Home > Message Board > Home Video > Satellite TV > Archive through March 07, 2005 > Gtools and channel lists
Author Thread: Gtools and channel lists
Username: Yankeesrule
I have a question about gtools and downloading a channel list. Is it normal for the receiver to read 001 after the channel list download? I waited for the computer screen to say download complete. Should the receiver show anyting except "ON"? Thanks
LK
Download the list you want to use. Click on the file folder to open it in your Gtools. It should display the selected list. Right click under any satellite name and select tools. Then stb connect (make sure it is set as type 2).Turn your receiver on the back and wait for flashing lights on your receiver and then click download and wait for 100% complete and popup to say completed. Sometimes if it doesn't work on COM 1 you have to try COM 2. Flip switch off on back of receiver and reconnect to coax from dish flip switch back on. You should be set,no sat scanning needed.
Home > Message Board > Home Video > Satellite TV > Archive through March 07, 2005 > Gtools and channel lists [ « Previous ] [ Next » ]
