Home > Message Board > Home Video > Satellite TV > Archive through March 07, 2005 > Dishnet Channel
Author Thread: Dishnet Channel
Username: Lowtecintegra
i just flashed my lifetime ultra with "al7barftaultra_040920_247_api(ntsc-pk0_rev2)-f" with bootfile 6.0. i'm getting 200 channels. 4 ppv and other. i have my dish set to 61.5w using echo 3. do i get more channels if i set my dish to 100 / 109? thanx
LK
U mean 110/119 (echo 6-7-8) for dishnet...go to www.lyngsat.com and see what channels are on what satellites.
Username: Timscarlet
Dayton, Oh
Usa
Newest Blacklist release for Pansat 2500A
Release Date : 01/04/2005
Chat Help at :
irc.earthcore.net port:6667
irc.dsscommunity.com port:6667
Rooms:#pansat or #fta
Included files :
[1] X-85BL_050104_240_api(N).bin [the bin file]
[2] EchoStarPackage.gtd [recomended sgtools channel list]
[3] 2500A_040607_222_api(N).bin [original pansat bin]
[4] Readme.txt [this file]
Purpose :
The main purpose for this flash is to give you, the user
a way to have your ird conform to the dishnet channel listings.
This flash creates a new sat in your [sat key] info. This new listing
is called, "echostar package".
You will be able to press your Sat on the remote, choose the "Echostar
package" and have channels come up just as on a dishnet ird.. ie..
300 will be HBO East, 122 will SciFi Channel, etc.
Recomended Procedure :
Take the blacklist updater version 1.4 and dowload to your ird,
the included 2500A_040607_222_api(N).bin.
Next, Download the new flash 2500A_040607_222_api(N).bin also included
in this zip file.
NEXT, PLEASE CHOOSE, either you can scan your sats or put on a channel list.
One or the other... don't do both.
We have also included a channel list, X-85BL_050104_240_api(N).gtd.
Use SGTools 1.86 to download that file into your 2500 after you have
completed your flash.
Proceed to the parental controls, "second pin", and enter with 0000.
go to "Set Default Key" and press "OK" on your remote. Wait for it to
save and exit out to the TV Screen.
Now on your remote, hit your sat button. You will see "Echostar Package".
Hit the "ok" key, and enter that channel list. Your channel list is imported
into there and you can proceed to watch tv. You will find that pressing
your key numbers, say, 122 will bring you to scifi channel and so forth.
there you have it...
If you are NOT USING A CHANNEL LIST.
Simply set up your ird as you normaly would. Choose language and go into
setup. Antenna set up is done just as you normally would.
Next, after your sats are set proplerly.. do a BLIND scan of each.
Now on your remote, hit your "sat" button. You will see "Echostar Package".
Remember, do one or the other.
these are for satellites 110/119 echo 7 & echo 6,8
Home > Message Board > Home Video > Satellite TV > Archive through March 07, 2005 > Dishnet Channel [ « Previous ] [ Next » ]
