Thread: Fortec lifetime ultra |
| Posted on Wednesday, March 02, 2005 - 10:28 pm: |
I just purchased a fortec lifetime ultra and do not know how to get started to get all the dishnetwork 110 and 119 channels, can anyone help? |
| Posted on Wednesday, March 02, 2005 - 11:26 pm: |
U must READ for hours,days,weeks,BEFORE U start a new hobby such as this...start at www.al7bar.tk forums...basically U install and align a dual LNB dish aimed at the 110 and 119 satellites..then flash the receiver and then scan the receiver for channels..and thats the VERY BASIC..its all very easy,BUT U have MUCH reading to do.. |
| Posted on Monday, March 07, 2005 - 10:47 pm: |
And here is a cheap place to get them. We have the best deals on the Fortec |
New member Username: Fortec_dummy
COMPTON,
NY
Post Number: 1 Registered: Mar-05
| Posted on Tuesday, March 08, 2005 - 05:52 pm: |
HELLO AND A THANK YOU IN ADVANCE ,,I WAS ENJOYING MY FORTEC WHEN,.,,POOF IT STARTED DOWNLOADING SUMTING....THEN ALL CHANNLES GO BUH BYE....ANYWAYS NOW THERES A BAR THAT SAYS PLEASE PUT INFO HOW DO I FIX THIS PLEASE HELP.... |
| Posted on Tuesday, March 08, 2005 - 06:00 pm: |
Read the manual and start over with the factory flash.. |
Bronze Member Username: Allic
Post Number: 39 Registered: Jan-05
| Posted on Tuesday, March 08, 2005 - 09:09 pm: |
Help for the fortec is here Fortec star lifetime ultra support |
| Posted on Tuesday, March 08, 2005 - 10:41 pm: |
that site sucks..bogus info and old Dec 2 keys still posted as "real time keys"..quit spamming bogus info and garbage sites.. |
| Posted on Wednesday, March 09, 2005 - 08:59 am: |
HOW TO ENTER THE CODES FOR THE LIFETIME ULTRA FIX. Click MENU on the remote Then side arrow to CHANNEL EDIT Then down to CODE then OK then 1668 Then side arrow to turn OFF code Then down to NAGRAVISION then OK Then side arrow to DISH NETWORK Then down to KEY NUMBER, change to 00 Then down to KEY change to 8A C4 96 93 EC 79 9D 57 Then OK then EXIT once Then side arrow turn code ON then 1668 then EXIT EXIT Your TV should work now. |
New member Username: Cancan
Post Number: 6 Registered: Dec-04
| Posted on Wednesday, March 09, 2005 - 09:49 am: |
Its good to see someone like LK is here to help at times like this...A lot others are taking the opportunity to peddle their sites and services |
| Posted on Wednesday, March 09, 2005 - 09:54 am: |
Can someone explain to me how to load channel list and where I can find a list for Lifetime Ultra. Not sure if this is the reason I'm missing alot of channels. Thanks in advance |
| Posted on Wednesday, March 09, 2005 - 10:45 am: |
Fortec lifetime ultra Help! I deleted channel data & music data and tried to download new channel list, I can not get it to except the gtd file for some reason although it appears to be taking it. I am using gtools v1.85 and a channel list I created using channel master. I end up having to scan for satellites.Thanks in advance.
