Thread: Sony KDF60XS955 |
New member Username: Racoola
Post Number: 1 Registered: Feb-05
| Posted on Wednesday, February 23, 2005 - 02:21 pm: |
I've got a question that I don't know if anyone can answer. I bought a new 60" sony XS955 and it seems that when your watching a movie that the peoples legs seem to be stretched a little wide. I've double checked and it's definetly not wide girls gone wild. I have a progressive scan dvd player and I don't know if I have a wrong setting or what. I always leave it on full screen viewing and have switched it to normal and it seems like it stretches people taller than normal. Please help!!! |
LCD Guy Unregistered guest |
| Posted on Thursday, February 24, 2005 - 01:42 am: |
Make sure when you are watching something in 16:9 widescreen that you are in "full" mode and when viewing a 4:3 show (bars on the sides of the picture) that you are in "normal" mode. Once you make these settings, the picture should not appear distorted. |
| Posted on Thursday, February 24, 2005 - 03:39 am: |
Also, check the settings on your DVD to make sure widescreen (16:9) is selected as the default. They came from the factory with 4:3 as the default. Should be able to find the setting with the on-screen- programming menu. Hope this helps. |
| Posted on Thursday, February 24, 2005 - 03:44 am: |
I meant check the settings on your DVD player. You probably figured that was what I meant;) |
