Thread: Pansat and Fortec Key Change Guide |
| Posted on Friday, March 11, 2005 - 07:42 pm: |
Tuesday, March 8 2005 KEY00 CHANGE How to fix: press menu go down to parental controls, and press OK press down arrow and enter 0000 thats 4 zeros now go down to nagravision and press ok now press the right side arrow next to the ok button 11 times until it says dish network now press the down arrow 1 time key number should read 00 now..or change to 01 (if change to Key 01) now press the down arrow 1 time using the buttons on the remote (number buttons, To type the letters into the new keydata, press the appropriate button on your remote: Audio = A, Info = B, Signal = C, Pause = D, Sat = E, EPG = F) set the key to whatever the latest key code is 8A C4 96 93 EC 79 9D 57 now press the ok button! then press exit to exit the menu This is how to change your public keys when needed, these instructions should work for both 2300 and 2500 pansats. ............................................................ FOR FORTEC ULTRA: Press MENU on the remote control Then right side arrow to CHANNEL EDIT Go down to CODE, and press OK, and enter 1668 (Could also be 1010 or 1688) Then right side arrow to turn OFF, KEYCODE FUNCTION Go down to NAGRAVISION and press OK Now press the right side arrow next to the OK button 11 times until it says DISH NETWORK Go down to KEY NUMBER, change to 00 (or 01 if Key 01 has changed) Enter the following KEY with your remote control (enter latest key code) 8A C4 96 93 EC 79 9D 57 Now press OK, Now press EXIT once Then right side arrow and enter 1668, this will turn ON, KEYCODE FUNCTION Then press EXIT twice to turn off the on screen menu and you are finished, and ready to watch TV. Fortec buttons to use for letters Sat=a info=b tv/radio=c pause=d ?=e |
Unregistered guest |
| Posted on Thursday, March 17, 2005 - 05:52 pm: |
latest keys for pansat 2500a. |