New member Username: Redpirate
Hibbing,
Minnesota
Post Number: 1 Registered: Dec-04
| Posted on Wednesday, March 09, 2005 - 11:38 am: |
I did what LK said above and still don't get the picture. The 0 key wont stay put. When I change it, it scrambles as soon as I leave and come back to check on it. Odd, all the two digit sequences are there, but in a different order. And no picture - message says 'ecm or key change'. Any help would be appreciated. What is the current flash? |
| Posted on Wednesday, March 09, 2005 - 12:23 pm: |
Do NOT set it back to DEFAULT settings... |
| Posted on Wednesday, March 09, 2005 - 04:22 pm: |
How do I go about getting the new key into my new st 2000? Can it be done with the remote? Or do I have to reflash the receiver with an updated bin and if so where can I get I get the bin? Thanking all respondents in advance.... davidv |
| Posted on Wednesday, March 09, 2005 - 04:46 pm: |
read the other 2000 thread..www.dssftp.com FTA downloads.. 2. 2005-03-08 23:15:00 pff56new.bin PFF5.6 with key changed on 3-8-2005. Enjoy. |
COMPTON,
NY
Post Number: 2 Registered: Mar-05
| Posted on Wednesday, March 09, 2005 - 05:17 pm: |
THANK YOU TO ALL.....AND A SPECIAL THANKS TO LK VERY VERY MUCH THANKS |
COMPTON,
NY
Post Number: 3 Registered: Mar-05
| Posted on Wednesday, March 09, 2005 - 05:54 pm: |
ok heres another o master LK lol.. i noticed theres no chanell guide only stations so how am i suposed to find out whats on tv... |
LK DECIEVED ME Unregistered guest |
| Posted on Wednesday, March 09, 2005 - 09:07 pm: |
HEY I WAS TOLD BY YOU LK EVERTHING WAS FINE AND NOW I READ THAT ITS GOING TO GO DOWN? |
| Posted on Wednesday, March 09, 2005 - 09:26 pm: |
No programming guide -EPG with Dishnetwork and Fortec |
New member Username: Cablerock
Post Number: 5 Registered: Mar-05
| Posted on Wednesday, March 09, 2005 - 09:40 pm: |
What is going down LK? |
Post Number: 6 Registered: Mar-05
| Posted on Wednesday, March 09, 2005 - 10:30 pm: |
I have a directv Dish already install, I usually get signal on 110 not on the 119. I just want to know if I can leave it the way it is, and would my Fortec Star Lifetime ULTRA Receiver works with my dish point to the Directv satellite? |
| Posted on Wednesday, March 09, 2005 - 10:37 pm: |
what type dish..oval/round..1/2/3 LNB's...most DTV channels were off the 101...I would realign it to the 119...but if it pointed at 110 then thats OK too.. |
Post Number: 7 Registered: Mar-05
| Posted on Wednesday, March 09, 2005 - 10:51 pm: |
Is an oval Dish with 2 LNB. |
| Posted on Wednesday, March 09, 2005 - 11:06 pm: |
great dish for getting both 110 and 119..read the FTA dish pointing area of forums at www.dsscommunity.com |
| Posted on Thursday, March 10, 2005 - 09:27 am: |
When you order the Fortec Lifetime Ultra Receiver, how long does it usually take to get to my house? |
| Posted on Thursday, March 10, 2005 - 11:07 am: |
is there someone out there knows how to load a channel list? |
| Posted on Thursday, March 10, 2005 - 03:05 pm: |
Gtools 1.85..get it at any reputable site |
| Posted on Thursday, March 10, 2005 - 03:44 pm: |
thanks for the response. I got the Gtools 1.85 and a channel list. But when I click on Gtools, it give me an error code. Am I suppose to connect the com port with the IRD first before I click on Gtools? |
| Posted on Saturday, March 19, 2005 - 07:36 pm: |
I just bought fortec ultra and can't get it to flash |
pronkey Unregistered guest |
| Posted on Saturday, March 19, 2005 - 07:39 pm: |
is there a trick to getting the fortec to flash it's new. I would appreciate any help been reading for two days and can't get any info |
go home L T Unregistered guest |
| Posted on Sunday, March 20, 2005 - 01:00 pm: |
Aw NO this Dave MOle is back ....................geeze.......some people........Guys..guys...come on this guy.aka applebee ....aka.......the truth is back .aka.....LT...or whatever this looser calls himself......get a real job ya mole.....man oh man....SPEAK FOR YOURSELF LOOSER..........PEEPS BOYCOTT LT Lts somw looser BUM that works for ECOUSTICS......yes this site which is owned by DAVE.........yes DAVE owns this site...ive checked this out extensively..............ecoustics is DAVE OWNED and operated so PEEPS watch what ya say here....... |
| Posted on Sunday, March 20, 2005 - 11:53 pm: |
-= DssCentral =- Main site - dsscentral.ne*t Sister site - dsscommunity.com B I G SCAMMERS.........STAY AWAY >>>>PEEPS Ok peeps sorry U guys got burnt from em |
New member Username: Lalusingh
New york,
Ny
Us
| Posted on Friday, March 25, 2005 - 01:47 am: |
i dont have code key on channel page on the fortec ultra can anyone help |
New york,
Ny
Us
| Posted on Friday, March 25, 2005 - 01:48 am: |
i am tring to get directv antenna useful |
