Thread: Delayed sound on new Sammy 4663 with HD/DVR....help please |
Bronze Member Username: Peadegm
Post Number: 14 Registered: Jan-05
| Posted on Thursday, February 24, 2005 - 05:20 pm: |
I am using a HD/DVR and have connected to my Sammy 4663 using only a HDMI cable. If I have another TV on in the kitchen and they are both on the same channel there is an echo because the Sammy is delayed. Why is this and what can I do?? Thanks |
Post Reader Unregistered guest |
| Posted on Thursday, February 24, 2005 - 05:25 pm: |
The processing of the signal through the cable box is the source of the delay. I assume that your kitchen TV is straight cable. You cannot eliminate this unless you put the kitchen on a box too. One solution is close the door. |
Silver Member Username: Paul_ohstbucks
Post Number: 137 Registered: Jan-05
| Posted on Thursday, February 24, 2005 - 05:38 pm: |
Exactly... There is nothing wrong. That's just how it is. |
Post Number: 15 Registered: Jan-05
| Posted on Thursday, February 24, 2005 - 05:43 pm: |
My old Toshiba had a cable box and no delay, maybe it's the HDMI cable?? Any other thoughts? |
| Posted on Thursday, February 24, 2005 - 05:48 pm: |
The exact same box? |
The real PR Unregistered guest |
| Posted on Thursday, February 24, 2005 - 06:00 pm: |
Post Reader, You have hi-jacked my old and quite controversial handle. It comes with baggage you may not want to deal with. Good luck! |
