Home > Message Board > Home Video > Rear Projection TVs > Archive through February 25, 2005 > Toshiba 52hm94 screen adjustment
Author Thread: Toshiba 52hm94 screen adjustment
Username: Wild1devil
Does anyone know how to access the service mode on this model and adjust the screen position? The picture on my screen is shifted to the right about 3/4" and I'd like to get it centered. It's not noticable on HD channels, but when viewing regular channels the bars on the side of the screen are definitely not even.
Jim777
Ryan:
Press mute twice, then hold it while pressing menu on the TV. An S will appear on the upper right of the screen. Press menu again and an item and value will be displayed. I would be very reluctant to change any values unless I knew what I was doing in this mode as I have read you can really screw up your set. You can view and download the sevice manual for the 52HMX94 which is virtually identical to the 52HM94 on the following thread:
http://www.avsforum.com/avs-vb/showthread.php?s=a15c07c7a011b357f58620296acf2406 &threadid=438276&perpage=20&pagenumber=76
Note post 1518
It has detailed information on settings, etc., however it doesn't explain what the various settings mean.
Home > Message Board > Home Video > Rear Projection TVs > Archive through February 25, 2005 > Toshiba 52hm94 screen adjustment [ « Previous ] [ Next » ]
