Home > Message Board > Home Video > Satellite TV > Archive through March 20, 2005 > Channel Lists
Author Thread: Channel Lists
How does one edit a channel list to match there setup? eg. list is 110-119-91 need to set it up as 91-110-119. Also how do you change a file format eg. into a pdf. or .bin etc. any help would be much appreciated. thanks
I put up a simple directory that should help you find what you need SATELLITE TV SUPPORT
Thanks but sending me into a blind site does not answer my question. So if it is not too much trouble maybe someone could give me a decent answer. thanks again
Username: Allic
Post Number: 71
A SIMPLE MAPPING OF YOUR CHAN LIST IN GTOOLS IN RE: TO THE DISQUE CONFIG WILL DO IT. RIGHT CLICK ON THE CHAN LIST IN GTOOLS WHEN LOADED AND YOU SET THE DISCQE SETTINGS TO 1,2,4 ECT..
HOPE THIS HELPS.
LK
anon..those "blind sites" are the biggest,best,most knowledgeable people in the world..this site here is like TBALL compared to those blind" MAJOR league sites..I would use them!
If U had used them,or even did SOME reading here U would have found your answer too..here happy St Patrick's day!
The best channel edit tool I have found is called: CHANNEL MASTER, you can download it from the FTA files and install it to your computer and open any channel list you have downloaded or uploaded from your receiver and edit it to your liking and then download it back into your receiver using Gtools.
Thanks guys this should help solve the problem. Are the gtools and channel master compatible with all ch. lists or are they designed to just work with pansat. Sorry Lk it's just so hard finding info sometimes,and when someone sends you in blindly, you get frusterated. What I've noticed is alot of peeps are afraid to ask simple questions for fear of being ridicued. That's just the way it is at respected sites. No one has patience anymore.Anyways guys thanks again.
LK
No there are channels lists for all FTA receivers..U will get flamed for NOT reading and asking a FTA basic 101 question that has already been answered 100x...but not for a legit question,like U just asked...it was a simple question but not an everyday question..and ALL respected major sites do NOT flame.. dsscommunity.com/forums are very friendly and there is NO flaming there at all,maybe a little ribbing but nothing serious..
Thanks again Lk for showing respect. You must be from the old school like myself.I have tried to help out a few here myself with what knowledge I have. The least I can do. Take care
Ok the gtools and channel master won't work, says wrong file format. So after doing abit more reading, need to use a hex editer. Is there a simple way to convert one file format to another? thanks
LK
I don't believe so..
LK
read this link..
http://forums.al7bar.tk/forumdisplay.php?f=30
Thanks Lk, have you ever heard of any one trying to put- say a coolsat factory flash into a blackbird, then the reg. flash. Would this work? or would it kill the ird?
LK
No can do!
Home > Message Board > Home Video > Satellite TV > Archive through March 20, 2005 > Channel Lists [ « Previous ] [ Next » ]
