Thread: Programing a mitsubishi TV Channels (cs-2056R) |
New member Username: Zinger54
Post Number: 1 Registered: Mar-05
| Posted on Saturday, March 05, 2005 - 12:34 am: |
When I try to program the channels the darn thing skips over channels 2 thru 7 . Its like those channels arn't there. What Can I do? Anybody HELP! |
Silver Member Username: Samijubal
Post Number: 658 Registered: Jul-04
| Posted on Saturday, March 05, 2005 - 12:41 am: |
You should be able to manually program channels. Is the cable TV/antenna set on whichever you have? |
Post Number: 2 Registered: Mar-05
| Posted on Saturday, March 05, 2005 - 05:15 am: |
Yes the input is set correctly and I have tried the manual programing and it acts like those cannels have been remooved. And locked out somehow.Could there be a way to completely reset the TV to its factory settings. In other words rid the thing of all passwords if any? |
Post Number: 3 Registered: Mar-05
| Posted on Saturday, March 05, 2005 - 05:30 pm: |
Any body??????????? Anybody???????? Hello! |
Post Number: 660 Registered: Jul-04
| Posted on Saturday, March 05, 2005 - 05:48 pm: |
They can usually be reset, but you would have to contact the manufacter to find out how. |
Post Number: 4 Registered: Mar-05
| Posted on Sunday, March 06, 2005 - 11:52 am: |
Thankyou David for your input I do appreciate it. How do I contact the Manufacturer ? Do I call Mitsubishi ? Or the factory that built it? |
Post Number: 5 Registered: Mar-05
| Posted on Sunday, March 06, 2005 - 11:54 am: |
Whats the possibility of getting a remote for this TV? |
