Do you need unlock code for Memorex MVD2042? Here it is!
Username: Tranceaddict
Reno, NV
If you would like to adjust the region code setting on you Memorex DVD Player, simply follow
the instructions below.
1. Press the Remote Control "OPEN/CLOSE" button, to make the try open.
2. Next, press 9735 on the remote control.
3. Select your desired Region Code, by using cursor keys.
· 1 for Region 1
· 2 for Region 2
· 3 for Region 3
· 4 for Region 4
· 5 for Region 5
· 6 for Region 6
· 0 for ALL Regions
4. Press ENTER to confirm.
Then re-load the DVD disc.
andrey123
This did not work for me. I have MVD2042 silver. Following these instructions did absolutely nothing. Any updates would be greatly appreciated
Reno, NV
I have the same one and it works. On your user's guide does it say:
MVD2042
(Suffix A) ?
Make sure you have the DVD tray open when you type in the code. I don't think it will work with a DVD in the tray, so it's best to just leave it open when you type in the code. It's pretty self explanatory after that. Good luck. If you have a different model then me just email Memorex with all the info on your unit and ask. Thats what I did and they sent me the info above. I have been playing my Velfarre cyber trance DVDs from Japan on mine and it works fine.
Reg Code
The Region Free steps do work. Anyone knows the code to free Macrovision!!!
snowboarder74
I have Memorex MVD 2042 (Suffix B). Does this hack for the above DVD?
Reno, NV
It should work. Give it a try and let us know if it works. Just remember not to have a DVD in the tray when you type in the code.
Boricuan
IT REALLY WORKS, Excelelnt job and thank you for sharing it!!!!! I have a Panasonic Region Free that costed over $200, now I have this one for less than $50. WOW!
blank
does anyone know the code for memorex dvd mvd2030
slynj
suffix b
does not work with this hack
anyone knows how to crack mvd2042 suffix b
slynj
Finaly found it SUFFIX-B and im pasting it here: (Good lock to everyone) Sly.
I tried the hack for the Memorex-2020 (posted by upsino) and it worked right away. Here it goes:
1. Turn on the Player (with no discs in)
2. Press the Open/Close button (leave it open, like if you were yet to insert a DVD)
3. Press the Clear button (on the bottom of your remote control, close to the numbers 0-9)
4. Press the following sequence: 1,3,6,9.
5. Press the number of the Region you want (0 for Region free)
6. Turn off and on your player.
P.S: note that nothing will apear or change on the screen while you do the process. Just follow through completion and you'll have a multi region DVD player.
