Home > Message Board > Home Video > TV Basics > Archive through February 22, 2004 > Amateur Cable Hook Up Question - Easy...
Author Thread: Amateur Cable Hook Up Question - Easy one
Username: Chrisboston
I have purchased the Sony 50" HD widescreen Rear Projection on LCD. I have the following equipment:
Sony DA333ES: It has optical, coax and s-video jacks, but I dont see component video
Sony DVP-C600D: 5 cd/dvd carousel that does have Compenent Video, S-Video and Optical.
Purchasing Comcast HD Cable box.
Question: since I dont seem to have component video on my a/v receiver, what do I do? connect s-video from tv to receiver and to dvd OR do I connect compenent from tv to DVD and then s-video from dvd to the receiver?
Thanks for your assistance
Chris,
Connect your HD cable box to your TV through a DVI or component video, connect your DVD player to the TV using a component video input and connect the audio outputs from the HD cable box and the DVD player directly to your a/v receiver using the optical and/or coax connections.
Hope this helps.
Home > Message Board > Home Video > TV Basics > Archive through February 22, 2004 > Amateur Cable Hook Up Question - Easy... [ « Previous ] [ Next » ]
