Home > Message Board > Home Video > Satellite TV > Archive through March 20, 2005 > Using the DTV triple LNB dish
Author Thread: Using the DTV triple LNB dish
LK
The Phase III oval dish (FAQ)
All about the Phase 3 dish
(made for DTV, has 3 LNBs in same enclosure and built in multiswitch.)
YES, you CAN use this for your FTA setup to get 91 and 110 !
Advantages
1. You can add 2 LNBs and get 82 and 119 too on same dish.
2. Cheap or free from your DTV system.
3. Use only one wire and get 2 sats.
4. If u add 82 and 119, you'll use 3 ports on your diseq switch.. perfect to hook up an additonal bigger dish and a linear LNB and get birds like Intelsat 5 (T5) on your diseq empty port.
Connection
1. You need only 1 coax cable per receiver connected to the Phaze 3 dish, which is an advantage.
2. It doesnt matter which of the 4 ports you connect to. All 4 are the same in functionality. Your receiver will use the built in multiswitch to select one of the 3 sats. It does that via voltage change and 22khz tone signalling.
What this dish is for and how it was meant to work
1. This dish is for DirectTV. Was made to get the 101, 110 and 119 DTV sats.
2. Looking from behind the dish, the LNB are used like so:
.......left lnb = 119 sat
..middle lnb = 110 sat
.....right lnb = 101 sat
3. The multiswitch inside uses 22khz tone that is sent by your receiver to switch between 2 sats (just like any other 22khz switch). You'll have to set that up in your Pansat receiver.
4. 2 sats?? Yes! The multiswitch inside also serves as a combiner to combine signal from 110 and 119. So the 22khz will switch between the signal of 110 and 119 combined and the signal of 101
How the built in combiner works
1. The combiner takes TPs 2, 4, 6, 8, 10, 12, 14, 28, 30 and 32 from the middle LNB (110) and all the rest of the 32 TPs of the left LNB (119). You cannot change what TPs are combined... Covering middle LNB with foil wont work, cutting traces on the pcb wont work.
2. This is OK for DTV because DTV only has 3 TP's on DTV's 110 (28, 30 and 32) and they are different from the TPs on DTV's 119. (a tp is a frequency band on which up to 14 channels are transmitted). So combining different frequencies on the same wire, works fine. But it will affect your FTA setup.
How the built in combiner affects your pansat setup
1. You can use the Phaze 3 dish to get the 91 (bev) and the 110 (dn) satellites.
2. For that you point the dish to 101 (middle lnb), and adjust the skew. Now the left LNB picks up 110 (looking from behind the dish) and the right LNB picks up 91.
3. The combiner will combine TPs 2,4,6,8,10,12 and 14 from the 101 DTV sat with the rest of the TPs of the 110 DN sat. This means you will not be able to get TPs 2,4,6,8,10,12 and 14 from the 110 sat. but read on to see what your're missing.
What channels will i be missing on my Pansat
1. You will be missing only some local channels. (ABC,CBS..etc..), which may or may not be local to you. Thats it !
2. To see what is missing you go to lyngsat and check to see whats on TP 2,4,6,8,10,12 and 14 on DN's 110 sat.
4. You will see that ALL but 2 of these TPs are of BEAM type... which means you wouldnt have been able to get them ANYWAYS, Unless you are in the area indicated for that particular beam.
5. The 2 conus (available nationwide) tps that you'll be missing are TP 12 and TP 14. Whats on it? Only locals from Lexington, Knoxville, Jackson and Denver.
What you should be pointing it to, to get 91 and 110
Pansat setup:
Assuming you will point this dish to 101 (middle LNB to 101), you will be able to get 91 and 110 on the 2 outside LNBs WITH proper SKEW, and thats what u want do to if you gonna use it with your Pansat. The middle LNB is useless for Pansat setups on Phase 3 dish as it will be pointed to DTV's 101 sat. Also covering this lnb with anything won't help to give u back those locals that you'll be missing.
To get the azimuth and elevation for your dish, calculate it for the 101 sat. For skew see below.
DTV setup
If you set the dish like above, it will not work for DTV. If you want it to work for DTV you point it to 110 (middle lnb gets 110) and the outer will get 101 and 119.
To get the azimuth and elevation for your dish, calculate it for the 110 sat. For skew see below. Or you can use your DTV receiver, enter your zip code and it will give you all settings.
U can't use the Phase 3 dish for DTV and Pansat at the same time because you're pointing to different sats.
