Thread: Problem with Fortec star lifetime ultra...!! please help |
New member Username: Tomcruise
Post Number: 1 Registered: Mar-05
| Posted on Tuesday, March 08, 2005 - 06:44 pm: |
I have just bought fortec lifetime ultra 3 weeks ago. it worked fine till today afternoon. no channel works at all. it gives me the following info message "data is being downloaded" then after a while it gives me "please input data" and nothing comes out at all. no channel works at all..!! is it a hardware problem? or software/firmware problem? or what? and what should i do to fix it? please help... |
| Posted on Tuesday, March 08, 2005 - 08:12 pm: |
read the "key00 change" thread |
Bronze Member Username: Allic
Post Number: 32 Registered: Jan-05
| Posted on Tuesday, March 08, 2005 - 08:14 pm: |
real time keys are here expressvu and dish keys |
Post Number: 4 Registered: Mar-05
| Posted on Tuesday, March 08, 2005 - 08:30 pm: |
i changed the key and everything is ok. thx guys.. |
Post Number: 37 Registered: Jan-05
| Posted on Tuesday, March 08, 2005 - 08:58 pm: |
Full support for for Fortec star |
| Posted on Tuesday, March 08, 2005 - 10:43 pm: |
Gordo...that site sucks..bogus info and old Dec 2 keys still posted as "real time keys"..quit spamming bogus info and garbage sites.. |
Post Number: 41 Registered: Jan-05
| Posted on Tuesday, March 08, 2005 - 10:55 pm: |
DUDE STOP BEING A GOOF. THE KEYS COME FROM A REAL TIME UPDATING JAVA SCRIPT SO THERE IS NO WAY THERE WRONG! LOOK HERE REAL TIME KEYS |
| Posted on Wednesday, March 09, 2005 - 08:57 am: |
HOW TO ENTER THE CODES FOR THE LIFETIME ULTRA FIX. Click MENU on the remote Then side arrow to CHANNEL EDIT Then down to CODE then OK then 1668 Then side arrow to turn OFF code Then down to NAGRAVISION then OK Then side arrow to DISH NETWORK Then down to KEY NUMBER, change to 00 Then down to KEY change to 8A C4 96 93 EC 79 9D 57 Then OK then EXIT once Then side arrow turn code ON then 1668 then EXIT EXIT Your TV should work now. |
New member Username: Denden
Sebring,
Fl
Usa
| Posted on Thursday, March 17, 2005 - 02:58 pm: |
can someone help for some reason i have no code button why? |
Sebring,
Fl
Usa
Post Number: 2 Registered: Mar-05
| Posted on Thursday, March 17, 2005 - 03:04 pm: |
can someone tell me where i can get factory software for lifetime ultra.think i loaded wrong software first could that be why i have no code button |
Jimbo7373 Unregistered guest |
| Posted on Tuesday, March 22, 2005 - 09:58 pm: |
I have a fortec ultra works well, But does anyone else have problems when it comes to re-entering a code after a key change?? Is there a recommended bin file, or a known issue with the keys not being excepted, or a special trick to getting the key to take each time you re-enter it?? Thx Jimbo |
