Thread: Reinstall echostar package? |
Bronze Member Username: Djgo_42
Post Number: 14 Registered: Feb-05
| Posted on Sunday, March 13, 2005 - 11:50 am: |
When trying to find sat 119 and I thought I found it, I did a full scan and it ended up to be Bell Expressvu. Now when I turn on the echostar package , I get Bellexpressvu coming up on the bottom on the screen. Is this bad? Should I rescan with Gtools and echostar package? Any advice would be appreciated. |
| Posted on Sunday, March 13, 2005 - 12:59 pm: |
U don't have correct satellite..read the readme with the echostar package (select dishnetwork)...and make sure your dish is aligned to the 110 and 119 |
| Posted on Sunday, March 13, 2005 - 01:16 pm: |
Rooms:#pansat or #fta Included files : ---------------- [1] X-85BL_050104_240_api(N).bin [the bin file] [2] EchoStarPackage.gtd [recomended sgtools channel list] [3] 2500A_040607_222_api(N).bin [original pansat bin] [4] Readme.txt [this file] Purpose : --------- The main purpose for this flash is to give you, the user a way to have your ird conform to the dishnet channel listings. This flash creates a new sat in your [sat key] info. This new listing is called, "echostar package". You will be able to press your Sat on the remote, choose the "Echostar package" and have channels come up just as on a dishnet ird.. ie.. 300 will be HBO East, 122 will SciFi Channel, etc. Recomended Procedure : ---------------------- Take the blacklist updater version 1.4 and dowload to your ird, the included 2500A_040607_222_api(N).bin. Next, Download the new flash 2500A_040607_222_api(N).bin also included in this zip file. NEXT, PLEASE CHOOSE, either you can scan your sats or put on a channel list. One or the other... don't do both. We have also included a channel list, X-85BL_050104_240_api(N).gtd. Use SGTools 1.86 to download that file into your 2500 after you have completed your flash. Proceed to the parental controls, "second pin", and enter with 0000. go to "Set Default Key" and press "OK" on your remote. Wait for it to save and exit out to the TV Screen. Now on your remote, hit your sat button. You will see "Echostar Package". Hit the "ok" key, and enter that channel list. Your channel list is imported into there and you can proceed to watch tv. You will find that pressing your key numbers, say, 122 will bring you to scifi channel and so forth. there you have it... If you are NOT USING A CHANNEL LIST. Simply set up your ird as you normaly would. Choose language and go into setup. Antenna set up is done just as you normally would. Next, after your sats are set proplerly.. do a BLIND scan of each. Proceed to the parental controls, "second pin", and enter with 0000. go to "Set Default Key" and press "OK" on your remote. Wait for it to save and exit out to the TV Screen. Now on your remote, hit your "sat" button. You will see "Echostar Package". Hit the "ok" key, and enter that channel list. Your channel list is imported into there and you can proceed to watch tv. You will find that pressing your key numbers, say, 122 will bring you to scifi channel and so forth. Remember, do one or the other. Regards, Blacklist |
| Posted on Sunday, March 13, 2005 - 01:36 pm: |
to align your dish to the correct satellites U want.. http://forums.al7bar.tk/showthread.php?t=44114 |
| Posted on Sunday, March 13, 2005 - 01:58 pm: |
read this too.. http://forums.al7bar.tk/showthread.php?t=24301 and this is GREAT link for all types of various questions..read this. http://forums.al7bar.tk/forumdisplay.php?f=30
New member Username: Jderek
Post Number: 8 Registered: Mar-05
| Posted on Sunday, March 13, 2005 - 08:33 pm: |
LK..Im really confused now. At the form athttp://forums.al7bar.tk/showthread.php?t=44114 about Gtools and your post above are different. This is what I did. 1. downloaded loader 2. did a factory flash 3. then the 240BL bin 4. then opened Gtools and loaded Echostar package 5. then went to satellite and got 90% quality **** the initial instructions I used said..now select scan all but your post says to hit the sat button and pick echostar package. So by scanning sat 110 means I cannot pick up 119 channels? Would it really make a difference? Should I start over and do the factory flash..etc. Thanks DJ |
| Posted on Sunday, March 13, 2005 - 08:52 pm: |