How to calculate and use Skew:
Skew= vertical offset (twist) in degrees from the vertical (from the 90 degrees mark on your dish)
1. Go to Satellite Nut page
2. Enter your location info.
3. Calculate skew for the 2 outter satellites on your dish (for the pansat setup on Phaze3 that would be 91 and 119)
4. Add them toghether and divide by 2
5. U get the skew number. (Disregard the minus sign if its negative)
To use SKEW:
You must ensure that the top of the mast is perfectly plum. Best thing is to use an eye round level (home depot,tools section - $3) that u put right on top of the mast. You do that BEFORE you even put the dish on the mast.
If you are on the EAST coast, skew = counter-clockwise rotation in degrees from the 90 deg mark on your phaze 3 dish. Set your dish to 90 minus the skew number
If you are on the WEST coast, skew = clockwise rotation in degrees from the 90 deg mark on your phaze 3 dish. Set dish to 90 plus the skew number
Receiver setup
No diseq switch is needed, only one wire needs to be connected to the Phase 3
91: 22khz OFF, Diseq - OFF (or ON - doesnt matter)
110: 22khz ON, Diseq - OFF (or ON - doesnt matter)
Can i also get 119 on this dish?
Yes, if you have an additional DTV or DN (circular) LNB laying around, you can strap it to the LEFT of the 3 existing LNBs (looking from behind the dish). You will now have to use a DiseqC switch to switch between the wire from the Phaze 3 and the wire from the strapped LNB.
Receiver setup with the strapped on 119 LNB
Assuming u put the wire from the Phaze 3 in port #1 and the wire from the strapped LNB in port #2, your setup will be:
91: 22 khz OFF, Diseq #1
110: 22khz ON, Diseq #1
119: 22khz OFF (or ON - doesnt matter), Diseq #2
Can i also get 82 on this dish?
Yes, if you have an additional DTV or DN (circular) LNB laying around, you can strap it to the RIGHT of the 3 existing LNBs (looking from behind the dish). You will now have to use a DiseqC switch to switch between the wire from the Phaze 3 and the wire from the strapped LNB.
Receiver setup with the strapped on 82 LNB
Assuming u put the wire from the Phaze 3 in port #1 and the wire from the strapped LNB in port #3, your setup will be:
82: 22khz OFF (or ON - doesnt matter), Diseq #
Username: Jmill1948
Chester, Va
Usa
Post Number: 548
Excellent post..............
someone123455
how do you make the pansat 2500a to work? i tried everything and couldnt get it to to work.
Beerman1
Hay LK hows it goin, i picked this thread to ask you a question, because it seems the weirdos have'nt come here yet. My Nephew is a Sat. installer, he came to the house and got my dave dish set perfect and working great, but he hooked up my super s cable which made the picture better then ever, but now i cant turn the TV on and off with the remote, he was gone when i got home so i have'nt been able to ask him what he did to cause this problem, have you ever heard of this before? keep up the great help that you provide, us peeps that dont know. Thanks Beerman1
LK
Which dave dish?...3 LNB?....just curious...surprised that S cable made a difference,U must have had bad cable or connectors on coaxial...sorry can't help with the remote issue..it should work still...maybe for some odd reason,it needs reprogrammed for your TV..
Q
Beerman,did ya check the batteries, is the remote in TV mode,has the remote lost it's code,is there something ubstructing the IR path? I'm sure it's something simple you've overlooked.Try a differant universal remote if all else fails to narrow down the problem.
Beerman1
To LK and Q, thanks for the help, it is a 3 lnb dish, havent tried to reprogram the remote, guess i need to quit drinkin beer for awhile, lol, i should of thought of that.
xgos
LK,
Your post is very well put together. I'm having a problem setting up my multi dish. I have a Fortec Ultra with a 4 way DiSeqC switch and 3 LNBF properly configured as linear.
Dish -> Switch
#1 (91)
#3 (110)
#4 (119)
I've been able to connect to 91 but am having trouble locating 110 and 119. From other forums, it appears that these other sats should show up under different switch settings. But, when I enter the sat setup only port #3 seems to be active (the only port I get quality on). Ports #1, #2, and #4 have no quality. Now, I expect #2 to have nothing cause no LNBF is there and I'm pretty sure the configuration is correct because the level is very low (23%). If an LNBF is connected to a port I usually get a level of around 40-55%.
Am I correct in assuming that 91 is coming through on LNBF #3 (110)? Any suggestion to what I’m doing wrong?
Home > Message Board > Home Video > Satellite TV > Archive through March 20, 2005 > Using the DTV triple LNB dish [ « Previous ] [ Next » ]
