about the loopback ?
Username: Sml
LK Thanks for the info in the past. Do I need to load the factory flash for 2700a every time add new bin? Also, heard that the orasat 5 didn't have any problems with auto-roll recently. Could I use a orasat 5 with dish netwk??? up and runing!
Thanks!
UMEHYE
Hi, those keys aren't working for BEV? I tried a few times. Can you give an update? Keymaster show keys from 4 DAYS AGO???
Thanks
UMEHYE
Never mind, I figured it out myself. The WORKING KEYS FOR BEV ARE:
Key 0: 47 77 F3 36 25 5B 59 A0
Key 1: 22 ED 5A 0B 50 C2 D8 E4
46 5F E3 27 EA 6F F3 C7
Username: Babakhan
Post Number: 68
Bell ExpressVu (Last Update: 2006/02/11 14:30 CST)
00:22 ED 5A 0B 50 C2 D8 E4
01:46 5F E3 27 EA 6F F3 C7....active
i have foretec lifetime ultra receiver
i try to put keys
9e 5b 7a 77 c0 fe 91 ca
4d 2a dc 33 d4 cd e3 75
still not working ten i try to download bin file then i received "update fail er1" message and one help me on this
i have pansat 2500a i need the gtrom loader or code please
Username: Klules
Hi,
Anyone knows where I can get the latest file of new code for FortecStar lifetime Ultra?
Thanks
Username: Rostam
Is the keys for N-1 and N-2 is the same for dish net. I have a Pansat 2700a I tried below keys and it is not working. I only have Nagravision on my list to select from.
Can someone help please?
Username: Rostam
All,
What is the keys for Nagra-1 please for dish net on Pansat2700a please?
Username: Lklives
Post Number: 741
what a bunch of tards..correct codes are here....same keys for all receivers...U clowns just are too stupid to know how to use your own receivers and manually input these keys..
and Ultra owners ,use the same bin 256T, just input new keys!
Username: Terryhhh
oi I may be a tard but f%$#in f key wont register help...PLEASE AND THANK YOU!! terryhhh@canada.com
06
i asked no answeres yet !! if the reciever has a Loopback in the back of it. can u hook two recivers through that ??? and get all satellites working ??? im thinking that would elimintate the need for me to have run wires again ?? please tell me if it will work ? i have two recievers but i only have wires running from my satellite for only one reciever... so is it possible to run wire between the 2 recievers through the loopback
vancouverman
Current DISH Network NagraVision 2 Keys
IDEA KEYS: 02/14/06
Dish IdeaKey 00 (86): 9E 5B 7A 77 C0 FE 91 CA 4D 2A DC 33 D4 CD E3 75 <--Active
Dish IdeaKey 01 (96): FB D9 F2 D9 D6 C9 EF 7A 57 AD 32 24 67 42 6C E6
00: FB D9 F2 D9 D6 C9 EF 7A
01: 57 AD 32 24 67 42 6C E6
Dishnet & other providers can swap back and forth from one key to the other. If one does not work...try the other
Dish & other providers CAN also, and sometimes WILL run both keys active where some channels such as pron would work with one key, and the other channels with the other active key
• Most FTA's use the old N1 key spots in firmware, So they split the 16 byte key into two 8 byte keys.
• These aren't accurate as Key00 and Key01 but rather are halfs of the active key
• Your more current stb flashes will support both keys for each provider now.
vancouverman
Bin270 is like superman
Username: Tango
i have a fortec with a 282 bin. anyone knows if the new keys work or do i need to flash it again, and is the 291 bin clone safe?
I HAVE FORSAT 2500 ULTRA IN WHICH THERE IS ONLY NAGRAVISION 1. CAN NAGRA 2 KEYS WILL WORK OR THERE ARE OTHER KEYS .THANKS
Username: Viper79
Scarborough, Ontario
Hi, I have Pansat 2300 clone and programming got busted and wondering how would I be able to make it work again.
szumilas
I have a Fortec Star Lifetime ULTRA, but i dont have Nagravision 1 or Nagravision 2 on it....just plain Nagravision and the dish network keys dont work on it....can someone please help me?
Is there anyway to get local channels along with Dish channnels?
Locals
Scan all.But a lot of the locals are on 121w.
The easy way
You could put up a good areial antenna.
Username: Srii
Toronto
I also have a Fortec Star Lifetime ULTRA, nto working,, can someone help to get the keys ppllsssaass
hello
is it possible to watch supersport channels on fortecstar ultra
hello
Username: Mikell7171
Im new to this and ive been reading alot about the pansat i would like to know if you can get dish network without any flashs or bins?
Ann124
Hi there,
I am confused as to what serial cable I need for my FORTEC ULTRA receiver. If anyone could help, it'd be greatly appreciated.
Thanks.
=l ;(
Hey michael.NO YOU CANT.
Username: Lklives
Post Number: 775
Ann..straight Rs232 cable with DB9 female ends
Username: Murcek
somebody help me here
i got clone 2500, got bin 258 on it,i don't want autoroll 271.but i have no signal and when i do sat scan it says no transponder found.
now