My instuctions (copy/paste) is written by Blacklist ...he is the author/writer/coder who made the flashs,bins ,downloaders and echostar package..Nobody knows more than him!....see the BL in all bins and flashes file names,that BL = BlackList!...just do as Blacklist instructs.. BTW...his instructions are for 2 methods...using the scan...or using a channel list with Gtools..U can do either,your choice |
Post Number: 9 Registered: Mar-05
| Posted on Sunday, March 13, 2005 - 09:04 pm: |
LK...thanks.. One last newbie question..when I load the echostar package I selected sat110 and 119 and all these channels are listed. So is that why I don't have to scan because they are already in the receiver? Hopefully this will allow me to find that 119 sat...I know your instructions to move it over one inch are correct but I continued to get only 110 and not 119. Well , hope you have a great week and get the rest of your motor fixed...I'll give it a try next weekend ...thanks again DJ the newbie |
Unregistered guest |
| Posted on Sunday, March 20, 2005 - 12:12 pm: |
Hi, My 501 gave me the message : " A serious problem has been detected in your receiver" - the TSOP wasn't back-up while I read the box key thru Jtag. Is there any solution without the TSOP back-up. Thanks in advance. Delince |
| Posted on Monday, March 21, 2005 - 01:54 am: |
I have a Pansat 2500A. How would i find out what sat im positioning at on the Pansat receiver? Currently i get about 89%-90% in quality and im pointing my sat to the south. |
davemoledick Unregistered guest |
| Posted on Monday, March 21, 2005 - 02:18 am: |
Registration Service Provided By: Contact: Visit: Domain name: DSSCOMMUNITY.COM Registrant Contact: Whois Privacy Protection Service, Inc. Whois Agent (sxxhbndrbr@whoisprivacyprotect.com) +1.4252740657 Fax: +1.4256960234 PMB 368, 14150 NE 20th St - F1 C/O DSSCOMMUNITY.COM Bellevue, WA 98007 US Administrative Contact: Whois Privacy Protection Service, Inc. Whois Agent (sxxhbndrbr@whoisprivacyprotect.com) +1.4252740657 Fax: +1.4256960234 PMB 368, 14150 NE 20th St - F1 C/O DSSCOMMUNITY.COM Bellevue, WA 98007 US Technical Contact: Whois Privacy Protection Service, Inc. Whois Agent (sxxhbndrbr@whoisprivacyprotect.com) +1.4252740657 Fax: +1.4256960234 PMB 368, 14150 NE 20th St - F1 C/O DSSCOMMUNITY.COM Bellevue, WA 98007 US Billing Contact: Whois Privacy Protection Service, Inc. Whois Agent (sxxhbndrbr@whoisprivacyprotect.com) +1.4252740657 Fax: +1.4256960234 PMB 368, 14150 NE 20th St - F1 C/O DSSCOMMUNITY.COM Bellevue, WA 98007 US Status: Active Name Servers: ns1.dsscommunity.com ns2.dsscommunity.com |
davemolespotter Unregistered guest |
| Posted on Monday, March 21, 2005 - 02:20 am: |
Registration Service Provided By: Contact: Visit: Domain name: DSSCENTRAL.NE*T Registrant Contact: Whois Privacy Protection Service, Inc. Whois Agent (vdqmxnpks@whoisprivacyprotect.com) +1.4252740657 Fax: +1.4256960234 PMB 368, 14150 NE 20th St - F1 C/O DSSCENTRAL.NE*T Bellevue, WA 98007 US Administrative Contact: Whois Privacy Protection Service, Inc. Whois Agent (vdqmxnpks@whoisprivacyprotect.com) +1.4252740657 Fax: +1.4256960234 PMB 368, 14150 NE 20th St - F1 C/O DSSCENTRAL.NE*T Bellevue, WA 98007 US Technical Contact: Whois Privacy Protection Service, Inc. Whois Agent (vdqmxnpks@whoisprivacyprotect.com) +1.4252740657 Fax: +1.4256960234 PMB 368, 14150 NE 20th St - F1 C/O DSSCENTRAL.NE*T Bellevue, WA 98007 US Billing Contact: Whois Privacy Protection Service, Inc. Whois Agent (vdqmxnpks@whoisprivacyprotect.com) +1.4252740657 Fax: +1.4256960234 PMB 368, 14150 NE 20th St - F1 C/O DSSCENTRAL.NE*T Bellevue, WA 98007 US Status: Active Name Servers: ns1.dsscommunity.com ns2.dsscommunity.com Creation date: 03 Dec 2000 09:33:22 Expiration date: 03 Dec 2005 09:33:22 |
jethro tull Unregistered guest |
| Posted on Monday, March 21, 2005 - 10:45 am: |
whats point?..2 sister sites...notice they are not new and been around AT LEAST 5 years...not some NEW fly by night scam sites! |
New member Username: Viga1197
Rochester,
Ny
Usa
Post Number: 1 Registered: Mar-05
| Posted on Tuesday, March 22, 2005 - 12:29 pm: |
Hi LK I M new in this room . I would like you to have me out I have pansat 2500a I use dish 18" the only one I get Echostar 7 110W.I try to get 119W but I can not have . Lk please tell me what to do or any advice would be appreciated thanks |
